    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      sdetweil @Alyx
      @alyx under the submit button two messages are written
      Your Configuration has been submitted
      and
      config.js created successfully
      • A
        Alyx @sdetweil
        Did the debug what folder does it go to? I have the somefile ready also
        As for the messages I get the first part but not the second saying its created
          sdetweil @Alyx
          @alyx debug is set in config.js for my module
          the somefile is the debug output from save
          also send the config.js and the defaulys.js from my module folder.
          the .js files will have to be renamed to .txt
          as .js files cannot be sent as attachments
          my email is my same userid at gmail
          lack of the second message means some content formatting issue
          • A
            Alyx @sdetweil
            @sdetweil Sent over there cheers
              sdetweil @Alyx
              @alyx sent message back. need the rest of debug
              • A
                Alyx @sdetweil
                @sdetweil sent back over
                  sdetweil @Alyx
                  @alyx yes… saw. was at car dealer for oil change… just got back…
                  • A
                    Alyx @sdetweil
                    @sdetweil Ah no worries was out for some materials to build the mirror frame myself haha
                      sdetweil @Alyx
                      @alyx ok, the crash is because u have a bad position for selfieshoot in config.js
                      	module: "MMM-Selfieshot",
                          position: "bottom",
                      bottom is not valid
                      https://docs.magicmirror.builders/modules/configuration.html#example
                      separate lines are my addition to the view
                      The location of the module in which the module will be loaded. Possible values are
                      top_bar,
                      top_left,
                      top_center,
                      top_right,
                      upper_third,
                      middle_center,
                      lower_third,
                      bottom_left,
                      bottom_center,
                      bottom_right,
                      bottom_bar,
                      fullscreen_above, and
                      fullscreen_below.
                      S A 2 Replies Last reply Reply Quote 0
                        I opened issue to document changes to protect against crashing
                        https://github.com/sdetweil/MMM-Config/issues/31
                        • A
                          Alyx @sdetweil
                          @sdetweil OK back working now with that thanks! Although the conf for my pm2 seems to be not working anymore, I think I saw a similar issue somewhere in the comments here?
                          Also I cant get the conf page anymore cause it can no longer get /modules/MMM-Config/review
                            sdetweil @Alyx
                            @alyx said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                            eh?? what conf for pm2? where?
                            pm2 setup is done once at install (if you use my script and it just points to the ~/MagicMirror/installers/mm.sh
                            eh??
                            http://localhost:8080/modules/MMM-Config/review
                            (the MM config says localhost, SO the url MUST be localhost to match…
                            anything else
                            (ip or name)
                            will fail
                            • A
                              Alyx @sdetweil
                              @sdetweil Before I was able to connect my alexa as a smart device with pm2 but now its not showing at all on alexa is what i mean.
                              Yep that the link I use but I get the the home page and its the same blank interface as before with no modules tab or anything? Like I just used it to make the latest conf file so I know it works some how haha
                              • A
                                Alyx @Alyx
                                @alyx ok screw that its working now all of a sudden ahaha
                                The alexa thing still isnt working tho
                                  sdetweil @Alyx
                                  @alyx i;m not sure what u mean by the alexaControl problem
                                  u set it up once and then do Alexa Discover Devices.
                                  they are there forever …(until u manually delete them)
                                  now… IF the machine IP changes (like across a reboot)
                                  then the ip address that alexa saved is no longer valid and alexa can’t find them
                                  it does NOT save dns NAME, only IP address.
                                  • A
                                    Alyx @sdetweil
                                    Yes thats what I mean I haven’t changed anything like that although. I just used the script and the generated config file. It seems alexa can no longer find the devices and is displaying them as offline
                                      sdetweil @Alyx
                                      @alyx the pi address changed (like powered off overnight and the ip lease expired
                                      I set fixed (reservation) addresses for all my pi devices in my network router to avoid this problem
                                      only way to fix is to delete and rediscover
                                      alexa.amazon.com
                                      smarthome tab
                                      devices
                                      at the bottom is forget all
                                      (or u can delete them 1 by 1)
                                      • A
                                        Alyx @sdetweil
                                        @sdetweil I did delete and rediscover but the thing is they arent showing up in the discovery now lol
                                          sdetweil @Alyx
                                          @alyx i delete, restart MM or reboot and then rediscover
                                          its finicky for sure… and some newer alexa devices seem not to support the old wmeo plugs like they used to…
                                          new show will not discover them, but older echo will
                                          • A
                                            Alyx @sdetweil
                                            @sdetweil Ive rebooted the machine 3 times at this point ahah, I have an echo3 would that be considered new? I know the 4th gen is the latest
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
