    MMM - NewsFeed Ticker Hangs
    40 Posts 4 Posters 15.0k Views 4 Watching
      Matthewlawson3 @sdetweil
      @sdetweil Okay so the reason it hangs and doesn’t go to other sources is because of what exactly? Sorry just saw this and trying to get up to speed.
      I added the max news items where you said I think if I understand correctly (see config file below). I also changed the number to 0 inside the MMM-NewsFeedTicker.js.
      Where is the fetcher.js? Can’t find that file.
      The module keeps repeating NYT and USA Today and doesn’t move on to BBC or Ars Technica.
      	disabled: false,
      	module: "MMM-NewsFeedTicker",
      	position: "bottom_bar",
      	//classes: "day_scheduler",
      		maxNewsItems: 0,
      	    feeds: [
      			title: "New York Times",
      			url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
      			customLogo: "NYT_logo_rss_250x40.png"
      			title: "USA Today",
      			url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
      			customLogo: "RSS_Syndication_Logo-USATN.png"
      			title: "BBC World News",
      			url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
      			customLogo: "bbc_news_120x60.gif"
      			title: "Ars Technica",
      			url: "http://feeds.arstechnica.com/arstechnica/technology-lab",
      			customLogo: "arstechnica.jpg"
      Mykle1M S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @Matthewlawson3
        @matthewlawson3
        Try this:
        Under the maxNewsItems that you just added to your config entry, add this
        updateInterval: 10 * 60 * 1000,
        The default is 1 minute, which effectively resets the module back to the beginning of the feeds. This will give it 10 minutes to display the feeds without resetting. Assuming this will work, adjust the time accordingly.
          Matthewlawson3
          @mykle1 Just added it. It brought the ticker to a crawl across the screen. Super slow.
            sdetweil @Matthewlawson3
            @matthewlawson3 never edit the module source file.use config.js to adjust the parma
            I loaded the module u referenced, and fetcher.js is in that folder
            no idea if it hangs yet. hasn’t for me.
              @sdetweil Ok I made the changes in the fetcher file hopefully. I really am kinda lost though as to what we are trying to do exactly. My main concern is that it goes to all 4 of the sources listed. NYT, USA Today, BBC, and Ars Technica. I haven’t seen Ars Technica at all.
              I may just give up and find another good news module.
                @matthewlawson3
                the modules collects all the entries and makes a big list, and then the module sorts them by published date.
                there could be over 300 entries… each takes 10 seconds, 3000 seconds is 5 hours,
                but the reload interval is 60 minutes, so it will wipe out the list and start over…
                  @sdetweil Okay. So looking at it now, I added in Fox News and took out Ars Technica. It shows me Fox News, NYT, USA Today, but doesn’t show BBC which is still in the feeds area.
                  Also, it seems to reset and replay a headline before it finishes it the first time.
                    @matthewlawson3 not my module, just trying to help out.
                      @sdetweil I understand. Sorry.
                      Any other news modules you recommend? May try another.
                        @matthewlawson3 no idea… I just use the default, only cause its there…
                        • 3 / 4
