    MMM-MercedesMe
    53 Posts 10 Posters 35.3k Views 9 Watching
      ashishtank Module Developer @kar1507
      @kar1507 do you have logs in console or from dev tools ?
      • K Offline
        kar1507 @ashishtank
        @ashishtank
        Hello.
        I set up my Magic Mirror again.
        I’ve been working on the project for 2 weeks.
        So I honestly don’t know where to find the exact logs.
        I also have the debug mode on but first have to see where I can find the log.
        Sorry, just start with the matter.
          sdetweil @kar1507
          @kar1507 if you start your mirror with pm2
          do pm2 status
          then pm2 logs --lines=100
          will show 100 lines of the logged info…
          same stuff that is displayed after npm start
          pm2 flush to clear the logs
          • K Offline
            kar1507
            Good Morning
            Thank You sdetweil
            Here my log:
            /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
            0|MagicMir | npm ERR! code ELIFECYCLE
            0|MagicMir | npm ERR! errno 1
            0|MagicMir | npm ERR! magicmirror@2.14.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            0|MagicMir | npm ERR! Exit status 1
            0|MagicMir | npm ERR! Failed at the magicmirror@2.14.0 start script.
            0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|MagicMir |
            0|MagicMir | npm ERR! A complete log of this run can be found in:
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-02-11T08_58_44_432Z-debug.log
            0|MagicMir | [11.02.2021 09:59.18.142] [WARN]  You're using a full whitelist configuration to allow for all IPs
            0|MagicMir | [11.02.2021 09:59.20.163] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
            0|MagicMir | [11.02.2021 09:59.18.193] [LOG]   Connecting socket for: MMM-MercedesMe
            0|MagicMir | [11.02.2021 09:59.18.195] [LOG]   Starting node_helper for Mercedes Me
            0|MagicMir | [11.02.2021 09:59.38.750] [LOG]   Init token from file./modules/MMM-MercedesMe/tokens.json
            0|MagicMir | [11.02.2021 09:59.38.764] [LOG]   Client id 2051c078-7e58-4758-a508-cabafe8d1317
            0|MagicMir | [11.02.2021 09:59.38.772] [LOG]   Current token is expired or does not exists
            0|MagicMir | [11.02.2021 09:59.38.945] [INFO]  Checking git for module: MMM-MercedesMe
            0|MagicMirror  | [11.02.2021 10:01.33.024] [LOG]
            0|MagicMirror  | Handle OAuth request
            0|MagicMirror  | [11.02.2021 10:01.33.036] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=2051c078-7e58-4758-a508-cabafe8d1317&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:fuelstatus&state=0ec4726f-662b-40d5-bb07-ad649bd085ec
            0|MagicMirror  | [11.02.2021 10:01.47.680] [LOG]
            0|MagicMirror  | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
            0|MagicMirror  | [11.02.2021 10:01.47.685] [LOG]
            0|MagicMirror  | [11.02.2021 10:01.47.715] [LOG]
            0|MagicMirror  | [11.02.2021 10:01.47.719] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
            0|MagicMirror  | [11.02.2021 10:02.07.183] [LOG]
            0|MagicMirror  | [11.02.2021 10:02.07.198] [LOG]
            0|MagicMirror  | [11.02.2021 10:02.07.233] [LOG]
            0|MagicMirror  | [11.02.2021 10:02.07.241] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
            • K Offline
              kar1507
              Hello.
              Thank you @ashishtank @sdetweil @JerryP
              It works now and the data is displayed.
              A JerryPJ 2 Replies Last reply Reply Quote 1
                @kar1507 Good to know that issues is solved, may be it was temporary issue from Mercedes Api, they have some downtime every now and then. Also I noticed that you have not included offline_access scope in config ? if you do not include that then refresh token will not be generated and thus you will need to re login again and again once the access token is expirers.
                • JerryPJ Offline
                  JerryP @kar1507
                  @kar1507
                  cen you post a picture of the screen???
                  • K Offline
                    kar1507
                    @ashishtank
                    That explains why I always had Authenticate there. I’ve added it now. Thank you very much.
                    @JerryP
                    JerryPJ 1 Reply Last reply Reply Quote 0
                    • JerryPJ Offline
                      JerryP @kar1507
                      @kar1507 Nice. that is the same as over her white the electric car.
                      Thanks for the screen view
                        pyrophoenix
                        First of all Thank you for this module. I followed the full setup and unfortunately I have no update.
