    MMM-CalDAV
    97 Posts 10 Posters 52.7k Views 9 Watching
      caw @sdetweil
      @sdetweil i dont have a dot in front of the Prefix
      module :“MMM-CalDAV”,
      servers: [
      envPrefix: “SYNOLOGY_”,
      2024/09/06 01:23:15 stderr path: ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
      2024/09/06 01:23:15 stderr syscall: ‘open’,
      2024/09/06 01:23:15 stderr code: ‘EACCES’,
      2024/09/06 01:23:15 stderr errno: -13,
      2024/09/06 01:23:15 stderr at async saveIcs (/opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:76:7) {
      2024/09/06 01:23:15 stderr at async Object.writeFile (node:internal/fs/promises:1212:14)
      2024/09/06 01:23:15 stderr at async open (node:internal/fs/promises:639:25)
      2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.709] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
      2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.707] [ERROR] Whoops! There was an uncaught exception…
      2024/09/06 01:23:14 stderr at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024/09/06 01:23:14 stderr at NodeHelper.checkFetchStatus (/opt/magic_mirror/js/node_helper.js:110:9)
      2024/09/06 01:23:14 stderr [2024-09-06 01:23:14.687] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics Error: Not Found
      2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.671] [LOG] [CALDAV] /opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics is not found.
      2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.606] [LOG] Create new calendarfetcher for url: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics - Interval: 3600000
      2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.539] [LOG] [CALDAV] Fetching SYNOLOGY_ : caldav …
      S M karsten13K 3 Replies Last reply Reply Quote 0
        sdetweil @caw
        @caw said in MMM-CalDAV:
        servers: [
        i dont know what caldav wants in its setup,
        sorry. you’ll have to wait for @MMRIZE to help
          MMRIZE @caw
          @caw
          I’m not familiar with the Docker setting. Anyway, it seems to be a permission issue. The docker container creation and execution might be performed by different accounts. Or you may need proper permission for those files or directories. However, I have no idea of Docker environment, so that’s all I can say.
          • karsten13K Offline
            karsten13 @caw
            @caw
            how did you start the container? Please provide full docker run ... command or compose file.
              danny607
              Hello, I am new and wondering what do you name the file env.example to? Second What lines need to be added to the /config/config.js file?
                sdetweil @danny607
                @danny607 the env file name is typically
                .env
                note the leading dot
                the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
                  @caw
                  so looking at the code, this module will write out the constructed ICAL format data to
                    const filePath = path.resolve(__dirname, 'service', '.' + fileName)
                  notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
                  SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
                  in THIS module folder… but write to it…
                  @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
                    karsten13 @sdetweil
                    @sdetweil said in MMM-CalDAV:
                    see docs
                    rw: Read and write access. This is the default if none is specified.
                      sdetweil @karsten13
                      @karsten13 thats what I thought
                      @caw can you ssh logon to your synology and execute a docker command
                      docker inspect  magicmirror
                      scroll up to look at the mounts section
                      (this is from a different container, as I don’t have one running MM)
                      Mounts": [
                                      "Type": "volume",
                                      "Name":
                      "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                                      "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                                      "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                                      "Driver": "local",
                                      "Mode": "",
                                      "RW": true,    <------------    check this , should be true
                                      "Propagation": ""
                      also, how (from where, as what userid?) did you git clone the module, and npm install?
                      another docker command
                      docker exec magicmirror ls /opt/magic_mirror/modules -laF
                        caw @karsten13
                        @karsten13
                        i used:
                        docker run -d --user root --name magicmirror
                        -p 8036:8080
                        -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
                        -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
                        -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
                        -e TZ=Europe/Berlin
                        –restart always
                        registry.gitlab.com/khassel/magicmirror
                          sdetweil @caw
                          @caw from synology ssh terminal window do
                          ls /volume1/docker/magicmirror -laF
                            caw @sdetweil
                            thats the result
                            and
                            are the mounts section
                              sdetweil @caw
                              @caw ok now need to look inside modules
                              ls -laF /volume1/magicmirror/modules
                              and in the module folder
                              ls -laF /volume1/magicmirror/modules/MMM-CalDAV
                              we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
                                caw @sdetweil
                                it´s in the /volume1/docker/magicmirror/modules
                                  sdetweil @caw
                                  @caw ok, the docker container is running as user/group 1000/1000
                                  so Simon and users is neither of those
                                  and linux permissions are a set of values, 3 flags per
                                  user – this user number/name (Simon)
                                  group --if the user is part of the named group (users)
                                  other – permissions for any user NOT in the two choices above
                                  the permissions shown
                                  user = rwx // user can read( r) write(w) and execute(x)
                                  group = r-x // group can read( r) and execute(x)
                                  other = r-x // all others can read ( r) and execute(x)
                                  or 755
                                  if you fix the permissions to 757
                                  user rwx
                                  group r-x
                                  other rwx
                                  or 775 (probably better, not allow ‘any’ other…)
                                  user rwx
                                  group rwx
                                  other r-x
                                  then other (1000) will be allowed to write to the folder (service folder)
                                    caw @sdetweil
                                    so the permission error is gone but the *ics is still not saved
                                      sdetweil @caw
                                      @caw can you show all the calDAV messages…
                                      last says fetching
                                      but the prior says not found…
                                        MMRIZE @caw
                                        @caw
                                        I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                                          caw @MMRIZE
                                          @MMRIZE
                                          hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                                          THANK YOU VERY MUCH!!! :)
                                          maybe you can add the workaround for a tutorial for any Synology User :)
                                            sdetweil @caw
                                            @caw add the workaround?
                                            • 4 / 5
