    MMM-CalDAV
    97 Posts 10 Posters 49.9k Views 9 Watching
      @caw
      so looking at the code, this module will write out the constructed ICAL format data to
        const filePath = path.resolve(__dirname, 'service', '.' + fileName)
      notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
      SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
      in THIS module folder… but write to it…
      @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
      • karsten13K Offline
        karsten13 @sdetweil
        @sdetweil said in MMM-CalDAV:
        see docs
        rw: Read and write access. This is the default if none is specified.
          sdetweil @karsten13
          @karsten13 thats what I thought
          @caw can you ssh logon to your synology and execute a docker command
          docker inspect  magicmirror
          scroll up to look at the mounts section
          (this is from a different container, as I don’t have one running MM)
          Mounts": [
                          "Type": "volume",
                          "Name":
          "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                          "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                          "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                          "Driver": "local",
                          "Mode": "",
                          "RW": true,    <------------    check this , should be true
                          "Propagation": ""
          also, how (from where, as what userid?) did you git clone the module, and npm install?
          another docker command
          docker exec magicmirror ls /opt/magic_mirror/modules -laF
            caw @karsten13
            @karsten13
            i used:
            docker run -d --user root --name magicmirror
            -p 8036:8080
            -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
            -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
            -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
            -e TZ=Europe/Berlin
            –restart always
            registry.gitlab.com/khassel/magicmirror
              sdetweil @caw
              @caw from synology ssh terminal window do
              ls /volume1/docker/magicmirror -laF
                caw @sdetweil
                thats the result
                and
                are the mounts section
                  sdetweil @caw
                  @caw ok now need to look inside modules
                  ls -laF /volume1/magicmirror/modules
                  and in the module folder
                  ls -laF /volume1/magicmirror/modules/MMM-CalDAV
                  we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
                    caw @sdetweil
                    it´s in the /volume1/docker/magicmirror/modules
                      sdetweil @caw
                      @caw ok, the docker container is running as user/group 1000/1000
                      so Simon and users is neither of those
                      and linux permissions are a set of values, 3 flags per
                      user – this user number/name (Simon)
                      group --if the user is part of the named group (users)
                      other – permissions for any user NOT in the two choices above
                      the permissions shown
                      user = rwx // user can read( r) write(w) and execute(x)
                      group = r-x // group can read( r) and execute(x)
                      other = r-x // all others can read ( r) and execute(x)
                      or 755
                      if you fix the permissions to 757
                      user rwx
                      group r-x
                      other rwx
                      or 775 (probably better, not allow ‘any’ other…)
                      user rwx
                      group rwx
                      other r-x
                      then other (1000) will be allowed to write to the folder (service folder)
                        caw @sdetweil
                        so the permission error is gone but the *ics is still not saved
                          sdetweil @caw
                          @caw can you show all the calDAV messages…
                          last says fetching
                          but the prior says not found…
                            MMRIZE @caw
                            @caw
                            I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                              caw @MMRIZE
                              @MMRIZE
                              hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                              THANK YOU VERY MUCH!!! :)
                              maybe you can add the workaround for a tutorial for any Synology User :)
                                sdetweil @caw
                                @caw add the workaround?
                                  caw @sdetweil
                                  @sdetweil i think some of the Synology users have the same issue with permissions an their nas
                                    sdetweil @caw
                                    @caw this is really a docker on synology implementation issue. you created files needed by the docker container using an outside the container userid.
                                    many modules use their folder as a cache storage location
                                      jal201
                                      I apologize but I am very very new to all of this and I was looking for a little guidance on syncing with my Apple Calendar using MMM-CalDAV. The issue I am running into is that in the [LOG] it is showing [CALDAV] /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics is not found. This is cascading into a lot of issues which results in the fetch of the family calendar isn’t happening. I am sure I am missing something simple but I can’t for the life of me find it out. Would it be possible to get some help and which direction could I investigate? Thank you all in advance.
                                        sdetweil @jal201
                                        @jal201 can u tell us more about your runtime environment?
                                        are you using a NAS device, synology? or is this on a pi, without docker?
                                          jal201 @sdetweil
                                          Thank you for your time. I believe am using a pi without a docker.
                                            sdetweil @jal201
                                            @jal201 said in MMM-CalDAV:
                                            this seems to imply the config for calendar doesn’t match the config for MMM-Caldav
                                            caldav reads the real calendar and puts the data in the configured folder
                                            and then the MM calendar loads it from the configured folder…
                                            I am not the module author.
                                            • 4 / 5
