    Any plan to replace "request" and "moment"?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    61 Posts 8 Posters 40.8k Views 8 Watching
      sdetweil @0m4r
      @0m4r said in Any plan to replace "request" and "moment"?:
      What is the point to bloat the size of the installation with the same node module installed over and over again
      it is NOT installed over and over
      npm install start with the module folder and says
      is it here?
         no
           look in the parent folders, 1 by 1, looking for a node_modules folder
             is it there?
                yes, stop
         yes,
           stop.
      so it will only be installed once…
      in the near term with all the old modules ‘assuming’ is was installed,
      it’ll have to be installed in the MM/node_modules (but only once)
      0m4r0 1 Reply Last reply Reply Quote 1
      • 0m4r0 Offline
        0m4r Module Developer @sdetweil
        @sdetweil yeah, I guess, I was not clear enough. And I think we are saying the same thing.
        Installing “request” in the MM root folder solves the problem, and this is how I do run my magic mirror from the development branch at this very moment.
        What I mean is that if the module is removed from the “MM/node_modules” folder (the last “parent” level for all modules), every single module will most likely need to install it on its own node_modules folder. This is where I meant it may blow up the size of the MM installation (modules included!)
        I hope this clarifies my prev post :)
        https://github.com/0m4r
          sdetweil @0m4r
          yeh, you have NO idea how big other stuff is already…
          but, this is the design… there is virtual memory, and paging and … to offset these
          now, remember, we are NOT making an installable bundle from all this, just a runtime layout
          • BKeyportB Offline
            BKeyport Module Developer @0m4r
            God, the alternatives to moment are head spinning. I don’t understand 'em, and can’t even get basic functions to work right within jsfiddle.net (Example: Date1 <= Date2 crashes jsfiddle)
            For now, I’ve added package.json to both modules, and if needed, will update my install instructions.
              MMRIZE
              For the moment, maybe luxon or date-fns could be the alternative. (And there are several other modules also.)
              However, After releasing TC39’s new proposal (currently stage 3. https://tc39.es/ecma402/), Browsers and NodeJS will have the native features of handling dates. So I would recommend waiting.
              At this moment, native implementing moment’s features is not easy. Though Intl could handle many aspects of moment already, the unsolved big issue is, current Date and Intl features are still not perfect for localization, like weekOfYear, startdayOfWeek and so on. (Those will be solved by ECMA402)
              0m4r0 cowboysdudeC 2 Replies Last reply Reply Quote 0
              • 0m4r0 Offline
                0m4r Module Developer @MMRIZE
                @mmrize agree to support native browser APIs, but I do also believe we cannot assume everyone is running an up-to-date system for their magic mirror.
                One idea could be to provide a wrapper module to abstract the “behind the scene” tool to manipulate dates, but it may turn out to be quite of an effort and limiting the module developer.
                • cowboysdudeC Offline
                  cowboysdude Module Developer @MMRIZE
                  @mmrize Well we all know how ‘browsers supporting’ all work out LOL
                  Some do…some don’t.
                    sdetweil @cowboysdude
                    @cowboysdude AND for mm, the calendar date work is done OUTSIDE the browser in the node helper. soooooo, still need something
                      MMRIZE
                      @cowboysdude @sdetweil
                      Fortunately, We need to consider only ‘Chromium’ and ‘node’ at most. (Firefox already implements almost-complete Intl features. For Safari… who cares.)
                      And in this case, Intl (and the Temporal in the future) suggests the STANDARD WAY how to handle date/time for L10N/I18N in Javascript environments(includes browsers and nodeJS). So I believe it has worthy looking inside.
                      Once (yesterday), I’ve tried to rewrite clock module and calendar module without momentjs or any other 3rd party library, only with Date and Intl.
                      The start was not so bad. I could rewrite many features with only Date and Intl.
                      Where I stuck was the showWeek config feature. It has to show the ordinal number of weeks of the year. To calculate ISOweek is not difficult. But in some areas, like the US. they never use the ISO system. damn!. To calculate the conventional US week number, additional pieces of information are needed. (read this.) Current Intl has not yet that feature. I’m waiting for Temporal and enhanced Intl releasing.
