    MMM-MercedesMe
    53 Posts 10 Posters 36.8k Views 9 Watching
      pyrophoenix @ashishtank
      @ashishtank Thanks for the reply!
      I have erased token and reboot it with Diesel…Still the same issue but this time it goes to the correct URL
      [08.04.2021 13:38.22.939] [LOG]   Handle OAuth request
      [08.04.2021 13:38.22.946] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=c****************4a&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=d*************************e
      [08.04.2021 13:38.25.124] [INFO]  Newsfeed-Fetcher: Broadcasting 66 items.
      [08.04.2021 13:38.26.049] [LOG]   Handle OAuth callback
      [08.04.2021 13:38.26.982] [LOG]   OAuth callback Success
      [08.04.2021 13:38.34.388] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1****************9/containers/fuelstatus
      [08.04.2021 13:38.35.647] [LOG]   403 - Forbidden
      It is still saying error 403
      • A
        ashishtank Module Developer @pyrophoenix
        @pyrophoenix did you followed the step 3 correctly ? did you linked fuel status scope with app ? as shown in image below you should see
        Fuel Status BYOCAR
          pyrophoenix
          Thanks! Great that YOU point it out! I cheated a bit and directly put the “fuel” on the URL as so
          https://developer.mercedes-benz.com/products/fuel_status/get_access?pm=free
          I just added it and I’ll try now.
            pyrophoenix
            Not working…But it seems that the Bearer is not generated properly. If I try the test curl provided by the Mercedes Dev, it does work…
            • A
              @pyrophoenix Can you delete the app in Mercedes dev portal and create new one with correct scope ? also delete tokens.json file and restart the mirror. I think it is some caching issue.
                @ashishtank Remove and did a brand new app on console. Removed tokens.json and reboot…Same problem
                There is one thing that is on your step (Right from step 1) saying:
                AUTH CALLBACK URL: http://localhost
                Where that needs to be introduced?
                  pyrophoenix
                  Details.PNG image url)
                  A 2 Replies Last reply Reply Quote 0
                  • A
                    @pyrophoenix things looks correct, http://localhost:8080/MMM_MercedesMe/callback is important other localhost urls in callback are optional. I have sent you PM what we can do next.
                    • A
                      @pyrophoenix Let me know if changing the scope solves the issue. I will update the documentation accordingly.
                        @ashishtank Hi! Unfortunatly it didn’t :/ Mercedes are looking at this matter and they will get back to me normally on Monday.
                        Thanks again for your help and I’ll keep you informed!
                        • A
                          Andreas Heins
                          When i press “Authenticate” i only get “Handle OAuth callback” in the Log and nothing more.
                          Any Ideas?
                          Mit freundlichen Grüßen
                          Andreas
                          • A
                            ashishtank Module Developer @Andreas Heins
                            @andreas-heins Is your configuration correct ? if you have already logged in then it will not display login screen and will directly get token. Did you check if tokens.json file is created and updated after authentication ?
                            • A
                              Andreas Heins
                              @ashishtank i checkend my configuration and now i have another error „ 400 - Invalid redirect_uri“.
                              • A
                                @andreas-heins looks like you are missing Step 7 from https://github.com/ashishtank/MMM-MercedesMe documentation. Please check, also which version of Magic Mirror are you using ? there are breaking changes in v2.15 in MM core and issue i have not fixed for my module yet.
                                  rogers0072002 @ashishtank
                                  @ashishtank hello i folow all steps and i had initial auth form
                                  i install oauth module ( explain by sdetweil in gitlab issues).
                                  My was created correctly but i receive no data.
                                  My version of MM is 2.15
                                  in mm log i found this
                                  0|MagicMirror | [28.06.2021 22:13.20.726] [ERROR]
                                  0|MagicMirror | Failed to fetch git data for MMM-homeassistant-sensors: Error: block timeout reached
                                  0|MagicMirror | [28.06.2021 22:13.21.674] [LOG]
                                  0|MagicMirror | 403 - Forbidden
                                  0|MagicMirror | [28.06.2021 22:13.21.678] [LOG]
                                  0|MagicMirror | [28.06.2021 22:13.21.866] [LOG]
                                  thk in advance
                                    rogers0072002 @rogers0072002
                                    @rogers0072002 sorry is not good log
                                    0|MagicMirror | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDCXXXXXXXXXXXXXX/containers/fuelstatus
                                    0|MagicMirror | [28.06.2021 22:35.42.737] [LOG]
                                    0|MagicMirror | [28.06.2021 22:38.15.691] [LOG]
                                    0|MagicMirror | [28.06.2021 22:38.16.209] [LOG]
                                    0|MagicMirror | [28.06.2021 22:38.21.119] [INFO]
                                    • A
                                      ashishtank Module Developer @rogers0072002
                                      @rogers0072002 As per logs it looks like you have not added scope or token is not valid can you delete the tokens.json file and try login again ? make sure you have linked right scope (electric or fuel) in the Mercedes app.
                                        matt216
                                        Hello.
                                        Lovely looking module. Having some trouble with mine. The single dial displays, but doesn’t seem to have pulled any data from Mercedes. I did not ever get an authenticate option after installing…
                                        Did pm2 restart mm and then watched pm2 logs… only thing relevant I could see was:
                                        0|mm  | [24.11.2021 13:58.46.575] [ERROR]
                                        0|mm  | Whoops! There was an uncaught exception...
                                        0|mm  | [24.11.2021 13:58.46.583] [ERROR]
                                        0|mm  | TypeError: Cannot read property 'toLowerCase' of undefined
                                        0|mm  |     at Class.getVehicleDataUrl (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:146:32)
                                        0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:106:25)
                                        0|mm  |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:112:11)
                                        0|mm  |     at Socket.emit (events.js:210:5)
                                        0|mm  |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:253:20)
                                        0|mm  |     at Socket.socket.onevent (/home/pi/MagicMirror/js/node_helper.js:105:13)
                                        0|mm  |     at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:216:22)
                                        0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:205:28
                                        0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:75:11)
                                        0|mm  | [24.11.2021 13:58.46.588] [ERROR]
                                        0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|mm  | [24.11.2021 13:58.46.593] [ERROR]
                                        0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        I cannot see a tokens.json in the ~/MagicMirror/modules/MMM-MercedesMe folder to try that option.
                                        I have the following products enabled in developer portal:
                                        Appreciate any tips, thanks.
                                        Matt
                                        • A
                                          ashishtank Module Developer @matt216
                                          @matt216 Can you check if request package is installed ? you can do so with below command
                                          npm install request --save
                                            matt216 @ashishtank
                                            @ashishtank ran command (added 47 packages), reloaded MM, same issue :(
                                            Appreciate the help
                                            • 2 / 3
