    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 687.7k Views 57 Watching
    • C Offline
      chris1971 @sdetweil
      @sdetweil Does that mean I have to stopp pm before I make changes in the config?
      Module is still not loading…
      When I remove the script for google maps from the config.js the weather module is working. When I place the script in the config.js again, the weather module is not loading.
        sdetweil @chris1971
        @chris1971 yes, when u make any change, you should stop MM and then then restart it…
        as I said before, some modules impact others…
        I fixed a similar problem in OpenWeatherMapForecast as the author was not updating it anymore
        this is my fork with the fix https://github.com/sdetweil/MMM-OpenWeatherMapForecast
        I would look at the messages
        pm2 stop all
        pm2 flush
        pm2 start all
        wait
        pm2 logs --lines=100
        or, not use pm2
        pm2 stop all
        cd ~/MagicMirror
        npm start >somefile.txt 2>&1
        wait
        ctrl-c to stop MM (in the window where you did npm start )
        then examine the contents of somefile.txt to see if there was any error that might causing the problem
        you can also look in the MagicMirror developers window to see if there is a problem there
        ctrl-shift-i on the running MM screen
        select the console tab
        and put weath in the filter field
        this will reduce the output to modules with weath in their name
        looking for any content in red
        • C Offline
          chris1971 @sdetweil
          @sdetweil lot of stuff…
          pi@raspberrypi:~ $ pm2 logs --lines=100
          [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
          /home/pi/.pm2/pm2.log last 100 lines:
          PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] online
          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
          0|MagicMir | [31.03.2023 16:08.20.333] [WARN] You’re using a full whitelist configuration to allow for all IPs
          0|MagicMir | MESA-LOADER: failed to retrieve device information
          0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160823.980369:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
          0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160825.475337:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
          0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160827.345249:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
          0|MagicMir | [2512:0331/160829.375127:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
          0|MagicMir |
          0|MagicMir | > magicmirror@2.22.0 start
          0|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
          0|MagicMir |
          0|MagicMir | [31.03.2023 16:08.18.855] [LOG] Starting MagicMirror: v2.22.0
          0|MagicMir | [31.03.2023 16:08.18.868] [LOG] Loading config …
          I read something about the GPU process in the forum - could this infuence the system?
            sdetweil @chris1971
            @chris1971 possibly
            for pm2 add the
            export ELECTRON_DISABLE_GPU=1
            to the ~/MagicMirror/installers/mm.sh
            before the line
            DISPLAY=:0 npm start
            for using npm start
            just do it once in the terminal window
            • C Offline
              chris1971 @sdetweil
              @sdetweil still not loading…
              [31.03.2023 16:29.04.053] [LOG] Starting MagicMirror: v2.22.0
              [31.03.2023 16:29.04.077] [LOG] Loading config …
              [31.03.2023 16:29.04.113] [LOG] Loading module helpers …
              [31.03.2023 16:29.04.120] [LOG] No helper found for module: alert.
              [31.03.2023 16:29.04.191] [LOG] Initializing new module helper …
              [31.03.2023 16:29.04.194] [LOG] Module helper loaded: updatenotification
              [31.03.2023 16:29.04.196] [LOG] No helper found for module: clock.
              [31.03.2023 16:29.04.591] [LOG] Initializing new module helper …
              [31.03.2023 16:29.04.592] [LOG] Module helper loaded: MMM-OpenWeatherForecast
              [31.03.2023 16:29.05.736] [LOG] Initializing new module helper …
              [31.03.2023 16:29.05.740] [LOG] Module helper loaded: calendar
              [31.03.2023 16:29.05.754] [LOG] No helper found for module: MMM-TextClock.
              [31.03.2023 16:29.06.143] [LOG] Initializing new module helper …
              [31.03.2023 16:29.06.150] [LOG] Module helper loaded: newsfeed
              [31.03.2023 16:29.06.155] [LOG] No helper found for module: MMM-RAIN-MAP.
              [31.03.2023 16:29.06.170] [LOG] Initializing new module helper …
              [31.03.2023 16:29.06.172] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
              [31.03.2023 16:29.06.173] [LOG] All module helpers loaded.
              [31.03.2023 16:29.06.803] [LOG] Starting server on port 8080 …
              [31.03.2023 16:29.06.828] [WARN] You’re using a full whitelist configuration to allow for all IPs
              [31.03.2023 16:29.06.884] [ERROR] Whoops! There was an uncaught exception…
              [31.03.2023 16:29.06.900] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (node:net:1432:16)
              at listenInCluster (node:net:1480:12)
              at doListen (node:net:1629:7)
              at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
              code: ‘EADDRINUSE’,
              errno: -98,
              syscall: ‘listen’,
              address: ‘0.0.0.0’,
              port: 8080
              [31.03.2023 16:29.06.901] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [31.03.2023 16:29.06.902] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [31.03.2023 16:29.08.680] [LOG] Launching application.
