    Starter problem
    73 Posts 8 Posters 82.3k Views 5 Watching
    • K Offline
      kurt @strawberry 3.141
      @strawberry-3.141
      I’m working with File Zilla to transfer the files.
      By now I guess he the one who makes the config folder dissapear. Have you ever heard of something like that? or can you recommend an other tool to upload files? I tried Cyberduck, but won’t work.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt im using filezilla or an usb stick
        • K Offline
          @strawberry-3.141
          Anyway, I copied the folder again to the pi.
          calender, changed compliments and newsfeed appear.
          Do you have an idea, why the weather and the forecast dont show?
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
          	language: 'de',
          	timeFormat: 24,
          	units: 'metric',
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'calendar',
          			header: 'US Holidays',
          			position: 'top_left',
          						symbol: 'calendar-check-o ',
          						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '2761369',  //ID from http://www.openweathermap.org
          				appid: 'xxxxxxxxxxxxxxxxxx'
          			module: 'weatherforecast',
          			header: 'Das Wetter',
          				appid: 'xxxxxxxxxxxxxxxxx'
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "Der Standard",
          						url: "http://derStandard.at/?page=rss&ressort=Seite1"
          				showSourceTitle: true,
          				showPublishDate: true
          Note from admin: Please use Markdown on code snippets for easier reading!
            @kurt do you get any errors in the terminal, maybe your api key is incorrect etc.
            • K Offline
              @strawberry-3.141 Thank you for todays help, can’t find the reason,
              and no, I get no messages.
              Thanks a lot
              • K Offline
                kurt @in_a_days
                @in_a_days
                Thank’s a lot for your help, but strawberry allready repaired my mistakes, so by now i’m fine, just thinking about what is the best way to save such a running system, so I can go back when things go wrong and I found out things go very quick wrong :)
                So have a nice day and Thank you
                yawnsY 1 Reply Last reply Reply Quote 0
                • yawnsY Offline
                  yawns Moderator @kurt
                  @kurt
                  I would create an archive of the entire magicmirror folder.
                  cd ~
                  tar -cvf mirror.tar /MagicMirror
                  • K Offline
                    kurt @yawns
                    @yawns
                    this is on the Raspi and on which place will he make the archiv ?
                    And to save it outside the best way is? I#m using Filzilla is this a right tool for this plan?
                    • yawnsY Offline
                      @kurt
                      This command will create a file called mirror.tar in your home directory on your raspberry. You can copy/transfer it to your computer with filezilla, the same way you did to copy new files to your raspberry
                      K 3 Replies Last reply Reply Quote 0
                      • K Offline
                        kurt @yawns
                        @yawns
                        perfekt
                        thank you, I better bring my sheeps to a save place :)
                        • 6
                        • 7
                        • 8
                        • 5 / 8
