    Problems With Weather
    41 Posts 6 Posters 15.2k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @brendan_c23
      @brendan_c23
      I don’t use the default weather modules but I loaded up the weather forecast module and it errors, stating:
      Failed to load resource: the server responded with a status of 401 (Unauthorized)
      weatherforecast.js:261 weatherforecast: Your AppID does not support long term forecasts.
      So, it looks like the appKey from open weather is the problem, or, the module is asking for data that is not available to holders of the free api.
      Run your mirror by using npm start dev and see if that is the error you are getting
        @brendan_c23
        Correction, the module loads eventually but with only one day of weather, today.
          @brendan_c23
          This is with your config entry:
            brendan_c23 @Mykle1
            @mykle1 Hourly forecast: unavailable
            Daily forecast: unavailable
            Calls per minute: 60
            3 hour forecast: 5 days
            It seems these are limits for the free API key I have now. Is there a way to tweak the code so it would be compatible? I tried the npm start dev, and got a couple errors popping up, will take picture and post on here
              brendan_c23 @brendan_c23
                @brendan_c23 Current Weather
                Minute Forecast 1 hour*
                Hourly Forecast 2 days*
                Daily Forecast 7 days*
                National Weather Alerts*
                Historical weather 5 days*
                Climatic Forecast 30 days
                Actually, 7 day forecast should be available with the free API from openweathermap.org
                  @brendan_c23
                  You trying to run the mirror from the wrong folder. ENOENT error.
                  Start the mirror from within the MagicMirror directory
                    brendan_c23
                    @mykle1 I am sorry Im a noob. How do I run the mirror from within the directory? cd MagicMirror?
                      @brendan_c23 said in Problems With Weather:
                      cd MagicMirror?
                      yes sir
                      B 2 Replies Last reply Reply Quote 0
                        brendan_c23 @Mykle1
                        • 4 / 5
