    Generic Config.js & Module Question
    5 Posts 3 Posters 1.0k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      If you go with the default settings that are coded in to each module, you can delete that from the config.js module script associated with each module?
      For example, if color: true, is the default and you are going to stick with true then you can delete that line in config.js because it is coded true in the file you installed in MagicMirror/modules?
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @ankonaskiff17
        @ankonaskiff17 correct… the design is the config.js settings replace to defaults in the module code.
        if they are not specified in config.js then there is nothing to replace with, so the defaults are used
        this makes it so you only have to specify what you need
        • BKeyportB Offline
          BKeyport Module Developer @ankonaskiff17
          @ankonaskiff17 Yes. I think of it this way (Not quite correct, but it helps me wrap my head around it)
          Loading order:
          config in MM
          config in module
          config in config.js
          Same for CSS
          CSS in MM
          CSS in module’s CSS
          CSS in custom.css
          Each step inherits the previous by default, then overrides with new if specified.
            sdetweil @BKeyport
            @bkeyport its better to think of it as a stack
            custom
            module(s)
            main
            topmost wins
            same for config
            config.js
            module
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              ankonaskiff17 @sdetweil
              @sdetweil @BKeyport just trigggered a question on inheritance. On several occasions when I have Developer Tool up to look at something , I’ll see message text that is roughly “X is inherited from body” or from main. Been a while since I was really poking around in developer tool mode. Think above was in context of CSS. So in event you want to change X, how do you tackle without it having global impact?
