    MM Install Error
    3 Posts 2 Posters 674 Views 2 Watching
    • E
      etatsu
      Hi!
      I’m trying to install MM on a RP 4 . I followed the Manual Installation steps , however, from step two on scripts indicate no file or directory. This is all new to me so your advice will be much appreciated!
      pi@raspberrypi:~ $ https://github.com/MichMich/MagicMirror
      bash: https://github.com/MichMich/MagicMirror: No such file or directory
      pi@raspberrypi:~ $ cd MagicMirror/
      bash: cd: MagicMirror/: No such file or directory
      pi@raspberrypi:~ $ npm install
      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      up to date in 0.797s
      found 0 vulnerabilities
      pi@raspberrypi:~ $ cp config/config.js.sample config/config.js
      cp: cannot stat 'config/config.js.sample': No such file or directory
      pi@raspberrypi:~ $ npm run start
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! path /home/pi/package.json
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2021-03-26T07_35_06_236Z-debug.log
      pi@raspberrypi:~ $
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @etatsu
        @etatsu you have the first command wrong.
        You need to put in
        git clone https://github.com/MichMich/MagicMirror
        And please PLEASE take care when the system throws errors at you :-) Basically all answers you got from the system on the way told you something’s wrong.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • E
          etatsu
          Thank you for your help!
