    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 463.3k Views 31 Watching
      sdetweil @Alyx
      @alyx the pi address changed (like powered off overnight and the ip lease expired
      I set fixed (reservation) addresses for all my pi devices in my network router to avoid this problem
      only way to fix is to delete and rediscover
      alexa.amazon.com
      smarthome tab
      devices
      at the bottom is forget all
      (or u can delete them 1 by 1)
        Alyx @sdetweil
        @sdetweil I did delete and rediscover but the thing is they arent showing up in the discovery now lol
          sdetweil @Alyx
          @alyx i delete, restart MM or reboot and then rediscover
          its finicky for sure… and some newer alexa devices seem not to support the old wmeo plugs like they used to…
          new show will not discover them, but older echo will
            Alyx @sdetweil
            @sdetweil Ive rebooted the machine 3 times at this point ahah, I have an echo3 would that be considered new? I know the 4th gen is the latest
              Alyx @Alyx
              @alyx ok I found the issue, I commented out all the options in alexa and then ran them individually and etc.
              Turns out the notification/ command and devices options werent configured correctly by the conf generator. after commenting those out I can now find them on alexa
                sdetweil @Dinschal
                @dinschal I have fixes for all the issues…
                in my module folder go
                git pull
                rm -rf node_modules
                git checkout new
                npm install
                give it a whirl… let me know
                  Dinschal @sdetweil
                  @sdetweil thanks sam… i will try it later… my frame has to dry :D first coat :D
                    Dinschal @sdetweil
                    @sdetweil Hi Sam i tried it again and the size of the analog clock wont change, same if i insert UTC+1 into the timezone… else looks pretty good…
                    thanks a lot ;)
                      sdetweil @Dinschal
                      @dinschal can u show me the generated config.js for clock? (just that module)
                      it changes the value in config.js when I change it in the form…
                      and send me the debug output again
                        Dinschal @sdetweil
                        @sdetweil oh no not the debug output again :D
                        give me just one second ;)
                          Dinschal @sdetweil
                          @sdetweil there is no debug: true in the config anymore :( can i insert it myself?
                          i tried it, but it stopped here
                            sdetweil @Dinschal
                            @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                            i debugged the clock module
                            UTC works
                            UTC +1 doesn’t
                            UTC -1 doesn’t
                            so I am not sure what it wants
                            Etc/UTC+1 doesn’t
                              sdetweil @Dinschal
                              @dinschal
                              make sure there is a comma on the line before where u added debug:true to my module
                                Dinschal @sdetweil
                                @sdetweil in germany we have summertime and wintertime… so we have utc and utc +1 :D
                                  Dinschal @sdetweil
                                  @sdetweil i did it this way…
                                    sdetweil @Dinschal
                                    yes, understand… the clock module should auto adjust…
                                    we just changed to std time last sunday and the clock adjusted… actually , the system changed reported time
                                    but I was saying I debugged using the timeZone option in config.js for clock, and cannot get any option other than ‘UTC’
                                    to work…
                                    I don’t understand what string it expects
                                    it has a time object and does
                                    time_object.tz(config.timeZone)
                                    to force the time to a particular timezone… except only UTC works for me.
                                      sdetweil @Dinschal
                                      @dinschal yes, looks good
                                      what does the debug output say?
                                        Dinschal @sdetweil
                                        @sdetweil the output stopped @calendar-fetcher: Broadcasting 10 events
                                          sdetweil @Dinschal
                                          @dinschal yes,… then u have to press save on the form…
                                            Dinschal @sdetweil
                                            @sdetweil i send it
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
