    Problems With Weather
    41 Posts 6 Posters 17.0k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @brendan_c23
      @brendan_c23
      You trying to run the mirror from the wrong folder. ENOENT error.
      Start the mirror from within the MagicMirror directory
        brendan_c23
        @mykle1 I am sorry Im a noob. How do I run the mirror from within the directory? cd MagicMirror?
          @brendan_c23 said in Problems With Weather:
          cd MagicMirror?
          yes sir
            brendan_c23 @Mykle1
              @brendan_c23
              Well, it says right in the error message that your appid is not set. Hmmm
                brendan_c23 @Mykle1
                  @brendan_c23
                  Something else is using port 8080. Most commonly it is because you have more than one instance of MM running at the same time. Or, there is another program on your pi using the same port.
                    brendan_c23 @Mykle1
                    @mykle1 Is it because I am using the same APPid for both weather modules? I have triple checked that I have the correct appid that was also working for the current weather. IMG_3983.JPG
                      No, you can use the appid twice. However, MM can not share port 8080
                        brendan_c23 @Mykle1
                        @mykle1 How could I try fixing this?
                        Mykle1M B 3 Replies Last reply Reply Quote 0
                          @brendan_c23
                          try running pm2 status in the terminal (I think that’s the command) and post the result here please.
                          Don’t post a picture. Copy the terminal output and paste it into your reply.
                          Also, do you have any other programs running on the Pi besides Magic Mirror?
                            brendan_c23 @brendan_c23
                              @brendan_c23
                              output should look like this
                              pi@Pi3:~ $ pm2 status
                              │ Name │ mode │ status │ ↺ │ cpu │ memory   │
                              │ mm   │ fork │ online │ 0 │ 0%  │ 1.3 MB   │
                               Use `pm2 show <id|name>` to get more details about an app
                              pi@Pi3:~ $
                                brendan_c23 @Mykle1
                                @mykle1 pi@raspberrypi:~ $ pm2 status
                                │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                                │ 0 │ MagicMirror │ fork │ 6 │ online │ 0% │ 2.6mb │
                                pi@raspberrypi:~ $
                                  brendan_c23 @Mykle1
                                  @mykle1 I should not have any other programs running besides the magic mirror as it is the only one I have installed , but not totally sure if there are any default programs already on there.
                                    @brendan_c23
                                    ok,. so try pm2 stop MagicMirror
                                    then pm2 start MagicMirror
                                      brendan_c23 @Mykle1
                                      @mykle1 pi@raspberrypi:~ $ pm2 stop MagicMirror
                                      [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                      [PM2] MagicMirror ✓
                                      │ 0 │ MagicMirror │ fork │ 6 │ stopped │ 0% │ 0b │
                                      pi@raspberrypi:~ $ pm2 start MagicMirror
                                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                                      [PM2] MagicMirror ✓
                                      [PM2] Process successfully started
                                      │ 0 │ MagicMirror │ fork │ 6 │ online │ 0% │ 2.4mb │
                                      pi@raspberrypi:~ $
                                      Still no luck displaying forecast, thank you again for bearing with me this long
                                        @brendan_c23
                                        Were there any errors when MM launched?
                                          @brendan_c23
                                          MagicMirror should have launched when you issued the pm2 start MagicMirror command
                                            brendan_c23 @Mykle1
                                            @mykle1 No errors and yes MM launched, everything is displaying but the forecast
