    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      sdetweil @Alyx
      @alyx ok, the crash is because u have a bad position for selfieshoot in config.js
      	module: "MMM-Selfieshot",
          position: "bottom",
      bottom is not valid
      https://docs.magicmirror.builders/modules/configuration.html#example
      separate lines are my addition to the view
      The location of the module in which the module will be loaded. Possible values are
      top_bar,
      top_left,
      top_center,
      top_right,
      upper_third,
      middle_center,
      lower_third,
      bottom_left,
      bottom_center,
      bottom_right,
      bottom_bar,
      fullscreen_above, and
      fullscreen_below.
      S A 2 Replies Last reply
        I opened issue to document changes to protect against crashing
        https://github.com/sdetweil/MMM-Config/issues/31
        • A
          Alyx @sdetweil
          @sdetweil OK back working now with that thanks! Although the conf for my pm2 seems to be not working anymore, I think I saw a similar issue somewhere in the comments here?
          Also I cant get the conf page anymore cause it can no longer get /modules/MMM-Config/review
            sdetweil @Alyx
            @alyx said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            eh?? what conf for pm2? where?
            pm2 setup is done once at install (if you use my script and it just points to the ~/MagicMirror/installers/mm.sh
            eh??
            http://localhost:8080/modules/MMM-Config/review
            (the MM config says localhost, SO the url MUST be localhost to match…
            anything else
            (ip or name)
            will fail
            A 1 Reply Last reply
            • A
              Alyx @sdetweil
              @sdetweil Before I was able to connect my alexa as a smart device with pm2 but now its not showing at all on alexa is what i mean.
              Yep that the link I use but I get the the home page and its the same blank interface as before with no modules tab or anything? Like I just used it to make the latest conf file so I know it works some how haha
              • A
                Alyx @Alyx
                @alyx ok screw that its working now all of a sudden ahaha
                The alexa thing still isnt working tho
                  sdetweil @Alyx
                  @alyx i;m not sure what u mean by the alexaControl problem
                  u set it up once and then do Alexa Discover Devices.
                  they are there forever …(until u manually delete them)
                  now… IF the machine IP changes (like across a reboot)
                  then the ip address that alexa saved is no longer valid and alexa can’t find them
                  it does NOT save dns NAME, only IP address.
                  • A
                    Alyx @sdetweil
                    Yes thats what I mean I haven’t changed anything like that although. I just used the script and the generated config file. It seems alexa can no longer find the devices and is displaying them as offline
                      sdetweil @Alyx
                      @alyx the pi address changed (like powered off overnight and the ip lease expired
                      I set fixed (reservation) addresses for all my pi devices in my network router to avoid this problem
                      only way to fix is to delete and rediscover
                      alexa.amazon.com
                      smarthome tab
                      devices
                      at the bottom is forget all
                      (or u can delete them 1 by 1)
                      • A
                        Alyx @sdetweil
                        @sdetweil I did delete and rediscover but the thing is they arent showing up in the discovery now lol
                          sdetweil @Alyx
                          @alyx i delete, restart MM or reboot and then rediscover
                          its finicky for sure… and some newer alexa devices seem not to support the old wmeo plugs like they used to…
                          new show will not discover them, but older echo will
                          • A
                            Alyx @sdetweil
                            @sdetweil Ive rebooted the machine 3 times at this point ahah, I have an echo3 would that be considered new? I know the 4th gen is the latest
                            • A
                              Alyx @Alyx
                              @alyx ok I found the issue, I commented out all the options in alexa and then ran them individually and etc.
                              Turns out the notification/ command and devices options werent configured correctly by the conf generator. after commenting those out I can now find them on alexa
                                sdetweil @Dinschal
                                @dinschal I have fixes for all the issues…
                                in my module folder go
                                git pull
                                rm -rf node_modules
                                git checkout new
                                npm install
                                give it a whirl… let me know
                                D 2 Replies Last reply
                                  Dinschal @sdetweil
                                  @sdetweil thanks sam… i will try it later… my frame has to dry :D first coat :D
                                    Dinschal @sdetweil
                                    @sdetweil Hi Sam i tried it again and the size of the analog clock wont change, same if i insert UTC+1 into the timezone… else looks pretty good…
                                    thanks a lot ;)
                                    S 2 Replies Last reply
                                      sdetweil @Dinschal
                                      @dinschal can u show me the generated config.js for clock? (just that module)
                                      it changes the value in config.js when I change it in the form…
                                      and send me the debug output again
                                        Dinschal @sdetweil
                                        @sdetweil oh no not the debug output again :D
                                        give me just one second ;)
                                          Dinschal @sdetweil
                                          @sdetweil there is no debug: true in the config anymore :( can i insert it myself?
                                          i tried it, but it stopped here
                                            sdetweil @Dinschal
                                            @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                            i debugged the clock module
                                            UTC works
                                            UTC +1 doesn’t
                                            UTC -1 doesn’t
                                            so I am not sure what it wants
                                            Etc/UTC+1 doesn’t
                                            D 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
