    starter problem # 2
    27 Posts 4 Posters 16.7k Views 4 Watching
    • K Offline
      kurt @roramirez
      @roramirez
      yes I did it on my mac via SSH
        roramirez Core Contributors @kurt
        @kurt No, when you run cd command you are still in your Mac
        -bash: cd: /Users/kurt/MagicMirror: No such file or directory
        Easy module development with MagicMirror Module Template
        • K Offline
          kurt @roramirez
          @roramirez
          sorry you are right, but
          Last login: Wed Jan 25 19:24:58 2017
          pi@raspi:~ $ cd ~/MagicMirror
          -bash: cd: /home/pi/MagicMirror: Datei oder Verzeichnis nicht gefunden
          pi@raspi:~ $
            @kurt Ok, is nothing there. Please use the installer script
            curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
            If you using Jessie Lite will need install some packages as say link of @morozgrafix’s post
            • K Offline
              kurt @roramirez
              @roramirez
              Thank you, that’s what i’ll do.
              But do you have any idea, why this happens. Just to avoid to make the same mistake again.
              I intend to use Cyber Duck for transfering folders or scripts.
              And I also use the VNC Viewer, just to see what happens next door, while I work on my mac in an other room.
              And I think I’ll install the full Jessi Version.
              So Thank’s once again! without you It engineers, students and helpers in this forum, users like me were just lost and couldn’t be part of this great projekt, which has just started…
              Kurt
              • morozgrafixM Offline
                morozgrafix Moderator
                if you are comfortable with using ssh and scp you may not even need any GUI tools to transfer files.
                K 1 Reply Last reply Reply Quote 1
                  @kurt Well Jessie Lite dont have X system. X mean desktop system, GUI.
                  MagicMirror run in Electron and this require a DISPLAY system where show it.
                  We working in this topic to prevent you when is using in a system like that.
                  https://github.com/MichMich/MagicMirror/issues/577
                  • K Offline
                    kurt @morozgrafix
                    @morozgrafix
                    Well I’m absolut not comfortable with transfering files or scripts without the help of an grafical surface.
                    I´m absolute new to work with commands on a terminal.
                    So the all the commands I type into the terminal Ijust learned from guys like you just a couple of days ago.
                    When you change the content, lets say from an config.js via SSH. What kind of tools do you use?
                    Because when I opened the folders of my Raspberry with the help of FileZilla, changed the content and tried to save, the MM system collapsed somehow.
                    So my question how do you that?
                    Thanks a lot for the help
                    morozgrafixM 1 Reply Last reply Reply Quote 0
                    • K Offline
                      kurt @roramirez
                      @roramirez
                      Well as I explained in the reply to morozgrafik i’m used to GUI and for me it’s fine doing things by drag and drop…
                      I apreciate your work and input into this projekt a lot!
                      What is your opinion to run the installer by the sudo command like alostvagabond postet it in https://github.com/MichMich/MagicMirror/issues/577
                      I’ll start my atempt #3 in the afternoon :)
                      Thanks a lot for your help
                        morozgrafix Moderator @kurt
                        @kurt I totally understand your point and reasons for you to use GUI tools for file transfers, editing etc. My personal choice is mostly working in the terminal, but it takes some getting used to. The reason why I mentioned SSH and scp, as alternative to using GUI transfer tools, is because they are very reliable and proven to work well. I just wanted to check your comfort level using them, in case that you are suspecting FileZilla, Cyber Duck or some other GUI tool is messing up your MM installation.
                        To answer your question about text editors that work in terminal. There are plenty of them and they have existed for a very long time in unix/linux world. Most of the time they are available with any *nix flavor. To name a few: nano (probably easiest to learn), vim and emacs
                        Hope you get everything sorted with your install and if you need assistance we are here to help.
                        • 2 / 3
