    MMM-CalDAV
    97 Posts 10 Posters 57.8k Views 9 Watching
    • T
      Tiller @sdetweil
      The local IP of my synology.
      Something like 192.168.0.x
        sdetweil @Tiller
        @Tiller ok… just checking…
        just fyi IP addresses 192.168.x.y NEVER cross the internet… they are ‘unroutable’ on purpose
        172. and 10. are also like that
        if you share that I cannot reach it…
        mine network is 192.168.2.x
        • T
          Tiller
          Hello and a happy new year to you all.
          I checked the URL, tried different versions. Used the tried the same URL I use on my smartphone (the url is working), but always get the same error.
          I don’t know what to do or try.
          I checked the firewall and port settings on my synology, but still the same error.
          Do you have any other ideas?
          Best
          Tillmann
            sdetweil @Tiller
            @Tiller can you post your config… xx out the personal part of your source calendar
            use the code block wrapper on the config post here
            T 1 Reply Last reply
            • T
              Tiller @sdetweil
              Hi Sam,
              here is my config.
              Thx
              /* Config Sample
               * see https://docs.magicmirror.builders/configuration/introduction.html
               * and https://docs.magicmirror.builders/modules/configuration.html
               * You can use environment variables using a `config.js.template` file instead of `config.js`
               * which will be converted to `config.js` while starting. For more information
               * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
              let config = {
                      address: "0.0.0.0",     // Address to listen on, can be:
                      port: 8080,
                      basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      ipWhitelist: [],        // Set [] to allow all IP addresses
                      useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                      httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                      httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                      language: "en",
                      locale: "en-US",
                      timeFormat: 24,
                      units: "metric",
                              {       module: "MMM-CalDAV",
                                              servers: [
                                               accountType: "caldav",
                                                envPrefix: "SYNOLOGY_",
                                               serverURL: "http://synology-ip/CalDav/",
                                      module: "alert",
                                      module: "updatenotification",
                                      position: "top_bar"
                                      module: "clock",
                                      position: "top_left"
                                      header: "US Holidays",
                                                              url: "http://localhost:8080/CALDAV/SYNOLOGY_Calendar.ics",
                                                              auth: {
        user: 'username1',
        pass: 'password1',
        method: 'basic'
                                      module: "compliments",
                                      position: "lower_third"
                                      module: "weather",
                                              weatherProvider: "openmeteo",
                                              type: "current",
                                              lat: 51.31,
                                              lon: 7.28
                                      module: "weather",
                                      header: "Weather Forecast",
                                              type: "forecast",
                                              lat: 51.31,
                                              lon: 7.28
                                      module: "newsfeed",
                                      position: "bottom_bar",
                                              feeds: [
                                                              title: "New York Times",
                                                              url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                              showSourceTitle: true,
                                              showPublishDate: true,
                                              broadcastNewsFeeds: true,
                                              broadcastNewsUpdates: true
              S 2 Replies Last reply
                sdetweil @Tiller
                @Tiller thanks… just needed caldav and calendar
                  sdetweil @Tiller
                  @Tiller said in MMM-CalDAV:
                  if you open that on browser someplace it works??
                  • T
                    Tiller @sdetweil
                    No, it still doesn’t work. I checked the path of the .ics, which should be stored in /MagicMirror/MMM-CalDav/service/
                    as a hidden file, but I can only find the placeholder.txt
                    Tillmann
                      sdetweil @Tiller
                      @Tiller i do not know… sounds like the MMM-CalDav module didn’t mnake the conversion for some reason
                      • T
                        Tiller @sdetweil
                        it’s working now, but without the MMM-CalDAV module.
                        I checked the url I’m using on my phone and just added it to the standard calendar module and added a “.ics” at the end of the url. Now it’s working. I tried this before and it wasn’t working.
                        Now it is.
                        Thanks for your help and support.
                        Best
                        Tillmann
                          sdetweil @Tiller
                          @Tiller awesome!! thanks for the feedback
                          M 1 Reply Last reply
                            MrPringless @sdetweil
                            @MMRIZE
                            Please Can you help me and Sorry for my bad English.
                            I have a Problem wit the CalDAV Module in Magic Mirror2.
                            in the pm2 error Log File i have this Message:
                            [2025-09-04 11:42:08.001] [ERROR] Error when loading MMM-CalDAV: Cannot find module ‘dotenv’
                            Require stack:
                            • /home/magicmirror/MagicMirror/modules/MMM-CalDAV/node_helper.js
                            • /home/magicmirror/MagicMirror/js/app.js
                            • /home/magicmirror/MagicMirror/js/electron.js
                              [2025-09-04 11:42:08.379] [WARN] You’re using a full whitelist configuration to allow for all IPs
                              [2025-09-04 11:42:17.749] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                              at NodeHelper.checkFetchStatus (/home/magicmirror/MagicMirror/js/node_helper.js:102:9)
                              at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
                              [2025-09-04 11:42:18.028] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                              [2025-09-04 11:42:18.226] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/DOMINIQUE_Klasse7d.ics Error: Not Found
                              [2025-09-04 11:42:18.406] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SAMUEL_Klasse4f.ics Error: Not Found
                              [2025-09-04 11:47:17.764] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                              [2025-09-04 11:47:18.035] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                            The following errors are clear thats the result from the First ERROR.
                            What im doing Wrong or thinking false?
                              sdetweil @MrPringless
                              @MrPringless did you run
                              npm install
                              In the module folder after the git clone?
                              git clone …
                              cd MMM-CalDAV
                              npm install
                                @sdetweil Thanks for your reply.
                                It’s a bit crazy. I completely reinstalled everything two days ago using copy and paste from the module page.
                                Then I copied the .env file from the old installation to the new installation.
                                Could this be because I copied the .env file from a backup into the directory after the reinstallation?
                                Thanks for the feedback, because I’d like to learn from my mistakes.
                                  @MrPringless I do not know the inner workings of the module.
                                  typically
                                  module not found
                                  means npm install for the module was not done or the package.json for the module didn’t list the library dependency. MMRIZE is very good on that point, so I don’t the second is the reason…
                                  but thanks for the nudge… my backup/restore scripts will save/restore extra files discovered in a modules folder… but files with leading dot are hidden by convention… so I will have to check that
                                  I would not have picked up the .env file… fixed… thx
                                  • 5 / 5
