    MMM-CalDAV
    97 Posts 10 Posters 56.4k Views 9 Watching
      sdetweil @caw
      @caw because the ics generated by MMM-Caldav is only needed on this same machine I would use
      http://localhost:mmport/CALDAV
      in the calendar module.
      I am guessing your cert is connected to your internet IP address (ISP router)
      which is then port forwarded to the MM machine…
      this is an external (from MM’s perspective) request
      MM is configured (be default) to be a closed system on the wall, not allowing any external systems to request the MM page (external means outside the machine MM is running on)
        caw @sdetweil
        @sdetweil i searched for a guide to get the Khassel container running on a Synology NAS but didn’t found anything about it. I tried it by my own but did not work. Do you have a clue how to get it on the Docker on a Synology NAS?
          sdetweil @caw
          @caw my older 416j only has 512mb storage, not enough room to run docker things
          but docker is docker. i thought he specified a compose or command line
          see this
          https://forum.magicmirror.builders/topic/18952/docker-install-on-synology-nas
            caw @sdetweil
            @sdetweil @MMRIZE
            so i got the khassel image running and i think the calendars are found but i get an error:
            [2024-09-05 22:42:56.488] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Familien_20Kalender.ics’
            2024/09/05 22:42:56 stderr [2024-09-05 22:42:56.486] [ERROR] Whoops! There was an uncaught exception…
            do you have a clue how to fix this? im irritated by the “20” between Familien_20Kalender.ics thats no part of the calendar name…
              sdetweil @caw
              @caw 20 is typically part of a name with a space in it, %20
              also you have a . (dot) in front of SYNOLOGY_
                caw @sdetweil
                and do you have any clue where the misstake is? and how can i fix it?
                  sdetweil @caw
                  @caw i am going to guess
                  remove the dot in front of SYNOLOGY
                  and in the MagicMirror config mke sure there is a space where you see the 20, or make it %20
                  one change at a time
                    caw @sdetweil
                    @sdetweil i dont have a dot in front of the Prefix
                    module :“MMM-CalDAV”,
                    servers: [
                    envPrefix: “SYNOLOGY_”,
                    2024/09/06 01:23:15 stderr path: ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                    2024/09/06 01:23:15 stderr syscall: ‘open’,
                    2024/09/06 01:23:15 stderr code: ‘EACCES’,
                    2024/09/06 01:23:15 stderr errno: -13,
                    2024/09/06 01:23:15 stderr at async saveIcs (/opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:76:7) {
                    2024/09/06 01:23:15 stderr at async Object.writeFile (node:internal/fs/promises:1212:14)
                    2024/09/06 01:23:15 stderr at async open (node:internal/fs/promises:639:25)
                    2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.709] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                    2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.707] [ERROR] Whoops! There was an uncaught exception…
                    2024/09/06 01:23:14 stderr at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                    2024/09/06 01:23:14 stderr at NodeHelper.checkFetchStatus (/opt/magic_mirror/js/node_helper.js:110:9)
                    2024/09/06 01:23:14 stderr [2024-09-06 01:23:14.687] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics Error: Not Found
                    2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.671] [LOG] [CALDAV] /opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics is not found.
                    2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.606] [LOG] Create new calendarfetcher for url: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics - Interval: 3600000
                    2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.539] [LOG] [CALDAV] Fetching SYNOLOGY_ : caldav …
                    S M karsten13K 3 Replies Last reply Reply Quote 0
                      sdetweil @caw
                      @caw said in MMM-CalDAV:
                      servers: [
                      i dont know what caldav wants in its setup,
                      sorry. you’ll have to wait for @MMRIZE to help
                        MMRIZE @caw
                        @caw
                        I’m not familiar with the Docker setting. Anyway, it seems to be a permission issue. The docker container creation and execution might be performed by different accounts. Or you may need proper permission for those files or directories. However, I have no idea of Docker environment, so that’s all I can say.
                        • karsten13K
                          karsten13 @caw
                          @caw
                          how did you start the container? Please provide full docker run ... command or compose file.
                            danny607
                            Hello, I am new and wondering what do you name the file env.example to? Second What lines need to be added to the /config/config.js file?
                              sdetweil @danny607
                              @danny607 the env file name is typically
                              .env
                              note the leading dot
                              the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
                                @caw
                                so looking at the code, this module will write out the constructed ICAL format data to
                                  const filePath = path.resolve(__dirname, 'service', '.' + fileName)
                                notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
                                SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
                                in THIS module folder… but write to it…
                                @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
                                • karsten13K
                                  karsten13 @sdetweil
                                  @sdetweil said in MMM-CalDAV:
                                  see docs
                                  rw: Read and write access. This is the default if none is specified.
                                    sdetweil @karsten13
                                    @karsten13 thats what I thought
                                    @caw can you ssh logon to your synology and execute a docker command
                                    docker inspect  magicmirror
                                    scroll up to look at the mounts section
                                    (this is from a different container, as I don’t have one running MM)
                                    Mounts": [
                                                    "Type": "volume",
                                                    "Name":
                                    "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                                                    "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                                                    "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                                                    "Driver": "local",
                                                    "Mode": "",
                                                    "RW": true,    <------------    check this , should be true
                                                    "Propagation": ""
                                    also, how (from where, as what userid?) did you git clone the module, and npm install?
                                    another docker command
                                    docker exec magicmirror ls /opt/magic_mirror/modules -laF
                                      caw @karsten13
                                      @karsten13
                                      i used:
                                      docker run -d --user root --name magicmirror
                                      -p 8036:8080
                                      -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
                                      -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
                                      -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
                                      -e TZ=Europe/Berlin
                                      –restart always
                                      registry.gitlab.com/khassel/magicmirror
                                        sdetweil @caw
                                        @caw from synology ssh terminal window do
                                        ls /volume1/docker/magicmirror -laF
                                          caw @sdetweil
                                          thats the result
                                          and
                                          are the mounts section
                                            sdetweil @caw
                                            @caw ok now need to look inside modules
                                            ls -laF /volume1/magicmirror/modules
                                            and in the module folder
                                            ls -laF /volume1/magicmirror/modules/MMM-CalDAV
                                            we did not check INSIDE the MMM-CalDAV/service folder to see if there is an existing file that might be overwritten (with the wrong permissions)
                                            • 3 / 5
