    MMM-CalDAV
    97 Posts 10 Posters 56.4k Views 9 Watching
    • T
      Tiller @sdetweil
      Hi Sam,
      here is my config.
      Thx
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
              address: "0.0.0.0",     // Address to listen on, can be:
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              ipWhitelist: [],        // Set [] to allow all IP addresses
              useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              timeFormat: 24,
              units: "metric",
                      {       module: "MMM-CalDAV",
                                      servers: [
                                       accountType: "caldav",
                                        envPrefix: "SYNOLOGY_",
                                       serverURL: "http://synology-ip/CalDav/",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              header: "US Holidays",
                                                      url: "http://localhost:8080/CALDAV/SYNOLOGY_Calendar.ics",
                                                      auth: {
                                                              user: 'username1',
                                                              pass: 'password1',
                                                              method: 'basic'
                              module: "compliments",
                              position: "lower_third"
                              module: "weather",
                                      weatherProvider: "openmeteo",
                                      type: "current",
                                      lat: 51.31,
                                      lon: 7.28
                              module: "weather",
                              header: "Weather Forecast",
                                      type: "forecast",
                                      lat: 51.31,
                                      lon: 7.28
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                                      url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                      showSourceTitle: true,
                                      showPublishDate: true,
                                      broadcastNewsFeeds: true,
                                      broadcastNewsUpdates: true
        sdetweil @Tiller
        @Tiller thanks… just needed caldav and calendar
          sdetweil @Tiller
          @Tiller said in MMM-CalDAV:
          if you open that on browser someplace it works??
          • T
            Tiller @sdetweil
            No, it still doesn’t work. I checked the path of the .ics, which should be stored in /MagicMirror/MMM-CalDav/service/
            as a hidden file, but I can only find the placeholder.txt
            Tillmann
              sdetweil @Tiller
              @Tiller i do not know… sounds like the MMM-CalDav module didn’t mnake the conversion for some reason
              • T
                Tiller @sdetweil
                it’s working now, but without the MMM-CalDAV module.
                I checked the url I’m using on my phone and just added it to the standard calendar module and added a “.ics” at the end of the url. Now it’s working. I tried this before and it wasn’t working.
                Now it is.
                Thanks for your help and support.
                Best
                Tillmann
                  sdetweil @Tiller
                  @Tiller awesome!! thanks for the feedback
                    MrPringless @sdetweil
                    @MMRIZE
                    Please Can you help me and Sorry for my bad English.
                    I have a Problem wit the CalDAV Module in Magic Mirror2.
                    in the pm2 error Log File i have this Message:
                    [2025-09-04 11:42:08.001] [ERROR] Error when loading MMM-CalDAV: Cannot find module ‘dotenv’
                    Require stack:
                    • /home/magicmirror/MagicMirror/modules/MMM-CalDAV/node_helper.js
                    • /home/magicmirror/MagicMirror/js/app.js
                    • /home/magicmirror/MagicMirror/js/electron.js
                      [2025-09-04 11:42:08.379] [WARN] You’re using a full whitelist configuration to allow for all IPs
                      [2025-09-04 11:42:17.749] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                      at NodeHelper.checkFetchStatus (/home/magicmirror/MagicMirror/js/node_helper.js:102:9)
                      at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
                      [2025-09-04 11:42:18.028] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                      [2025-09-04 11:42:18.226] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/DOMINIQUE_Klasse7d.ics Error: Not Found
                      [2025-09-04 11:42:18.406] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SAMUEL_Klasse4f.ics Error: Not Found
                      [2025-09-04 11:47:17.764] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                      [2025-09-04 11:47:18.035] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                    The following errors are clear thats the result from the First ERROR.
                    What im doing Wrong or thinking false?
                      sdetweil @MrPringless
                      @MrPringless did you run
                      npm install
                      In the module folder after the git clone?
                      git clone …
                      cd MMM-CalDAV
                      npm install
                        @sdetweil Thanks for your reply.
                        It’s a bit crazy. I completely reinstalled everything two days ago using copy and paste from the module page.
                        Then I copied the .env file from the old installation to the new installation.
                        Could this be because I copied the .env file from a backup into the directory after the reinstallation?
                        Thanks for the feedback, because I’d like to learn from my mistakes.
                          @MrPringless I do not know the inner workings of the module.
                          typically
                          module not found
                          means npm install for the module was not done or the package.json for the module didn’t list the library dependency. MMRIZE is very good on that point, so I don’t the second is the reason…
                          but thanks for the nudge… my backup/restore scripts will save/restore extra files discovered in a modules folder… but files with leading dot are hidden by convention… so I will have to check that
                          I would not have picked up the .env file… fixed… thx
                          • 5 / 5
