    MMM-MercedesMe
    53 Posts 10 Posters 33.1k Views 9 Watching
    • JerryPJ Offline
      JerryP @kar1507
      @kar1507
      cen you post a picture of the screen???
      • K Offline
        kar1507
        @ashishtank
        That explains why I always had Authenticate there. I’ve added it now. Thank you very much.
        @JerryP
        JerryPJ 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @kar1507
          @kar1507 Nice. that is the same as over her white the electric car.
          Thanks for the screen view
            pyrophoenix
            First of all Thank you for this module. I followed the full setup and unfortunately I have no update.
            Here is my setup:
              module: 'MMM-MercedesMe',
              position: 'bottom_left',
              header: 'Mercedes Fuel',
                      client_id: '**********************************************',
                      client_secret: '**************************************************',
                      vehicleType: 'Petrol',
                  scope: 'mb:vehicle:mbdata:vehiclestatus offline_access',
                      vehicleId: 'W*****************************9',
                      displayStyle: 'twodial',
                      updateInterval: 300000,
                  debug: true,
                      maxRange: 520
            On the log I do have this error:
            [05.04.2021 23:33.58.329] [LOG] Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W**************9/containers/electricvehicle
            [05.04.2021 23:33.58.575] [LOG] 403 - Forbidden
            Despite it says electricvehicule the setup on MercedesMe Dev is exactly as per the instruction.
            I’m a bit lost at this point.
            Thank you in advance for any help!
              pyrophoenix
                ashishtank Module Developer @pyrophoenix
                @pyrophoenix can you please restart the mirror and check if it works ? did you login to get the token ?
                  pyrophoenix @ashishtank
                  Hi @ashishtank
                  Yes I did reboot and it ask to authenticate everytime that I reboot it. I have to click on it then it goes blank page and the picture I’ve sent appear
                    @pyrophoenix can you delete the tokens.json file in MercedesMe directory and then restart the mirror ? it should show you login button and then you should be able to login and get token. after that check if tokens.json file is created or not…
                    P 2 Replies Last reply Reply Quote 0
                      @ashishtank Thanks for your reply!
                      I think I was looking the finger instead of the sky…I found the issue but couldn’t resolve it. It request EV while I have a petrol (But my config as you saw earlier was correct). On the logs I have that part saying:
                      [07.04.2021 22:13.34.301] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1************9/containers/electricvehicle
                      Then I missed that part (That I thought was for another modules):
                      [07.04.2021 22:13.34.785] [LOG]   403 - Forbidden
                      On request it says:
                      [07.04.2021 21:53.39.767] [LOG]   Handle OAuth request
                      [07.04.2021 21:53.39.784] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=d***********eb&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=7********************************f
                      [07.04.2021 21:53.41.314] [LOG]   Handle OAuth callback
                      [07.04.2021 21:53.41.844] [LOG]   OAuth callback Success
                      Meaning that now the token is indeed good but it request EV status rather then the rangeliquid and tankvalue (as mentioned here: https://developer.mercedes-benz.com/products/fuel_status/docs). M’I missing something?
                        @ashishtank Just one thing that I saw…Step 7 has your Client ID and Secret uncovered. I highly recommend to blur it if it’s still an active account :/
                          @pyrophoenix Hi Looks like you found the issue for me :) the vehicle type right now i am checking is only Electric (default) and Diesel. I will improve the code to check for petrol as well but you can have a work around and can configure your vehicle type as 'diesel' and it will work as api is same for diesel and petrol !
                          getVehicleDataUrl: function (config) {
                            var vehicleStatus = 'electricvehicle';
                            switch (config.vehicleType.toLowerCase()) {
                              case 'diesel': <-----------------------------------------------------------------------------
                                vehicleStatus = 'fuelstatus';
                          About my sample client id and secret in guide they are fine as I do not have a Car :D and also that account and app are throw away account with out any real car linked to it.
                          Let me know if changing the config to diesel and restarting mirror solves the issue.
                            @ashishtank Thanks for the reply!
                            I have erased token and reboot it with Diesel…Still the same issue but this time it goes to the correct URL
                            [08.04.2021 13:38.22.939] [LOG]   Handle OAuth request
                            [08.04.2021 13:38.22.946] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=c****************4a&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=d*************************e
                            [08.04.2021 13:38.25.124] [INFO]  Newsfeed-Fetcher: Broadcasting 66 items.
                            [08.04.2021 13:38.26.049] [LOG]   Handle OAuth callback
                            [08.04.2021 13:38.26.982] [LOG]   OAuth callback Success
                            [08.04.2021 13:38.34.388] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1****************9/containers/fuelstatus
                            [08.04.2021 13:38.35.647] [LOG]   403 - Forbidden
                            It is still saying error 403
                              @pyrophoenix did you followed the step 3 correctly ? did you linked fuel status scope with app ? as shown in image below you should see
                              Fuel Status BYOCAR
                                pyrophoenix
                                Thanks! Great that YOU point it out! I cheated a bit and directly put the “fuel” on the URL as so
                                https://developer.mercedes-benz.com/products/fuel_status/get_access?pm=free
                                I just added it and I’ll try now.
                                  pyrophoenix
                                  Not working…But it seems that the Bearer is not generated properly. If I try the test curl provided by the Mercedes Dev, it does work…
                                    @pyrophoenix Can you delete the app in Mercedes dev portal and create new one with correct scope ? also delete tokens.json file and restart the mirror. I think it is some caching issue.
                                      @ashishtank Remove and did a brand new app on console. Removed tokens.json and reboot…Same problem
                                      There is one thing that is on your step (Right from step 1) saying:
                                      AUTH CALLBACK URL: http://localhost
                                      Where that needs to be introduced?
                                        pyrophoenix
                                        Details.PNG image url)
                                        A 2 Replies Last reply Reply Quote 0
                                          @pyrophoenix things looks correct, http://localhost:8080/MMM_MercedesMe/callback is important other localhost urls in callback are optional. I have sent you PM what we can do next.
                                            @pyrophoenix Let me know if changing the scope solves the issue. I will update the documentation accordingly.
                                            • 2 / 3