                      One solution might be to obtain additional information needed for conventional calculation from the user by configuration. At this point, I stopped rewriting. It needs to change config.js and that was not my first intention.
                      A usual solution might be to use 3rd party library like momentjs or luxon. It is easier.
                      However it’s good to read this from the momentjs (https://momentjs.com/docs/#/-project-status/future/) I agree to him, In the near future, native JS features Date, Intl, Temporal will be a standard.
                      S BKeyportB 2 Replies Last reply Reply Quote 0
                        sdetweil @MMRIZE
                        @mmrize i don’t see whats so hard on week of the year.
                        what day of the week is 1/1, subtract that from 7, and then that is the start of the weekly cycle.
                        til you run out of days to count.
                        we don’t use it normally, but its still the week of the year. has nothing to do with month. that is a different scheme
                        my science teacher in high school had a great topic, measurement…
                        you can measure anything with anything… just record what the tool was
                        we were required to measure everything in broomstick handles, broomstick #1 in the lab to be precise.
                        we could subdivide broomstick #1 however we wanted to provide more accuracy, as long as we wrote down the algorithm. (divide by 3, 6, 10?.. , 1000 ml beaker height, whatever)
                        the last week doesn’t run over into a new year, it ENDS when the year ends.
                        just so happens that week #1 of the NEXT year is the same logical week, but who cares, as we started counting from 1 again.
                        M BKeyportB 2 Replies Last reply Reply Quote 0
                          MMRIZE @sdetweil
                          @sdetweil said in Any plan to replace "request" and "moment"?:
                          ISOWeek is easy. Conventional week is the problem.
                          For example, in the United States, Sunday is the first day of the week. The week with January 1st in it is the first week of the year.
                          In France, Monday is the first day of the week, and the week with January 4th is the first week of the year. It means January 1st could be the last week of the last year sometimes. And Jan. 10th could be the first week in certain year.
                          And in other countries, there is also their own rule.
                          This might be important in some European countries, because they use week number in real life (“my vacation ends 23. Weeks“)
                          • BKeyportB Offline
                            BKeyport Module Developer @MMRIZE
                            @mmrize I care about safari. 😢😢😢
                            0m4r0 1 Reply Last reply Reply Quote 0
                            • BKeyportB Offline
                              @mmrize said in Any plan to replace "request" and "moment"?:
                              Where I’m getting stuck with Luxon is basic comparision of dates:
                              Is this time the same or before that time?
                              Moment: m1.isSameOrBefore(m2) (works)
                              Luxon:  dt1 <= dt2 (Crashes jsfiddle)
                              and querying luxon for the locale’s weekday strings is always returning Monday as first, even though it will treat the week correctly otherwise.
                              luxon.info.weekdays('short') == Mon
                              • BKeyportB Offline
                                Moment handles this automatically. Everyone else, not so much.
                                • 0m4r0 Offline
                                  0m4r Module Developer @BKeyport
                                  @bkeyport many do, and you are not alone.
                                  But how many people are running MM in a safari browser?
                                  I guess this is the relevant point here :)
                                  • BKeyportB Offline
                                    @0m4r When I’m testing something, I’ll load it up on my local machine, which is a Mac, and yes, I use Safari. :)
                                    • 0m4r0 Offline
                                      @bkeyport same for me, even tho I am aware like 99% of MM users are running it out of a raspberry pi with a Chromium browser.
                                      That is the reason I say the main focus could be on Chromium-based browsers rather than others.
                                        cowboysdude Module Developer @0m4r
                                        I’m using Brave which is Chrome based without all the tracking and such ;)
                                        • 0m4r0 Offline
                                          0m4r Module Developer @cowboysdude
                                          @cowboysdude technically it is based on Chromium (https://www.chromium.org/).
                                          cowboysdudeC 1 Reply Last reply Reply Quote 1
                                            cowboysdude Module Developer @BKeyport
                                            @bkeyport I wouldn’t worry about it. Moment will be around for a while. Easy to use and yes you can add it to your own package json file and still use it.
                                            Request…not so much LOL
                                            • 2 / 4
