    MMM-NewsFeedTicker.
    21 Posts 4 Posters 8.7k Views 4 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      Is there a missing component in the MMM-NewsFeedTicker. I’ve installed it twice, one two different machines and it stopped MM in its tracks. Put in modules folder as required, copied config.js module block and put in config folder.
      No settings changes, launched MM and got black screen. Pulled section of config.js back out, restarted, black screen.
      Deleted MMM-NewsFeedTicker from modules folder. Everything back to normal.
      Tried to launch dev tools but while window came up, there was an error message where normally would be css code, etc.
        sdetweil @ankonaskiff17
        @ankonaskiff17 remember that we deleted old libraries in 2.16 , many modules didn’t document that they were needed, and SO, we end up with a crash
        see the messages where u start MM, and look for ‘module not found’ and then npm install those in the MM folder …
        probably one of
        request
        rrule-alt
        valid-url
        • G Offline
          greedyvegan
          @sdetweil said
          request
          rrule-alt
          valid-url
          this still doesn’t work
            sdetweil @greedyvegan
            @greedyvegan show me the messages from mm npm start
            • G Offline
              greedyvegan @sdetweil
              @sdetweil show me the message from npm start
              after starting mm v2.26.0 it says
              loading config…
              [DEBUG] config template file not exists, no envsubst
              loading module helpers…
              no helper found… initializing new module helper
              then…
                @greedyvegan that says you have an instance running already, do
                pm2 status
                then
                pm2 stop all
                then
                pm2 start  xx
                xx is the number or name on the row
                • G Offline
                  which row?
                    @greedyvegan share the output of
                    pm2 status
                    • G Offline
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 0 │ MagicMirror │ fork │ 29 │ stopped │ 0% │ 0b │
                      │ 2 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
                      │ 1 │ run-start │ fork │ 0 │ stopped │ 0% │ 0b │
                        @greedyvegan hm…
                        run this
                        ps -ef | grep  MagicMirror  | awk '{print $2}` | xargs sudo kill  -9
                        the. try. npm start
                        G 2 Replies Last reply Reply Quote 0
                        • G Offline
                          nothing happened after that, it returned “>” and the cursor
                          • G Offline
                            the module just says loading, I’m going to delete it and use the regular newsfeed instead, thanks.
                            by the way, is there a way that I can add an icon/image to the default newsfeed module?
                            • logo of the news source
                            • photo from the article
                              @greedyvegan I am not aware of those features in the default newsfeed module
                                @greedyvegan correct … Linux commands in general return nothing on success. they were designed in the old teletype terminal days
                                  @greedyvegan you can try the MMMNewsfeedTicker module again…
                                  at least it should work… I accepted the changes as I was a collaborator on that
                                  G 1 Reply Last reply Reply Quote 1
                                  • G Offline
                                    thank you, I’m going to try it now
                                    • G Offline
                                      greedyvegan @greedyvegan
                                      @greedyvegan said in MMM-NewsFeedTicker.:
                                      I tried it and didn’t like it, so I removed it.
                                      thank you.
                                      • K Offline
                                        KiaSohc
                                        Hi there,
                                        Sorry to jump in to this. I have the very same issue where the NFT module only shows “Loading” but never shows any feed. This was working perfectly fine for a long time before I ran an update (git pull) for the module today.
                                        A bit more info…
                                        • I am still on npm 6.14.11 and unable to upgrade due to the nodejs 10.24.0 compatibility issue.
                                        Could it be because I am still on an old npm version?
                                        Many Thanks!
                                          sdetweil @KiaSohc
                                          @KiaSohc well, you probably needed to do npm install in the module folder too after git pull
                                          • K Offline
                                            KiaSohc @sdetweil
                                            @sdetweil Sorry forgot to mention that. Yes, I did ran npm install after git pull but it just shows “Loading…”.
