    MMM-MercedesMe
    53 Posts 10 Posters 36.8k Views 9 Watching
    • A
      ashishtank Module Developer @pyrophoenix
      @pyrophoenix Let me know if changing the scope solves the issue. I will update the documentation accordingly.
        pyrophoenix @ashishtank
        @ashishtank Hi! Unfortunatly it didn’t :/ Mercedes are looking at this matter and they will get back to me normally on Monday.
        Thanks again for your help and I’ll keep you informed!
        • A
          Andreas Heins
          When i press “Authenticate” i only get “Handle OAuth callback” in the Log and nothing more.
          Any Ideas?
          Mit freundlichen Grüßen
          Andreas
          • A
            ashishtank Module Developer @Andreas Heins
            @andreas-heins Is your configuration correct ? if you have already logged in then it will not display login screen and will directly get token. Did you check if tokens.json file is created and updated after authentication ?
            • A
              Andreas Heins
              @ashishtank i checkend my configuration and now i have another error „ 400 - Invalid redirect_uri“.
              • A
                @andreas-heins looks like you are missing Step 7 from https://github.com/ashishtank/MMM-MercedesMe documentation. Please check, also which version of Magic Mirror are you using ? there are breaking changes in v2.15 in MM core and issue i have not fixed for my module yet.
                  rogers0072002 @ashishtank
                  @ashishtank hello i folow all steps and i had initial auth form
                  i install oauth module ( explain by sdetweil in gitlab issues).
                  My was created correctly but i receive no data.
                  My version of MM is 2.15
                  in mm log i found this
                  0|MagicMirror | [28.06.2021 22:13.20.726] [ERROR]
                  0|MagicMirror | Failed to fetch git data for MMM-homeassistant-sensors: Error: block timeout reached
                  0|MagicMirror | [28.06.2021 22:13.21.674] [LOG]
                  0|MagicMirror | 403 - Forbidden
                  0|MagicMirror | [28.06.2021 22:13.21.678] [LOG]
                  0|MagicMirror | [28.06.2021 22:13.21.866] [LOG]
                  thk in advance
                    rogers0072002 @rogers0072002
                    @rogers0072002 sorry is not good log
                    0|MagicMirror | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDCXXXXXXXXXXXXXX/containers/fuelstatus
                    0|MagicMirror | [28.06.2021 22:35.42.737] [LOG]
                    0|MagicMirror | [28.06.2021 22:38.15.691] [LOG]
                    0|MagicMirror | [28.06.2021 22:38.16.209] [LOG]
                    0|MagicMirror | [28.06.2021 22:38.21.119] [INFO]
                    • A
                      ashishtank Module Developer @rogers0072002
                      @rogers0072002 As per logs it looks like you have not added scope or token is not valid can you delete the tokens.json file and try login again ? make sure you have linked right scope (electric or fuel) in the Mercedes app.
                        matt216
                        Hello.
                        Lovely looking module. Having some trouble with mine. The single dial displays, but doesn’t seem to have pulled any data from Mercedes. I did not ever get an authenticate option after installing…
                        Did pm2 restart mm and then watched pm2 logs… only thing relevant I could see was:
                        0|mm  | [24.11.2021 13:58.46.575] [ERROR]
                        0|mm  | Whoops! There was an uncaught exception...
                        0|mm  | [24.11.2021 13:58.46.583] [ERROR]
                        0|mm  | TypeError: Cannot read property 'toLowerCase' of undefined
                        0|mm  |     at Class.getVehicleDataUrl (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:146:32)
                        0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:106:25)
                        0|mm  |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:112:11)
                        0|mm  |     at Socket.emit (events.js:210:5)
                        0|mm  |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:253:20)
                        0|mm  |     at Socket.socket.onevent (/home/pi/MagicMirror/js/node_helper.js:105:13)
                        0|mm  |     at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:216:22)
                        0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:205:28
                        0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:75:11)
                        0|mm  | [24.11.2021 13:58.46.588] [ERROR]
                        0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|mm  | [24.11.2021 13:58.46.593] [ERROR]
                        0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        I cannot see a tokens.json in the ~/MagicMirror/modules/MMM-MercedesMe folder to try that option.
                        I have the following products enabled in developer portal:
                        Appreciate any tips, thanks.
                        Matt
                        • A
                          ashishtank Module Developer @matt216
                          @matt216 Can you check if request package is installed ? you can do so with below command
                          npm install request --save
                            matt216 @ashishtank
                            @ashishtank ran command (added 47 packages), reloaded MM, same issue :(
                            Appreciate the help
                            • A
                              @matt216 did you set the vehicleType correctly in config. is the config variable in correct case ?
                              switch (config.vehicleType.toLowerCase()) { <--- error on this line.
                                   case 'diesel':
                                     vehicleStatus = 'fuelstatus';
                                matt216 @ashishtank
                                @ashishtank my vehicle is electric, so I didn’t include that in the config as it’s the default.
                                I just tried adding
                                vehicleType: 'Electric'
                                but nothing changed.
                                Any advice on logs I can check? I feel a bit unhelpful here… :)
                                Matt
                                • W
                                  Woody @matt216
                                  Hi together,
                                  is this module still active. Tried to register my project with mercedes but there is no purchase model ’ FREE’ as mentioned on the Github page. Only a Business model is available without
                                  any details regarding the cost. Has anyone tried it and has experience with this model. It sound like it is only for business professionals.
                                  Thanks in advance folks
                                  • 3 / 3