              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162912.978009:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162914.498526:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162915.779583:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
              [31.03.2023 16:29.37.588] [LOG] Shutting down server…
              [31.03.2023 16:29.37.595] [LOG] Stopping module helper: updatenotification
              [31.03.2023 16:29.37.596] [LOG] Stopping module helper: MMM-OpenWeatherForecast
              [31.03.2023 16:29.37.596] [LOG] Stopping module helper: calendar
              [31.03.2023 16:29.37.597] [LOG] Stopping module helper: newsfeed
              [31.03.2023 16:29.37.597] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
                sdetweil @chris1971
                @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                did u do the pm2 stop all?
                did you use any install instructions before my script? the manual install describes how to create a service to auto start MM
                • C Offline
                  chris1971 @sdetweil
                  yes - ich changed the mm.sh after stop all
                  my method for installation:
                  • format SD card
                  • install Bullseye
                  • install sudo apt-get install xrdp (to get a remote connection via remote desktop)
                  • install your scripts including screensaver/ pm2
                  • install the modules
                    it worked once … I do not understand what changed after a restart…
                    sdetweil @chris1971
                    @chris1971 and u checked the pm2 status
                    before doing npm start ?
                    you don’t reboot after pm2 stop all, as t will restart MM on boot (its job)
                    • C Offline
                      chris1971 @sdetweil
                      @sdetweil this is the pm2 status
                      pi@raspberrypi:~/MagicMirror $ pm2 status
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.3mb │
                      with npm start I only have a black screen in the terminal - I can see the conten in the browser with http://192.168.178.35:8080/
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @chris1971
                        @chris1971 pm2 stop all
                        then cd ~/MagicMirror
                        npm start
                        only can have ONE instance running at a time on the same config.js port: setting
                          sdetweil @chris1971
                          @chris1971 yes, you have another instance running , so this one will fail
                            sdetweil @chris1971
                            you are looking at the one running under pm2
                            • C Offline
                              chris1971 @sdetweil
                              sdetweil 5 minutes ago
                              npm start
                              ahhh… ok: with this I am able to see the scree in the terminal - but the weather module is still not loading in the terminal
                              Errors like before:
                              [31.03.2023 17:19.15.233] [LOG] Launching application.
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171918.392802:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171919.478457:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171920.679631:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              [2509:0331/171921.424506:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                              [31.03.2023 17:19.25.235] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/c.euro%40gmx.de/private-8dd63e4cddfec3349/basic.ics - Interval: 50000
                              [31.03.2023 17:19.25.774] [LOG] Create new newsfetcher for url: http://www.radiomuelheim.de/lokalnachrichten.xml - Interval: 300000
                              [31.03.2023 17:19.25.793] [LOG] Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                              [31.03.2023 17:19.25.813] [LOG] Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                              have to go out for a beer now…:dizzy_face:
                                sdetweil @chris1971
                                @chris1971 u have to enter the
                                EVERY time you open a new terminal window
                                so, then i’d look in the MM screen developers window as previously described
                                • C Offline
                                  chris1971 @sdetweil
                                  @sdetweil I placed the “export ELECTRON_DISABLE_GPU=1” in the install.
                                  Where do I have to place the “export ELECTRON_DISABLE_GPU=1” in the terminal window?
                                  Info from console (red):
                                  >Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                                  at script.onload (MMM-GoogleMapsTraffic.js:77:52)
                                  MMM-OpenWeatherForecast.js:685 Uncaught (in promise) TypeError: console.log is not a function
                                  at Class.addIcon (MMM-OpenWeatherForecast.js:685:13)
                                  at Class.processWeatherData (MMM-OpenWeatherForecast.js:370:61)
                                  at Class.socketNotificationReceived (MMM-OpenWeatherForecast.js:282:40)
                                  at module.js:245:9
                                  at Socket. (socketclient.js:38:4)
                                  at Emitter.emit (index.mjs:136:20)
                                  at Socket.emitEvent (socket.js:498:20)
                                  at Socket.onevent (socket.js:485:18)
                                  at MMSocket.socket.onevent (socketclient.js:32:11)
                                  at Socket.onpacket (socket.js:455:22)
                                  js?key=cccc:221 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
                                  js?key=uuuuu:217 Google Maps JavaScript API has been loaded directly without a callback. This is not supported and can lead to race conditions and suboptimal performance. For supported loading patterns please see https://goo.gle/js-api-loading
                                  MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                                    sdetweil @chris1971
                                    you just enter that command string and hit enter
                                      sdetweil @chris1971
                                      I haven’t seen that one before
                                      I xxx’ed out your api key in the debug info
                                      • C Offline
                                        chris1971 @sdetweil
                                        @sdetweil thanks for xxx
                                        What is your recommendation? Delete maps and new install?
                                        Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
                                          sdetweil @chris1971
                                          @chris1971 delete pm2, sure, see the
                                          pm2 --help
                                          output
                                          no idea why u are having trouble
                                          try this
                                          instead of npm start
                                          do
                                          npm run server
                                          then access from the remote and see what happens
                                          • C Offline
                                            chris1971 @sdetweil
                                            npm run server - no success
                                            I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
                                            Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
