    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      sdetweil @caw
      @caw i am going to guess
      remove the dot in front of SYNOLOGY
      and in the MagicMirror config mke sure there is a space where you see the 20, or make it %20
      one change at a time
      C 1 Reply Last reply
        caw @sdetweil
        @sdetweil i dont have a dot in front of the Prefix
        module :“MMM-CalDAV”,
        servers: [
        envPrefix: “SYNOLOGY_”,
        2024/09/06 01:23:15 stderr path: ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
        2024/09/06 01:23:15 stderr syscall: ‘open’,
        2024/09/06 01:23:15 stderr code: ‘EACCES’,
        2024/09/06 01:23:15 stderr errno: -13,
        2024/09/06 01:23:15 stderr at async saveIcs (/opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:76:7) {
        2024/09/06 01:23:15 stderr at async Object.writeFile (node:internal/fs/promises:1212:14)
        2024/09/06 01:23:15 stderr at async open (node:internal/fs/promises:639:25)
        2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.709] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
        2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.707] [ERROR] Whoops! There was an uncaught exception…
        2024/09/06 01:23:14 stderr at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024/09/06 01:23:14 stderr at NodeHelper.checkFetchStatus (/opt/magic_mirror/js/node_helper.js:110:9)
        2024/09/06 01:23:14 stderr [2024-09-06 01:23:14.687] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics Error: Not Found
        2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.671] [LOG] [CALDAV] /opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics is not found.
        2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.606] [LOG] Create new calendarfetcher for url: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics - Interval: 3600000
        2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.539] [LOG] [CALDAV] Fetching SYNOLOGY_ : caldav …
        S M karsten13K 3 Replies Last reply
          sdetweil @caw
          @caw said in MMM-CalDAV:
          servers: [
          i dont know what caldav wants in its setup,
          sorry. you’ll have to wait for @MMRIZE to help
            MMRIZE @caw
            @caw
            I’m not familiar with the Docker setting. Anyway, it seems to be a permission issue. The docker container creation and execution might be performed by different accounts. Or you may need proper permission for those files or directories. However, I have no idea of Docker environment, so that’s all I can say.
            • karsten13K
              karsten13 @caw
              @caw
              how did you start the container? Please provide full docker run ... command or compose file.
                danny607
                Hello, I am new and wondering what do you name the file env.example to? Second What lines need to be added to the /config/config.js file?
                  sdetweil @danny607
                  @danny607 the env file name is typically
                  .env
                  note the leading dot
                  the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
                    @caw
                    so looking at the code, this module will write out the constructed ICAL format data to
                      const filePath = path.resolve(__dirname, 'service', '.' + fileName)
                    notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
                    SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
                    in THIS module folder… but write to it…
                    @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
                    karsten13K 1 Reply Last reply
                    • karsten13K
                      karsten13 @sdetweil
                      @sdetweil said in MMM-CalDAV:
                      see docs
                      rw: Read and write access. This is the default if none is specified.
                        sdetweil @karsten13
                        @karsten13 thats what I thought
                        @caw can you ssh logon to your synology and execute a docker command
                        docker inspect  magicmirror
                        scroll up to look at the mounts section
                        (this is from a different container, as I don’t have one running MM)
                        Mounts": [
                                        "Type": "volume",
                                        "Name":
                        "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                                        "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                                        "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                                        "Driver": "local",
                                        "Mode": "",
                                        "RW": true,    <------------    check this , should be true
                                        "Propagation": ""
                        also, how (from where, as what userid?) did you git clone the module, and npm install?
                        another docker command
                        docker exec magicmirror ls /opt/magic_mirror/modules -laF
                          caw @karsten13
                          @karsten13
                          i used:
                          docker run -d --user root --name magicmirror
                          -p 8036:8080
                          -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
                          -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
                          -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
                          -e TZ=Europe/Berlin
                          –restart always
                          registry.gitlab.com/khassel/magicmirror
                            sdetweil @caw
                            @caw from synology ssh terminal window do
                            ls /volume1/docker/magicmirror -laF
                              caw @sdetweil
                              thats the result
                              and
                              are the mounts section
                                sdetweil @caw
                                @caw ok now need to look inside modules
                                ls -laF /volume1/magicmirror/modules
                                and in the module folder
                                ls -laF /volume1/magicmirror/modules/MMM-CalDAV
                                we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
                                  caw @sdetweil
                                  it´s in the /volume1/docker/magicmirror/modules
                                    sdetweil @caw
                                    @caw ok, the docker container is running as user/group 1000/1000
                                    so Simon and users is neither of those
                                    and linux permissions are a set of values, 3 flags per
                                    user – this user number/name (Simon)
                                    group --if the user is part of the named group (users)
                                    other – permissions for any user NOT in the two choices above
                                    the permissions shown
                                    user = rwx // user can read( r) write(w) and execute(x)
                                    group = r-x // group can read( r) and execute(x)
                                    other = r-x // all others can read ( r) and execute(x)
                                    or 755
                                    if you fix the permissions to 757
                                    user rwx
                                    group r-x
                                    other rwx
                                    or 775 (probably better, not allow ‘any’ other…)
                                    user rwx
                                    group rwx
                                    other r-x
                                    then other (1000) will be allowed to write to the folder (service folder)
                                      caw @sdetweil
                                      so the permission error is gone but the *ics is still not saved
                                      S M 2 Replies Last reply
                                        sdetweil @caw
                                        @caw can you show all the calDAV messages…
                                        last says fetching
                                        but the prior says not found…
                                          MMRIZE @caw
                                          @caw
                                          I cannot say anything without the full log. But at the first execution, ics would not be written yet, (calendar module is so fast than CalDAV’s connection and parsing) so just wait for the next cycle to finish serving, or just stop and rerun MM. From the second execution, ics will be served.
                                            caw @MMRIZE
                                            @MMRIZE
                                            hi i´ve got it- it was the firewall blocking and the ics files are created and a test is shown
                                            THANK YOU VERY MUCH!!! :)
                                            maybe you can add the workaround for a tutorial for any Synology User :)
                                            • 3 / 5
