    Problems With Weather
    41 Posts 6 Posters 15.2k Views 6 Watching
      brendan_c23 @Mykle1
      @mykle1 Worked perfectly! Thank you! was just not sure where to find the units. Still having trouble to get the forecast displaying though. Any help on that?
      Mykle1M 3 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @brendan_c23
        @brendan_c23
        I don’t use the default weather modules but I loaded up the weather forecast module and it errors, stating:
        Failed to load resource: the server responded with a status of 401 (Unauthorized)
        weatherforecast.js:261 weatherforecast: Your AppID does not support long term forecasts.
        So, it looks like the appKey from open weather is the problem, or, the module is asking for data that is not available to holders of the free api.
        Run your mirror by using npm start dev and see if that is the error you are getting
          @brendan_c23
          Correction, the module loads eventually but with only one day of weather, today.
            @brendan_c23
            This is with your config entry:
              brendan_c23 @Mykle1
              @mykle1 Hourly forecast: unavailable
              Daily forecast: unavailable
              Calls per minute: 60
              3 hour forecast: 5 days
              It seems these are limits for the free API key I have now. Is there a way to tweak the code so it would be compatible? I tried the npm start dev, and got a couple errors popping up, will take picture and post on here
                brendan_c23 @brendan_c23
                  @brendan_c23 Current Weather
                  Minute Forecast 1 hour*
                  Hourly Forecast 2 days*
                  Daily Forecast 7 days*
                  National Weather Alerts*
                  Historical weather 5 days*
                  Climatic Forecast 30 days
                  Actually, 7 day forecast should be available with the free API from openweathermap.org
                    @brendan_c23
                    You trying to run the mirror from the wrong folder. ENOENT error.
                    Start the mirror from within the MagicMirror directory
                      brendan_c23
                      @mykle1 I am sorry Im a noob. How do I run the mirror from within the directory? cd MagicMirror?
                        @brendan_c23 said in Problems With Weather:
                        cd MagicMirror?
                        yes sir
                        • 1 / 5
