    MMM-GrafanaCharts page not found with Grafana 8.0.6
    4 Posts 3 Posters 1.9k Views 3 Watching
      Babene1 Project Sponsor
      i want to use the MMM-GrafanaCharts in my MM but page not found.
      I have grafana 8.0.6.
      I have no idea where the error could be. I would be very grateful for a hint.
      in normal Brpwser the page works, here is the ULR
      Here is my module config
      			module: 'MMM-GrafanaChart',
      				position: 'top_right',   // This can be any of the regions.
      					   version: "8",
      					   host: "192.168.178.248",
      					   port: 3000,
      					   dashboardname: "raspberryklein",
      					   orgId: 1,
      					   panelId: 2,
      					   width: "500px",
      					   height: "500px",
      					   refreshInterval: 900
        sdetweil @Babene1
        @babene1 where is that host?
        evroomE 1 Reply Last reply Reply Quote 0
        • evroomE Offline
          evroom @sdetweil
          @Babene1
          Your config looks okay to me.
          I do not use it anymore, but from my notes (June 2020):
          $ sudo vi /etc/grafana/grafana.ini
          [auth.anonymous]
          l
          # enable anonymous access
          enabled = true
          # specify organization name that should be used for unauthenticated users
          org_name = MagicMirror
          # specify role for unauthenticated users
          org_role = Viewer
          [security]
          # https://grafana.com/docs/grafana/latest/installation/configuration/#allow-embedding
          allow_embedding = true
          $ sudo systemctl restart grafana-server
          I cannot remember why I needed this.
          Perhaps because of the allow_embedding and enabled settings.
          Good luck,
          E.J.
          MagicMirror version: 2.37.0
            i found the problem, in my case the “panelId” was the problem.
            I don’t know if the problem only occurs in Version 8 from graval or if an configuration misstake in my grafan evironments.
            I delete in MMM-GrafanCharts.js files the panelId in the iframe.src URL and now it works
