    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      MMRIZE @caw
      @caw
      I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
      C 1 Reply Last reply
        caw @MMRIZE
        @MMRIZE
        hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
        THANK YOU VERY MUCH!!! :)
        maybe you can add the workaround for a tutorial for any Synology User :)
          sdetweil @caw
          @caw add the workaround?
            caw @sdetweil
            @sdetweil i think some of the Synology users have the same issue with permissions an their nas
              sdetweil @caw
              @caw this is really a docker on synology implementation issue. you created files needed by the docker container using an outside the container userid.
              many modules use their folder as a cache storage location
                jal201
                I apologize but I am very very new to all of this and I was looking for a little guidance on syncing with my Apple Calendar using MMM-CalDAV. The issue I am running into is that in the [LOG] it is showing [CALDAV] /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics is not found. This is cascading into a lot of issues which results in the fetch of the family calendar isn’t happening. I am sure I am missing something simple but I can’t for the life of me find it out. Would it be possible to get some help and which direction could I investigate? Thank you all in advance.
                S 2 Replies Last reply
                  sdetweil @jal201
                  @jal201 can u tell us more about your runtime environment?
                  are you using a NAS device, synology? or is this on a pi, without docker?
                  J 1 Reply Last reply
                    jal201 @sdetweil
                    Thank you for your time. I believe am using a pi without a docker.
                      sdetweil @jal201
                      @jal201 said in MMM-CalDAV:
                      this seems to imply the config for calendar doesn’t match the config for MMM-Caldav
                      caldav reads the real calendar and puts the data in the configured folder
                      and then the MM calendar loads it from the configured folder…
                      I am not the module author.
                        jal201 @sdetweil
                        @sdetweil thank you for the information. I was curious about the *.ICLOUD file location. Do you see that in your application? Is that folder used?
                        • T
                          Tiller @MMRIZE
                          @MMRIZE
                          Hello again,
                          sorry I had a lot of work at my job, but now I’m trying again to get this MM working.
                          The sync to my Synology-Calendar still isn’t working.
                          Here are my logs:
                          pi@raspy:~ $ pm2 logs mm
                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                          0|mm       |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          0|mm       |     at async davRequest (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:158:25)
                          0|mm       |     at async fetchPrincipalUrl (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1254:24)
                          0|mm       |     at async createAccount (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1307:31)
                          0|mm       |     at async DAVClient.login (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1659:15)
                          0|mm       |     at async Fetcher.work (/home/pi/MagicMirror/modules/MMM-CalDAV/node_helper.js:89:7) {
                          0|mm       |   [cause]: Error: getaddrinfo ENOTFOUND invalidcaldavserver.com
                          0|mm       |       at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                          0|mm       |     errno: -3008,
                          0|mm       |     code: 'ENOTFOUND',
                          0|mm       |     syscall: 'getaddrinfo',
                          0|mm       |     hostname: 'invalidcaldavserver.com'
                          0|mm       |   }
                          0|mm       | }
                          Probably some auth. problem?
                          Maybe you got another idea.
                          I’m running the MM on an Raspberry Pi Zero.
                          Best
                          Till
                          M 1 Reply Last reply
                            MMRIZE @Tiller
                            @Tiller
                            invalidcaldavserver.com ???
                            Usually your error message is showing that URL may be wrong.
                            T 1 Reply Last reply
                            • T
                              Tiller @MMRIZE
                              @MMRIZE
                              Yes, that’s what I thought too.
                              But I checked it again, and it’s the same URL my Synology ist showing for the calendar.
                              “Http://localip:5000/caldav/”
                              Maybe some settings on my synology are the problem?! I already checked the port, it’s open.
                              Best
                              Tillmann
                                sdetweil @Tiller
                                @Tiller what is localip?
                                • T
                                  Tiller @sdetweil
                                  The local IP of my synology.
                                  Something like 192.168.0.x
                                    sdetweil @Tiller
                                    @Tiller ok… just checking…
                                    just fyi IP addresses 192.168.x.y NEVER cross the internet… they are ‘unroutable’ on purpose
                                    172. and 10. are also like that
                                    if you share that I cannot reach it…
                                    mine network is 192.168.2.x
                                    • T
                                      Tiller
                                      Hello and a happy new year to you all.
                                      I checked the URL, tried different versions. Used the tried the same URL I use on my smartphone (the url is working), but always get the same error.
                                      I don’t know what to do or try.
                                      I checked the firewall and port settings on my synology, but still the same error.
                                      Do you have any other ideas?
                                      Best
                                      Tillmann
                                        sdetweil @Tiller
                                        @Tiller can you post your config… xx out the personal part of your source calendar
                                        use the code block wrapper on the config post here
                                        • T
                                          Tiller @sdetweil
                                          Hi Sam,
                                          here is my config.
                                          Thx
                                          /* Config Sample
                                           * see https://docs.magicmirror.builders/configuration/introduction.html
                                           * and https://docs.magicmirror.builders/modules/configuration.html
                                           * You can use environment variables using a `config.js.template` file instead of `config.js`
                                           * which will be converted to `config.js` while starting. For more information
                                           * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                                          let config = {
                                                  address: "0.0.0.0",     // Address to listen on, can be:
                                                  port: 8080,
                                                  basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                                  ipWhitelist: [],        // Set [] to allow all IP addresses
                                                  useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                                                  httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                                  httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                                  language: "en",
                                                  locale: "en-US",
                                                  timeFormat: 24,
                                                  units: "metric",
                                                          {       module: "MMM-CalDAV",
        servers: [
        accountType: "caldav",
        envPrefix: "SYNOLOGY_",
        serverURL: "http://synology-ip/CalDav/",
        module: "alert",
        module: "updatenotification",
        position: "top_bar"
        module: "clock",
        position: "top_left"
        header: "US Holidays",
        url: "http://localhost:8080/CALDAV/SYNOLOGY_Calendar.ics",
        auth: {
        user: 'username1',
        pass: 'password1',
        method: 'basic'
        module: "compliments",
        position: "lower_third"
        module: "weather",
        weatherProvider: "openmeteo",
        type: "current",
        lat: 51.31,
        lon: 7.28
        module: "weather",
        header: "Weather Forecast",
        type: "forecast",
        lat: 51.31,
        lon: 7.28
        module: "newsfeed",
        position: "bottom_bar",
        feeds: [
        title: "New York Times",
        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
        showSourceTitle: true,
        showPublishDate: true,
        broadcastNewsFeeds: true,
        broadcastNewsUpdates: true
                                            sdetweil @Tiller
                                            @Tiller thanks… just needed caldav and calendar
                                            • 4 / 5
