    MMM-CalDAV
    97 Posts 10 Posters 57.8k Views 9 Watching
      caw @karsten13
      @karsten13
      i used:
      docker run -d --user root --name magicmirror
      -p 8036:8080
      -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
      -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
      -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
      -e TZ=Europe/Berlin
      –restart always
      registry.gitlab.com/khassel/magicmirror
        sdetweil @caw
        @caw from synology ssh terminal window do
        ls /volume1/docker/magicmirror -laF
        C 1 Reply Last reply
          caw @sdetweil
          thats the result
          and
          are the mounts section
            sdetweil @caw
            @caw ok now need to look inside modules
            ls -laF /volume1/magicmirror/modules
            and in the module folder
            ls -laF /volume1/magicmirror/modules/MMM-CalDAV
            we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
              caw @sdetweil
              it´s in the /volume1/docker/magicmirror/modules
                sdetweil @caw
                @caw ok, the docker container is running as user/group 1000/1000
                so Simon and users is neither of those
                and linux permissions are a set of values, 3 flags per
                user – this user number/name (Simon)
                group --if the user is part of the named group (users)
                other – permissions for any user NOT in the two choices above
                the permissions shown
                user = rwx // user can read( r) write(w) and execute(x)
                group = r-x // group can read( r) and execute(x)
                other = r-x // all others can read ( r) and execute(x)
                or 755
                if you fix the permissions to 757
                user rwx
                group r-x
                other rwx
                or 775 (probably better, not allow ‘any’ other…)
                user rwx
                group rwx
                other r-x
                then other (1000) will be allowed to write to the folder (service folder)
                  caw @sdetweil
                  so the permission error is gone but the *ics is still not saved
                  S M 2 Replies Last reply
                    sdetweil @caw
                    @caw can you show all the calDAV messages…
                    last says fetching
                    but the prior says not found…
                      MMRIZE @caw
                      @caw
                      I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                        caw @MMRIZE
                        @MMRIZE
                        hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                        THANK YOU VERY MUCH!!! :)
                        maybe you can add the workaround for a tutorial for any Synology User :)
                          sdetweil @caw
                          @caw add the workaround?
                            caw @sdetweil
                            @sdetweil i think some of the Synology users have the same issue with permissions an their nas
                              sdetweil @caw
                              @caw this is really a docker on synology implementation issue. you created files needed by the docker container using an outside the container userid.
                              many modules use their folder as a cache storage location
                                jal201
                                I apologize but I am very very new to all of this and I was looking for a little guidance on syncing with my Apple Calendar using MMM-CalDAV. The issue I am running into is that in the [LOG] it is showing [CALDAV] /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics is not found. This is cascading into a lot of issues which results in the fetch of the family calendar isn’t happening. I am sure I am missing something simple but I can’t for the life of me find it out. Would it be possible to get some help and which direction could I investigate? Thank you all in advance.
                                S 2 Replies Last reply
                                  sdetweil @jal201
                                  @jal201 can u tell us more about your runtime environment?
                                  are you using a NAS device, synology? or is this on a pi, without docker?
                                  J 1 Reply Last reply
                                    jal201 @sdetweil
                                    Thank you for your time. I believe am using a pi without a docker.
                                      sdetweil @jal201
                                      @jal201 said in MMM-CalDAV:
                                      this seems to imply the config for calendar doesn’t match the config for MMM-Caldav
                                      caldav reads the real calendar and puts the data in the configured folder
                                      and then the MM calendar loads it from the configured folder…
                                      I am not the module author.
                                        jal201 @sdetweil
                                        @sdetweil thank you for the information. I was curious about the *.ICLOUD file location. Do you see that in your application? Is that folder used?
                                        • T
                                          Tiller @MMRIZE
                                          @MMRIZE
                                          Hello again,
                                          sorry I had a lot of work at my job, but now I’m trying again to get this MM working.
                                          The sync to my Synology-Calendar still isn’t working.
                                          Here are my logs:
                                          pi@raspy:~ $ pm2 logs mm
                                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                          0|mm       |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                          0|mm       |     at async davRequest (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:158:25)
                                          0|mm       |     at async fetchPrincipalUrl (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1254:24)
                                          0|mm       |     at async createAccount (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1307:31)
                                          0|mm       |     at async DAVClient.login (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1659:15)
                                          0|mm       |     at async Fetcher.work (/home/pi/MagicMirror/modules/MMM-CalDAV/node_helper.js:89:7) {
                                          0|mm       |   [cause]: Error: getaddrinfo ENOTFOUND invalidcaldavserver.com
                                          0|mm       |       at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                                          0|mm       |     errno: -3008,
                                          0|mm       |     code: 'ENOTFOUND',
                                          0|mm       |     syscall: 'getaddrinfo',
                                          0|mm       |     hostname: 'invalidcaldavserver.com'
                                          0|mm       |   }
                                          0|mm       | }
                                          Probably some auth. problem?
                                          Maybe you got another idea.
                                          I’m running the MM on an Raspberry Pi Zero.
                                          Best
                                          Till
                                          M 1 Reply Last reply
                                            MMRIZE @Tiller
                                            @Tiller
                                            invalidcaldavserver.com ???
                                            Usually your error message is showing that URL may be wrong.
                                            T 1 Reply Last reply
                                            • 4 / 5
