    MMM-MercedesMe
    52 Posts 9 Posters 23.5k Views 8 Watching
    • K Offline
      kar1507
      @ashishtank
      That explains why I always had Authenticate there. I’ve added it now. Thank you very much.
      @JerryP
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @kar1507
        @kar1507 Nice. that is the same as over her white the electric car.
        Thanks for the screen view
        • P Offline
          pyrophoenix
          First of all Thank you for this module. I followed the full setup and unfortunately I have no update.
          Here is my setup:
            module: 'MMM-MercedesMe',
            position: 'bottom_left',
            header: 'Mercedes Fuel',
                    client_id: '**********************************************',
                    client_secret: '**************************************************',
                    vehicleType: 'Petrol',
                scope: 'mb:vehicle:mbdata:vehiclestatus offline_access',
                    vehicleId: 'W*****************************9',
                    displayStyle: 'twodial',
                    updateInterval: 300000,
                debug: true,
                    maxRange: 520
          On the log I do have this error:
          [05.04.2021 23:33.58.329] [LOG] Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W**************9/containers/electricvehicle
          [05.04.2021 23:33.58.575] [LOG] 403 - Forbidden
          Despite it says electricvehicule the setup on MercedesMe Dev is exactly as per the instruction.
          I’m a bit lost at this point.
          Thank you in advance for any help!
          • P Offline
            pyrophoenix
              ashishtank Module Developer @pyrophoenix
              @pyrophoenix can you please restart the mirror and check if it works ? did you login to get the token ?
              • P Offline
                pyrophoenix @ashishtank
                Hi @ashishtank
                Yes I did reboot and it ask to authenticate everytime that I reboot it. I have to click on it then it goes blank page and the picture I’ve sent appear
                  @pyrophoenix can you delete the tokens.json file in MercedesMe directory and then restart the mirror ? it should show you login button and then you should be able to login and get token. after that check if tokens.json file is created or not…
                  P 2 Replies Last reply Reply Quote 0
                  • P Offline
                    @ashishtank Thanks for your reply!
                    I think I was looking the finger instead of the sky…I found the issue but couldn’t resolve it. It request EV while I have a petrol (But my config as you saw earlier was correct). On the logs I have that part saying:
                    [07.04.2021 22:13.34.301] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1************9/containers/electricvehicle
                    Then I missed that part (That I thought was for another modules):
                    [07.04.2021 22:13.34.785] [LOG]   403 - Forbidden
                    On request it says:
                    [07.04.2021 21:53.39.767] [LOG]   Handle OAuth request
                    [07.04.2021 21:53.39.784] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=d***********eb&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=7********************************f
                    [07.04.2021 21:53.41.314] [LOG]   Handle OAuth callback
                    [07.04.2021 21:53.41.844] [LOG]   OAuth callback Success
                    Meaning that now the token is indeed good but it request EV status rather then the rangeliquid and tankvalue (as mentioned here: https://developer.mercedes-benz.com/products/fuel_status/docs). M’I missing something?
                    • P Offline
                      @ashishtank Just one thing that I saw…Step 7 has your Client ID and Secret uncovered. I highly recommend to blur it if it’s still an active account :/
                        @pyrophoenix Hi Looks like you found the issue for me :) the vehicle type right now i am checking is only Electric (default) and Diesel. I will improve the code to check for petrol as well but you can have a work around and can configure your vehicle type as 'diesel' and it will work as api is same for diesel and petrol !
                        getVehicleDataUrl: function (config) {
                          var vehicleStatus = 'electricvehicle';
                          switch (config.vehicleType.toLowerCase()) {
                            case 'diesel': <-----------------------------------------------------------------------------
                              vehicleStatus = 'fuelstatus';
                        About my sample client id and secret in guide they are fine as I do not have a Car :D and also that account and app are throw away account with out any real car linked to it.
                        Let me know if changing the config to diesel and restarting mirror solves the issue.
                        • 6
                        • 3 / 6