                        Here is my setup:
                          module: 'MMM-MercedesMe',
                          position: 'bottom_left',
                          header: 'Mercedes Fuel',
                                  client_id: '**********************************************',
                                  client_secret: '**************************************************',
                                  vehicleType: 'Petrol',
                              scope: 'mb:vehicle:mbdata:vehiclestatus offline_access',
                                  vehicleId: 'W*****************************9',
                                  displayStyle: 'twodial',
                                  updateInterval: 300000,
                              debug: true,
                                  maxRange: 520
                        On the log I do have this error:
                        [05.04.2021 23:33.58.329] [LOG] Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W**************9/containers/electricvehicle
                        [05.04.2021 23:33.58.575] [LOG] 403 - Forbidden
                        Despite it says electricvehicule the setup on MercedesMe Dev is exactly as per the instruction.
                        I’m a bit lost at this point.
                        Thank you in advance for any help!
                          pyrophoenix
                            ashishtank Module Developer @pyrophoenix
                            @pyrophoenix can you please restart the mirror and check if it works ? did you login to get the token ?
                              pyrophoenix @ashishtank
                              Hi @ashishtank
                              Yes I did reboot and it ask to authenticate everytime that I reboot it. I have to click on it then it goes blank page and the picture I’ve sent appear
                                @pyrophoenix can you delete the tokens.json file in MercedesMe directory and then restart the mirror ? it should show you login button and then you should be able to login and get token. after that check if tokens.json file is created or not…
                                P 2 Replies Last reply Reply Quote 0
                                  @ashishtank Thanks for your reply!
                                  I think I was looking the finger instead of the sky…I found the issue but couldn’t resolve it. It request EV while I have a petrol (But my config as you saw earlier was correct). On the logs I have that part saying:
                                  [07.04.2021 22:13.34.301] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1************9/containers/electricvehicle
                                  Then I missed that part (That I thought was for another modules):
                                  [07.04.2021 22:13.34.785] [LOG]   403 - Forbidden
                                  On request it says:
                                  [07.04.2021 21:53.39.767] [LOG]   Handle OAuth request
                                  [07.04.2021 21:53.39.784] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=d***********eb&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=7********************************f
                                  [07.04.2021 21:53.41.314] [LOG]   Handle OAuth callback
                                  [07.04.2021 21:53.41.844] [LOG]   OAuth callback Success
                                  Meaning that now the token is indeed good but it request EV status rather then the rangeliquid and tankvalue (as mentioned here: https://developer.mercedes-benz.com/products/fuel_status/docs). M’I missing something?
                                    @ashishtank Just one thing that I saw…Step 7 has your Client ID and Secret uncovered. I highly recommend to blur it if it’s still an active account :/
                                      @pyrophoenix Hi Looks like you found the issue for me :) the vehicle type right now i am checking is only Electric (default) and Diesel. I will improve the code to check for petrol as well but you can have a work around and can configure your vehicle type as 'diesel' and it will work as api is same for diesel and petrol !
                                      getVehicleDataUrl: function (config) {
                                        var vehicleStatus = 'electricvehicle';
                                        switch (config.vehicleType.toLowerCase()) {
                                          case 'diesel': <-----------------------------------------------------------------------------
                                            vehicleStatus = 'fuelstatus';
                                      About my sample client id and secret in guide they are fine as I do not have a Car :D and also that account and app are throw away account with out any real car linked to it.
                                      Let me know if changing the config to diesel and restarting mirror solves the issue.
                                        @ashishtank Thanks for the reply!
                                        I have erased token and reboot it with Diesel…Still the same issue but this time it goes to the correct URL
                                        [08.04.2021 13:38.22.939] [LOG]   Handle OAuth request
                                        [08.04.2021 13:38.22.946] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=c****************4a&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=d*************************e
                                        [08.04.2021 13:38.25.124] [INFO]  Newsfeed-Fetcher: Broadcasting 66 items.
                                        [08.04.2021 13:38.26.049] [LOG]   Handle OAuth callback
                                        [08.04.2021 13:38.26.982] [LOG]   OAuth callback Success
                                        [08.04.2021 13:38.34.388] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1****************9/containers/fuelstatus
                                        [08.04.2021 13:38.35.647] [LOG]   403 - Forbidden
                                        It is still saying error 403
                                          @pyrophoenix did you followed the step 3 correctly ? did you linked fuel status scope with app ? as shown in image below you should see
                                          Fuel Status BYOCAR
                                            pyrophoenix
                                            Thanks! Great that YOU point it out! I cheated a bit and directly put the “fuel” on the URL as so
                                            https://developer.mercedes-benz.com/products/fuel_status/get_access?pm=free
                                            I just added it and I’ll try now.
                                            • 2 / 3
