    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      sdetweil @danny607
      @danny607 the env file name is typically
      .env
      note the leading dot
      the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
        @caw
        so looking at the code, this module will write out the constructed ICAL format data to
          const filePath = path.resolve(__dirname, 'service', '.' + fileName)
        notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
        SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
        in THIS module folder… but write to it…
        @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
        karsten13K 1 Reply Last reply
        • karsten13K
          karsten13 @sdetweil
          @sdetweil said in MMM-CalDAV:
          see docs
          rw: Read and write access. This is the default if none is specified.
            sdetweil @karsten13
            @karsten13 thats what I thought
            @caw can you ssh logon to your synology and execute a docker command
            docker inspect  magicmirror
            scroll up to look at the mounts section
            (this is from a different container, as I don’t have one running MM)
            Mounts": [
                            "Type": "volume",
                            "Name":
            "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                            "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                            "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                            "Driver": "local",
                            "Mode": "",
                            "RW": true,    <------------    check this , should be true
                            "Propagation": ""
            also, how (from where, as what userid?) did you git clone the module, and npm install?
            another docker command
            docker exec magicmirror ls /opt/magic_mirror/modules -laF
              caw @karsten13
              @karsten13
              i used:
              docker run -d --user root --name magicmirror
              -p 8036:8080
              -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
              -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
              -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
              -e TZ=Europe/Berlin
              –restart always
              registry.gitlab.com/khassel/magicmirror
                sdetweil @caw
                @caw from synology ssh terminal window do
                ls /volume1/docker/magicmirror -laF
                C 1 Reply Last reply
                  caw @sdetweil
                  thats the result
                  and
                  are the mounts section
                    sdetweil @caw
                    @caw ok now need to look inside modules
                    ls -laF /volume1/magicmirror/modules
                    and in the module folder
                    ls -laF /volume1/magicmirror/modules/MMM-CalDAV
                    we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
                      caw @sdetweil
                      it´s in the /volume1/docker/magicmirror/modules
                        sdetweil @caw
                        @caw ok, the docker container is running as user/group 1000/1000
                        so Simon and users is neither of those
                        and linux permissions are a set of values, 3 flags per
                        user – this user number/name (Simon)
                        group --if the user is part of the named group (users)
                        other – permissions for any user NOT in the two choices above
                        the permissions shown
                        user = rwx // user can read( r) write(w) and execute(x)
                        group = r-x // group can read( r) and execute(x)
                        other = r-x // all others can read ( r) and execute(x)
                        or 755
                        if you fix the permissions to 757
                        user rwx
                        group r-x
                        other rwx
                        or 775 (probably better, not allow ‘any’ other…)
                        user rwx
                        group rwx
                        other r-x
                        then other (1000) will be allowed to write to the folder (service folder)
                          caw @sdetweil
                          so the permission error is gone but the *ics is still not saved
                          S M 2 Replies Last reply
                            sdetweil @caw
                            @caw can you show all the calDAV messages…
                            last says fetching
                            but the prior says not found…
                              MMRIZE @caw
                              @caw
                              I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                                caw @MMRIZE
                                @MMRIZE
                                hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                                THANK YOU VERY MUCH!!! :)
                                maybe you can add the workaround for a tutorial for any Synology User :)
                                  sdetweil @caw
                                  @caw add the workaround?
                                    caw @sdetweil
                                    @sdetweil i think some of the Synology users have the same issue with permissions an their nas
                                      sdetweil @caw
                                      @caw this is really a docker on synology implementation issue. you created files needed by the docker container using an outside the container userid.
                                      many modules use their folder as a cache storage location
                                        jal201
                                        I apologize but I am very very new to all of this and I was looking for a little guidance on syncing with my Apple Calendar using MMM-CalDAV. The issue I am running into is that in the [LOG] it is showing [CALDAV] /MagicMirror/modules/MMM-CalDAV/service/.ICLOUD_family.ics is not found. This is cascading into a lot of issues which results in the fetch of the family calendar isn’t happening. I am sure I am missing something simple but I can’t for the life of me find it out. Would it be possible to get some help and which direction could I investigate? Thank you all in advance.
                                        S 2 Replies Last reply
                                          sdetweil @jal201
                                          @jal201 can u tell us more about your runtime environment?
                                          are you using a NAS device, synology? or is this on a pi, without docker?
                                          J 1 Reply Last reply
                                            jal201 @sdetweil
                                            Thank you for your time. I believe am using a pi without a docker.
                                            • 4 / 5
