    MMM-CalDAV
    97 Posts 10 Posters 37.4k Views 9 Watching
    • C Offline
      caw @karsten13
      @karsten13
      i used:
      docker run -d --user root --name magicmirror
      -p 8036:8080
      -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
      -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
      -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
      -e TZ=Europe/Berlin
      –restart always
      registry.gitlab.com/khassel/magicmirror
        sdetweil @caw
        @caw from synology ssh terminal window do
        ls /volume1/docker/magicmirror -laF
        • C Offline
          caw @sdetweil
          thats the result
          and
          are the mounts section
            sdetweil @caw
            @caw ok now need to look inside modules
            ls -laF /volume1/magicmirror/modules
            and in the module folder
            ls -laF /volume1/magicmirror/modules/MMM-CalDAV
            we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
            • C Offline
              caw @sdetweil
              it´s in the /volume1/docker/magicmirror/modules
                sdetweil @caw
                @caw ok, the docker container is running as user/group 1000/1000
                so Simon and users is neither of those
                and linux permissions are a set of values, 3 flags per
                user – this user number/name (Simon)
                group --if the user is part of the named group (users)
                other – permissions for any user NOT in the two choices above
                the permissions shown
                user = rwx // user can read( r) write(w) and execute(x)
                group = r-x // group can read( r) and execute(x)
                other = r-x // all others can read ( r) and execute(x)
                or 755
                if you fix the permissions to 757
                user rwx
                group r-x
                other rwx
                or 775 (probably better, not allow ‘any’ other…)
                user rwx
                group rwx
                other r-x
                then other (1000) will be allowed to write to the folder (service folder)
                • C Offline
                  caw @sdetweil
                  so the permission error is gone but the *ics is still not saved
                    sdetweil @caw
                    @caw can you show all the calDAV messages…
                    last says fetching
                    but the prior says not found…
                      MMRIZE @caw
                      @caw
                      I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                      • C Offline
                        caw @MMRIZE
                        @MMRIZE
                        hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                        THANK YOU VERY MUCH!!! :)
                        maybe you can add the workaround for a tutorial for any Synology User :)
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 7 / 10
