    Applying CSS to individual cells in a table
    7 Posts 3 Posters 1.6k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      How do you go about changing individual cells in a table? I have been messing with MMM-Gas and out of the box it was really small in comparison to other modules. This on on a standard computer monitor and not on big TV I have been poking at, off and on.
      I got the cells/font below Price and Station enlarged no problem and at first I was anticipating them to scale up but when I dug around in MMM-Gas.js they are doing something that I have not seen before.
      ajumpy.innerHTML = "Price"; & xjumpy.innerHTML = "Station";
        sdetweil @ankonaskiff17
        @ankonaskiff17 that’s just setting the content of that tag
        innerText is treated as text and never analyzed.
        innerHtml says it may contain html.
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil What is “jumpy”? Is it similar to say moment.js or other similar libraries? I know I read a bunch of stuff relating to moment.js battling with the calendar module to see if I could figure out how to make the calendar module just show a date which I failed to succeed in doing.
          S cowboysdudeC 3 Replies Last reply Reply Quote 0
            @ankonaskiff17 those are just names of variables
            var xjumpy = document.createElement(“th”);
            var ajumpy = document.createElement(“th”);
            var bjumpy = document.createElement(“th”);
            no idea why he called them that name
            so xjumpy is a th
            and ajumpy is also
            and bjumpy is also
            I would have called them
            stationColumnHeader
            priceColumnHeader
            distanceColumnHeader
            i have this little function i use when doing the content via elements
                   // create document element worker
            	createEl : function (type, id, className, parent, value) {
            		var el= document.createElement(type)
            		if(id)
            			el.id = id
            		if(className)
            			el.className = className
            		if(parent)
            			parent.appendChild(el)
            		if(value) {
            			var e = document.createTextNode(value)
            			el.appendChild(e)
            		return el
            u can create and element, set its id, add a class, set its parent and add its value all in one stmt… reduces the size of the code u write, (but not the amount of code you execute)
            from my bdlist module ,using it
            	var table = this.createEl("table", "birthday-table","TABLE", wrapper, null);
              @ankonaskiff17 said in Applying CSS to individual cells in a table:
              what do you want to do there?
              • cowboysdudeC Offline
                cowboysdude Module Developer @ankonaskiff17
                @ankonaskiff17 Called boredom LOL
                  @sdetweil Have it read MM/DD/YY, even on the day of event.
                  Either 6 or 7 days out from calendar event, the date swaps from MM/DD/YY to Monday at 12:00 AM. (For US Labor Day holiday, in this case)
                  hideTimegets me to it just showing Monday.
                  I thought getRelative: 0, was used to do what I want it to do, You have option of from between 0 - 48 hours with default being 6 hours it goes to relative time. It is swapping at about 6 - 7 DAYS in reality. Maybe just a coincidence but it seems like the default getRelative: 6;is 6 days, not hours, and setting it to zero has no effect.
