    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • A
      Alyx @sdetweil
      @sdetweil Sent over there cheers
        sdetweil @Alyx
        @alyx sent message back. need the rest of debug
        A 1 Reply Last reply
        • A
          Alyx @sdetweil
          @sdetweil sent back over
            sdetweil @Alyx
            @alyx yes… saw. was at car dealer for oil change… just got back…
            • A
              Alyx @sdetweil
              @sdetweil Ah no worries was out for some materials to build the mirror frame myself haha
                sdetweil @Alyx
                @alyx ok, the crash is because u have a bad position for selfieshoot in config.js
                	module: "MMM-Selfieshot",
                    position: "bottom",
                bottom is not valid
                https://docs.magicmirror.builders/modules/configuration.html#example
                separate lines are my addition to the view
                The location of the module in which the module will be loaded. Possible values are
                top_bar,
                top_left,
                top_center,
                top_right,
                upper_third,
                middle_center,
                lower_third,
                bottom_left,
                bottom_center,
                bottom_right,
                bottom_bar,
                fullscreen_above, and
                fullscreen_below.
                S A 2 Replies Last reply
                  I opened issue to document changes to protect against crashing
                  https://github.com/sdetweil/MMM-Config/issues/31
                  • A
                    Alyx @sdetweil
                    @sdetweil OK back working now with that thanks! Although the conf for my pm2 seems to be not working anymore, I think I saw a similar issue somewhere in the comments here?
                    Also I cant get the conf page anymore cause it can no longer get /modules/MMM-Config/review
                      sdetweil @Alyx
                      @alyx said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                      eh?? what conf for pm2? where?
                      pm2 setup is done once at install (if you use my script and it just points to the ~/MagicMirror/installers/mm.sh
                      eh??
                      http://localhost:8080/modules/MMM-Config/review
                      (the MM config says localhost, SO the url MUST be localhost to match…
                      anything else
                      (ip or name)
                      will fail
                      • A
                        Alyx @sdetweil
                        @sdetweil Before I was able to connect my alexa as a smart device with pm2 but now its not showing at all on alexa is what i mean.
                        Yep that the link I use but I get the the home page and its the same blank interface as before with no modules tab or anything? Like I just used it to make the latest conf file so I know it works some how haha
                        • A
                          Alyx @Alyx
                          @alyx ok screw that its working now all of a sudden ahaha
                          The alexa thing still isnt working tho
                            sdetweil @Alyx
                            @alyx i;m not sure what u mean by the alexaControl problem
                            u set it up once and then do Alexa Discover Devices.
                            they are there forever …(until u manually delete them)
                            now… IF the machine IP changes (like across a reboot)
                            then the ip address that alexa saved is no longer valid and alexa can’t find them
                            it does NOT save dns NAME, only IP address.
                            • A
                              Alyx @sdetweil
                              Yes thats what I mean I haven’t changed anything like that although. I just used the script and the generated config file. It seems alexa can no longer find the devices and is displaying them as offline
                                sdetweil @Alyx
                                @alyx the pi address changed (like powered off overnight and the ip lease expired
                                I set fixed (reservation) addresses for all my pi devices in my network router to avoid this problem
                                only way to fix is to delete and rediscover
                                alexa.amazon.com
                                smarthome tab
                                devices
                                at the bottom is forget all
                                (or u can delete them 1 by 1)
                                • A
                                  Alyx @sdetweil
                                  @sdetweil I did delete and rediscover but the thing is they arent showing up in the discovery now lol
                                    sdetweil @Alyx
                                    @alyx i delete, restart MM or reboot and then rediscover
                                    its finicky for sure… and some newer alexa devices seem not to support the old wmeo plugs like they used to…
                                    new show will not discover them, but older echo will
                                    • A
                                      Alyx @sdetweil
                                      @sdetweil Ive rebooted the machine 3 times at this point ahah, I have an echo3 would that be considered new? I know the 4th gen is the latest
                                      • A
                                        Alyx @Alyx
                                        @alyx ok I found the issue, I commented out all the options in alexa and then ran them individually and etc.
                                        Turns out the notification/ command and devices options werent configured correctly by the conf generator. after commenting those out I can now find them on alexa
                                          sdetweil @Dinschal
                                          @dinschal I have fixes for all the issues…
                                          in my module folder go
                                          git pull
                                          rm -rf node_modules
                                          git checkout new
                                          npm install
                                          give it a whirl… let me know
                                          D 2 Replies Last reply
                                            Dinschal @sdetweil
                                            @sdetweil thanks sam… i will try it later… my frame has to dry :D first coat :D
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
