    Main.css, Custom.css and Big Screen TV
    4 Posts 3 Posters 1.6k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      @sdetweil You’ve commented on having large screen TV running MM and I’m attempting to do the same. This is second attempt at this and seeing how small modules are and how much void space is between modules I was wondering if I could copy main.css to custom.css to globally address all the modules similarly. It would end up different than main.css but instead of tackling each module separately, get them all at once. A prime example would be the .dimmed setting. I find that hard to read no matter which module I am looking at so change to bright and same with fonts, big screen TV needs everything to be up-sized and tackling globally seems to be a good option. Wondering on your thoughts and issues you dealt with on large TV.
      S cowboysdudeC 2 Replies Last reply Reply Quote 0
        sdetweil @ankonaskiff17
        @ankonaskiff17 sure… copy away…
        yes, more stuff (smaller fonts) isn’t necessarily the best solution
        • cowboysdudeC Offline
          cowboysdude Module Developer @ankonaskiff17
          @ankonaskiff17 That’s why it’s better that instead of for instance and image in a module is written like this:
          width: 110px;
          height: 125px;
          that it be written
          width: 35%;
          height: 37%;
          The percent works on space where the px is what it is.
          You can always make a module bigger by going into the custom css and doing something like this:
          MMM-Whatever
          custom.css
          .MMM-Whatever {
          width: 400px;
          or
          .MMM-Whatever {
          width: 90%;
          BUT this may NOT give you the results you want… but it’s css so you can play with it and if doesn’t work change it back. I would keep all your changes in the custom.css file and back that up that way if you do an update to MM you won’t lose all your work.
          I think you can do things like git stash but I’d rather just back the file up myself.
          That way you’re only ever changing one file and not individual modules. Too much work. One file, much easier…
          ankonaskiff17A 1 Reply Last reply Reply Quote 1
            ankonaskiff17 @cowboysdude
            @cowboysdude I understand the purpose of custom.css and in the end main.css which I copy to custom.css will be different than main.css.
            When you run MM on a big 45+ inch TV , each module is really small so if you park module X at top_left and park module Y at bottom_right you have two small modules that are same small size and would seem better to do them both with one block of css.
            The other thing that I want to understand is if the top, bottom, left and right sections scale up on big monitor?
            If I put a module in top_left is the right edge of the module hitting the right side of the left section.
            My first pass at this was module by module in custom.css and it was a chore. I’m first to admit i’m a noob in extreme at this but after upscaling each module one by one I was wondering if there was an easier way. I subsequently blew up whole thing so opted to start over. I don’t mind that I killed module via that very css but on second pass I’d as soon avoid the module by module tweaking. As @sdetweil says, just piling in more modules not way to go.
            Standard PC monitor it is not an issue. All the modules seem written with PC monitor in mind. In my use case I want MM to occupy one of HDMI ports on TV, with other HDMI port being cable TV. I can just toggle inputs on TV remote to flip between the two.
