    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      jal201
      I apologize but I am very very new to all of this and I was looking for a little guidance on syncing with my Apple Calendar using MMM-CalDAV. The issue I am running into is that in the [LOG] it is showing [CALDAV] /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics is not found. This is cascading into a lot of issues which results in the fetch of the family calendar isn’t happening. I am sure I am missing something simple but I can’t for the life of me find it out. Would it be possible to get some help and which direction could I investigate? Thank you all in advance.
      S 2 Replies Last reply
        sdetweil @jal201
        @jal201 can u tell us more about your runtime environment?
        are you using a NAS device, synology? or is this on a pi, without docker?
        J 1 Reply Last reply
          jal201 @sdetweil
          Thank you for your time. I believe am using a pi without a docker.
            sdetweil @jal201
            @jal201 said in MMM-CalDAV:
            this seems to imply the config for calendar doesn’t match the config for MMM-Caldav
            caldav reads the real calendar and puts the data in the configured folder
            and then the MM calendar loads it from the configured folder…
            I am not the module author.
              jal201 @sdetweil
              @sdetweil thank you for the information. I was curious about the *.ICLOUD file location. Do you see that in your application? Is that folder used?
              • T
                Tiller @MMRIZE
                @MMRIZE
                Hello again,
                sorry I had a lot of work at my job, but now I’m trying again to get this MM working.
                The sync to my Synology-Calendar still isn’t working.
                Here are my logs:
                pi@raspy:~ $ pm2 logs mm
                [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                0|mm       |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                0|mm       |     at async davRequest (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:158:25)
                0|mm       |     at async fetchPrincipalUrl (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1254:24)
                0|mm       |     at async createAccount (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1307:31)
                0|mm       |     at async DAVClient.login (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1659:15)
                0|mm       |     at async Fetcher.work (/home/pi/MagicMirror/modules/MMM-CalDAV/node_helper.js:89:7) {
                0|mm       |   [cause]: Error: getaddrinfo ENOTFOUND invalidcaldavserver.com
                0|mm       |       at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                0|mm       |     errno: -3008,
                0|mm       |     code: 'ENOTFOUND',
                0|mm       |     syscall: 'getaddrinfo',
                0|mm       |     hostname: 'invalidcaldavserver.com'
                0|mm       |   }
                0|mm       | }
                Probably some auth. problem?
                Maybe you got another idea.
                I’m running the MM on an Raspberry Pi Zero.
                Best
                Till
                M 1 Reply Last reply
                  MMRIZE @Tiller
                  @Tiller
                  invalidcaldavserver.com ???
                  Usually your error message is showing that URL may be wrong.
                  T 1 Reply Last reply
                  • T
                    Tiller @MMRIZE
                    @MMRIZE
                    Yes, that’s what I thought too.
                    But I checked it again, and it’s the same URL my Synology ist showing for the calendar.
                    “Http://localip:5000/caldav/”
                    Maybe some settings on my synology are the problem?! I already checked the port, it’s open.
                    Best
                    Tillmann
                      sdetweil @Tiller
                      @Tiller what is localip?
                      • T
                        Tiller @sdetweil
                        The local IP of my synology.
                        Something like 192.168.0.x
                          sdetweil @Tiller
                          @Tiller ok… just checking…
                          just fyi IP addresses 192.168.x.y NEVER cross the internet… they are ‘unroutable’ on purpose
                          172. and 10. are also like that
                          if you share that I cannot reach it…
                          mine network is 192.168.2.x
                          • T
                            Tiller
                            Hello and a happy new year to you all.
                            I checked the URL, tried different versions. Used the tried the same URL I use on my smartphone (the url is working), but always get the same error.
                            I don’t know what to do or try.
                            I checked the firewall and port settings on my synology, but still the same error.
                            Do you have any other ideas?
                            Best
                            Tillmann
                              sdetweil @Tiller
                              @Tiller can you post your config… xx out the personal part of your source calendar
                              use the code block wrapper on the config post here
                              • T
                                Tiller @sdetweil
                                Hi Sam,
                                here is my config.
                                Thx
                                /* Config Sample
                                 * see https://docs.magicmirror.builders/configuration/introduction.html
                                 * and https://docs.magicmirror.builders/modules/configuration.html
                                 * You can use environment variables using a `config.js.template` file instead of `config.js`
                                 * which will be converted to `config.js` while starting. For more information
                                 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                                let config = {
                                        address: "0.0.0.0",     // Address to listen on, can be:
                                        port: 8080,
                                        basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                        ipWhitelist: [],        // Set [] to allow all IP addresses
                                        useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                                        httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                        httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                        language: "en",
                                        locale: "en-US",
                                        timeFormat: 24,
                                        units: "metric",
                                                {       module: "MMM-CalDAV",
        servers: [
        accountType: "caldav",
        envPrefix: "SYNOLOGY_",
        serverURL: "http://synology-ip/CalDav/",
                                                        module: "alert",
                                                        module: "updatenotification",
                                                        position: "top_bar"
                                                        module: "clock",
                                                        position: "top_left"
                                                        header: "US Holidays",
        url: "http://localhost:8080/CALDAV/SYNOLOGY_Calendar.ics",
        auth: {
        user: 'username1',
        pass: 'password1',
        method: 'basic'
                                                        module: "compliments",
                                                        position: "lower_third"
                                                        module: "weather",
        weatherProvider: "openmeteo",
        type: "current",
        lat: 51.31,
        lon: 7.28
                                                        module: "weather",
                                                        header: "Weather Forecast",
        type: "forecast",
        lat: 51.31,
        lon: 7.28
                                                        module: "newsfeed",
                                                        position: "bottom_bar",
        feeds: [
        title: "New York Times",
        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
        showSourceTitle: true,
        showPublishDate: true,
        broadcastNewsFeeds: true,
        broadcastNewsUpdates: true
                                  sdetweil @Tiller
                                  @Tiller thanks… just needed caldav and calendar
                                    sdetweil @Tiller
                                    @Tiller said in MMM-CalDAV:
                                    if you open that on browser someplace it works??
                                    • T
                                      Tiller @sdetweil
                                      No, it still doesn’t work. I checked the path of the .ics, which should be stored in /MagicMirror/MMM-CalDav/service/
                                      as a hidden file, but I can only find the placeholder.txt
                                      Tillmann
                                        sdetweil @Tiller
                                        @Tiller i do not know… sounds like the MMM-CalDav module didn’t mnake the conversion for some reason
                                        • T
                                          Tiller @sdetweil
                                          it’s working now, but without the MMM-CalDAV module.
                                          I checked the url I’m using on my phone and just added it to the standard calendar module and added a “.ics” at the end of the url. Now it’s working. I tried this before and it wasn’t working.
                                          Now it is.
                                          Thanks for your help and support.
                                          Best
                                          Tillmann
                                            sdetweil @Tiller
                                            @Tiller awesome!! thanks for the feedback
                                            • 5 / 5
