    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • A
      Alyx @sdetweil
      @sdetweil Before I was able to connect my alexa as a smart device with pm2 but now its not showing at all on alexa is what i mean.
      Yep that the link I use but I get the the home page and its the same blank interface as before with no modules tab or anything? Like I just used it to make the latest conf file so I know it works some how haha
      A 1 Reply Last reply
      • A
        Alyx @Alyx
        @alyx ok screw that its working now all of a sudden ahaha
        The alexa thing still isnt working tho
          sdetweil @Alyx
          @alyx i;m not sure what u mean by the alexaControl problem
          u set it up once and then do Alexa Discover Devices.
          they are there forever …(until u manually delete them)
          now… IF the machine IP changes (like across a reboot)
          then the ip address that alexa saved is no longer valid and alexa can’t find them
          it does NOT save dns NAME, only IP address.
          • A
            Alyx @sdetweil
            Yes thats what I mean I haven’t changed anything like that although. I just used the script and the generated config file. It seems alexa can no longer find the devices and is displaying them as offline
              sdetweil @Alyx
              @alyx the pi address changed (like powered off overnight and the ip lease expired
              I set fixed (reservation) addresses for all my pi devices in my network router to avoid this problem
              only way to fix is to delete and rediscover
              alexa.amazon.com
              smarthome tab
              devices
              at the bottom is forget all
              (or u can delete them 1 by 1)
              • A
                Alyx @sdetweil
                @sdetweil I did delete and rediscover but the thing is they arent showing up in the discovery now lol
                  sdetweil @Alyx
                  @alyx i delete, restart MM or reboot and then rediscover
                  its finicky for sure… and some newer alexa devices seem not to support the old wmeo plugs like they used to…
                  new show will not discover them, but older echo will
                  • A
                    Alyx @sdetweil
                    @sdetweil Ive rebooted the machine 3 times at this point ahah, I have an echo3 would that be considered new? I know the 4th gen is the latest
                    • A
                      Alyx @Alyx
                      @alyx ok I found the issue, I commented out all the options in alexa and then ran them individually and etc.
                      Turns out the notification/ command and devices options werent configured correctly by the conf generator. after commenting those out I can now find them on alexa
                        sdetweil @Dinschal
                        @dinschal I have fixes for all the issues…
                        in my module folder go
                        git pull
                        rm -rf node_modules
                        git checkout new
                        npm install
                        give it a whirl… let me know
                        D 2 Replies Last reply
                          Dinschal @sdetweil
                          @sdetweil thanks sam… i will try it later… my frame has to dry :D first coat :D
                            Dinschal @sdetweil
                            @sdetweil Hi Sam i tried it again and the size of the analog clock wont change, same if i insert UTC+1 into the timezone… else looks pretty good…
                            thanks a lot ;)
                            S 2 Replies Last reply
                              sdetweil @Dinschal
                              @dinschal can u show me the generated config.js for clock? (just that module)
                              it changes the value in config.js when I change it in the form…
                              and send me the debug output again
                                Dinschal @sdetweil
                                @sdetweil oh no not the debug output again :D
                                give me just one second ;)
                                  Dinschal @sdetweil
                                  @sdetweil there is no debug: true in the config anymore :( can i insert it myself?
                                  i tried it, but it stopped here
                                    sdetweil @Dinschal
                                    @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                    i debugged the clock module
                                    UTC works
                                    UTC +1 doesn’t
                                    UTC -1 doesn’t
                                    so I am not sure what it wants
                                    Etc/UTC+1 doesn’t
                                    D 1 Reply Last reply
                                      sdetweil @Dinschal
                                      @dinschal
                                      make sure there is a comma on the line before where u added debug:true to my module
                                        Dinschal @sdetweil
                                        @sdetweil in germany we have summertime and wintertime… so we have utc and utc +1 :D
                                          Dinschal @sdetweil
                                          @sdetweil i did it this way…
                                            sdetweil @Dinschal
                                            yes, understand… the clock module should auto adjust…
                                            we just changed to std time last sunday and the clock adjusted… actually , the system changed reported time
                                            but I was saying I debugged using the timeZone option in config.js for clock, and cannot get any option other than ‘UTC’
                                            to work…
                                            I don’t understand what string it expects
                                            it has a time object and does
                                            time_object.tz(config.timeZone)
                                            to force the time to a particular timezone… except only UTC works for me.
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
