v2.15.0
https://github.com/MichMich/MagicMirror/releases/tag/v2.15.0
[2.15.0] - 2021-04-01
Special thanks to the following contributors: @EdgardosReis, @MystaraTheGreat, @TheDuffman85, @ashishtank, @buxxi, @codac, @fewieden, @khassel, @klaernie, @qu1que, @rejas, @sdetweil & @thomasrockhu.
ℹ️ Note: This update uses new dependencies. Please update using the following command:
git pull && npm install.Added
- Added Galician language.
- Added GitHub workflows for automated testing and changelog enforcement.
- Added CodeCov badge to Readme.
- Added CURRENTWEATHER_TYPE notification to currentweather and weather module, use it in compliments module.
- Added
start:devcommand to the npm scripts for starting electron with devTools open. - Added logging when using deprecated modules weatherforecast or currentweather.
- Added Portuguese translations for “MODULE_CONFIG_CHANGED” and “PRECIP”.
- Respect parameter ColoredSymbolOnly also for custom events.
- Added a new parameter to hide time portion on relative times.
module.showhas now the option for a callback on error.- Added locale to sample config file.
- Added support for self-signed certificates for the default calendar module (#466).
- Added hiddenOnStartup flag to module config (#2475).
Updated
- Updated markdown files for github.
- Cleaned up old code on server side.
- Convert
-0to0when displaying temperature. - Code cleanup for FEELS like and added {DEGREE} placeholder for FEELSLIKE for each language.
- Converted newsfeed module to use templates.
- Updated documentation and help screen about invalid config files.
- Moving weather provider specific code and configuration into each provider and making hourly part of the interface.
- Bump electron to v11 and enable contextIsolation.
- Don’t update the DOM when a module is not displayed.
- Cleaned up jsdoc and tests.
- Exposed logger as node module for easier access for 3rd party modules.
- Replaced deprecated
requestpackage withnode-fetchanddigest-fetch. - Refactored calendar fetcher.
- Cleaned up newsfeed module.
- Cleaned up translations and translator code.
Removed
- Removed danger.js library.
- Removed
icalwhich was substituted bynode-icalin releasev2.13.0. Module developers must install this dependency themselves in the module folder if needed. - Removed valid-url library.
Fixed
- Added default log levels to stop calendar log spamming.
- Fix socket.io cors errors, see breaking change since socket.io v3.
- Fix Issue with weather forecast icons due to fixed day start and end time (#2221).
- Fix empty directory for each module’s main javascript file in the inspector.
- Fix Issue with weather forecast icons unit tests with different timezones (#2221).
- Fix issue with unencoded characters in translated strings when using nunjuck template (
Loading …as an example). - Fix socket.io backward compatibility with socket v2 clients.
- Fix 3rd party module language loading if language is English.
- Fix e2e tests after spectron update.
- Fix updatenotification creating zombie processes by setting a timeout for the git process.
- Fix weather module openweathermap not loading if lat and lon set without onecall.
- Fix calendar daylight savings offset calculation if recurring start date before 2007.
- Fix calendar time/date adjustment when time with GMT offset is different day (#2488).
- Fix calendar daylight savings offset calculation if recurring FULL DAY start date before 2007 (#2483).
- Fix newsreaders template, for wrong test for nowrap in 2 places (should be if not).
use the scripted upgrade if u have any additional modules…
already seen requirement for npm rebuild or reinstall as a few have electron version dependencies (binaries) of THEIR dependencies
also note that valid-url has been removed, and at least two modules fail for this dependency
workaround
cd ~/MagicMirror npm install valid-url
