    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      jal201 @sdetweil
      Thank you for your time. I believe am using a pi without a docker.
        sdetweil @jal201
        @jal201 said in MMM-CalDAV:
        /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics
        this seems to imply the config for calendar doesn’t match the config for MMM-Caldav
        caldav reads the real calendar and puts the data in the configured folder
        and then the MM calendar loads it from the configured folder…
        I am not the module author.
        J 1 Reply Last reply
          jal201 @sdetweil
          @sdetweil thank you for the information. I was curious about the *.ICLOUD file location. Do you see that in your application? Is that folder used?
          • T
            Tiller @MMRIZE
            @MMRIZE
            Hello again,
            sorry I had a lot of work at my job, but now I’m trying again to get this MM working.
            The sync to my Synology-Calendar still isn’t working.
            Here are my logs:
            pi@raspy:~ $ pm2 logs mm
            [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
            0|mm       |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            0|mm       |     at async davRequest (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:158:25)
            0|mm       |     at async fetchPrincipalUrl (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1254:24)
            0|mm       |     at async createAccount (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1307:31)
            0|mm       |     at async DAVClient.login (/home/pi/MagicMirror/modules/MMM-CalDAV/node_modules/tsdav/dist/tsdav.cjs.js:1659:15)
            0|mm       |     at async Fetcher.work (/home/pi/MagicMirror/modules/MMM-CalDAV/node_helper.js:89:7) {
            0|mm       |   [cause]: Error: getaddrinfo ENOTFOUND invalidcaldavserver.com
            0|mm       |       at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
            0|mm       |     errno: -3008,
            0|mm       |     code: 'ENOTFOUND',
            0|mm       |     syscall: 'getaddrinfo',
            0|mm       |     hostname: 'invalidcaldavserver.com'
            0|mm       |   }
            0|mm       | }
            Probably some auth. problem?
            Maybe you got another idea.
            I’m running the MM on an Raspberry Pi Zero.
            Best
            Till
            M 1 Reply Last reply
              MMRIZE @Tiller
              @Tiller
              invalidcaldavserver.com ???
              Usually your error message is showing that URL may be wrong.
              T 1 Reply Last reply
              • T
                Tiller @MMRIZE
                @MMRIZE
                Yes, that’s what I thought too.
                But I checked it again, and it’s the same URL my Synology ist showing for the calendar.
                “Http://localip:5000/caldav/”
                Maybe some settings on my synology are the problem?! I already checked the port, it’s open.
                Best
                Tillmann
                  sdetweil @Tiller
                  @Tiller what is localip?
                  • T
                    Tiller @sdetweil
                    The local IP of my synology.
                    Something like 192.168.0.x
                      sdetweil @Tiller
                      @Tiller ok… just checking…
                      just fyi IP addresses 192.168.x.y NEVER cross the internet… they are ‘unroutable’ on purpose
                      172. and 10. are also like that
                      if you share that I cannot reach it…
                      mine network is 192.168.2.x
                      • T
                        Tiller
                        Hello and a happy new year to you all.
                        I checked the URL, tried different versions. Used the tried the same URL I use on my smartphone (the url is working), but always get the same error.
                        I don’t know what to do or try.
                        I checked the firewall and port settings on my synology, but still the same error.
                        Do you have any other ideas?
                        Best
                        Tillmann
                          sdetweil @Tiller
                          @Tiller can you post your config… xx out the personal part of your source calendar
                          use the code block wrapper on the config post here
                          • T
                            Tiller @sdetweil
                            Hi Sam,
                            here is my config.
                            Thx
                            /* Config Sample
                             * see https://docs.magicmirror.builders/configuration/introduction.html
                             * and https://docs.magicmirror.builders/modules/configuration.html
                             * You can use environment variables using a `config.js.template` file instead of `config.js`
                             * which will be converted to `config.js` while starting. For more information
                             * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                            let config = {
                                    address: "0.0.0.0",     // Address to listen on, can be:
                                    port: 8080,
                                    basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                    ipWhitelist: [],        // Set [] to allow all IP addresses
                                    useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                                    httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                    httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                    language: "en",
                                    locale: "en-US",
                                    timeFormat: 24,
                                    units: "metric",
                                            {       module: "MMM-CalDAV",
                                                            servers: [
                                                             accountType: "caldav",
                                                              envPrefix: "SYNOLOGY_",
                                                             serverURL: "http://synology-ip/CalDav/",
                                                    module: "alert",
                                                    module: "updatenotification",
                                                    position: "top_bar"
                                                    module: "clock",
                                                    position: "top_left"
                                                    header: "US Holidays",
        url: "http://localhost:8080/CALDAV/SYNOLOGY_Calendar.ics",
        auth: {
        user: 'username1',
        pass: 'password1',
        method: 'basic'
                                                    module: "compliments",
                                                    position: "lower_third"
                                                    module: "weather",
                                                            weatherProvider: "openmeteo",
                                                            type: "current",
                                                            lat: 51.31,
                                                            lon: 7.28
                                                    module: "weather",
                                                    header: "Weather Forecast",
                                                            type: "forecast",
                                                            lat: 51.31,
                                                            lon: 7.28
                                                    module: "newsfeed",
                                                    position: "bottom_bar",
                                                            feeds: [
        title: "New York Times",
        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                                            showSourceTitle: true,
                                                            showPublishDate: true,
                                                            broadcastNewsFeeds: true,
                                                            broadcastNewsUpdates: true
                            S 2 Replies Last reply
                              sdetweil @Tiller
                              @Tiller thanks… just needed caldav and calendar
                                sdetweil @Tiller
                                @Tiller said in MMM-CalDAV:
                                if you open that on browser someplace it works??
                                • T
                                  Tiller @sdetweil
                                  No, it still doesn’t work. I checked the path of the .ics, which should be stored in /MagicMirror/MMM-CalDav/service/
                                  as a hidden file, but I can only find the placeholder.txt
                                  Tillmann
                                    sdetweil @Tiller
                                    @Tiller i do not know… sounds like the MMM-CalDav module didn’t mnake the conversion for some reason
                                    • T
                                      Tiller @sdetweil
                                      it’s working now, but without the MMM-CalDAV module.
                                      I checked the url I’m using on my phone and just added it to the standard calendar module and added a “.ics” at the end of the url. Now it’s working. I tried this before and it wasn’t working.
                                      Now it is.
                                      Thanks for your help and support.
                                      Best
                                      Tillmann
                                        sdetweil @Tiller
                                        @Tiller awesome!! thanks for the feedback
                                          MrPringless @sdetweil
                                          @MMRIZE
                                          Please Can you help me and Sorry for my bad English.
                                          I have a Problem wit the CalDAV Module in Magic Mirror2.
                                          in the pm2 error Log File i have this Message:
                                          [2025-09-04 11:42:08.001] [ERROR] Error when loading MMM-CalDAV: Cannot find module ‘dotenv’
                                          Require stack:
                                          • /home/magicmirror/MagicMirror/modules/MMM-CalDAV/node_helper.js
                                          • /home/magicmirror/MagicMirror/js/app.js
                                          • /home/magicmirror/MagicMirror/js/electron.js
                                            [2025-09-04 11:42:08.379] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                            [2025-09-04 11:42:17.749] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                                            at NodeHelper.checkFetchStatus (/home/magicmirror/MagicMirror/js/node_helper.js:102:9)
                                            at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
                                            [2025-09-04 11:42:18.028] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                                            [2025-09-04 11:42:18.226] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/DOMINIQUE_Klasse7d.ics Error: Not Found
                                            [2025-09-04 11:42:18.406] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SAMUEL_Klasse4f.ics Error: Not Found
                                            [2025-09-04 11:47:17.764] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/FAMILY_Familienkalender.ics Error: Not Found
                                            [2025-09-04 11:47:18.035] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/NINA_Arbeit.ics Error: Not Found
                                          The following errors are clear thats the result from the First ERROR.
                                          What im doing Wrong or thinking false?
                                            sdetweil @MrPringless
                                            @MrPringless did you run
                                            npm install
                                            In the module folder after the git clone?
                                            git clone …
                                            cd MMM-CalDAV
                                            npm install
                                            • 5 / 5
