    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      sdetweil @caw
      @caw what docker container?
      C 1 Reply Last reply
        sdetweil @caw
        @caw said in MMM-CalDAV:
        "https://myownsynologyadress.de/caldav/
        https: means you have a certificate for that address and have configured MMM-Caldav to run in secure mode
        is that true?
        typically one uses mmm-caldav to read from the foreign calendar, and emit ics data for the local machine
        and make it available thru a url request (which causes the MMM-Caldav module to provide the data live)
        http://mmIP:mmPort/caldav
        or shorthand for this same system is (using the default mm port)
        http://localhost:8080/caldav
        depending on how MM is configured,
        address: and ipWhitelist, by default it rejects ALL requests from OUTSIDE systems
        so your loop back at - https://myownsynologyadress.de would be rejected…
        I use cloudflare to map outside requests to my systems thr a tunnel, so I have https (cert provided by cloudflare) and have reconfigured my MagicMirror to allow any incoming request
        address: "0.0.0.0",
        ipWhitelist:[],
          caw @sdetweil
          @sdetweil im running the “container manager” on the nas and the container by bastilimbach installation guide by https://mariushosting.com/how-to-install-magicmirror-on-your-synology-nas/
            caw @sdetweil
            @sdetweil i used ipv64 to receive a certificate - but for now i dont want to get any caldav from outside or do i missunderstand something?
              sdetweil @caw
              bastilimbach
              that image is 4 years old, so not running the latest node or MM…
              the install doc https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
              references this docker image
              https://gitlab.com/khassel/magicmirror
                sdetweil @caw
                @caw because the ics generated by MMM-Caldav is only needed on this same machine I would use
                http://localhost:mmport/CALDAV
                in the calendar module.
                I am guessing your cert is connected to your internet IP address (ISP router)
                which is then port forwarded to the MM machine…
                this is an external (from MM’s perspective) request
                MM is configured (be default) to be a closed system on the wall, not allowing any external systems to request the MM page (external means outside the machine MM is running on)
                  caw @sdetweil
                  @sdetweil i searched for a guide to get the Khassel container running on a Synology NAS but didn’t found anything about it. I tried it by my own but did not work. Do you have a clue how to get it on the Docker on a Synology NAS?
                    sdetweil @caw
                    @caw my older 416j only has 512mb storage, not enough room to run docker things
                    but docker is docker. i thought he specified a compose or command line
                    see this
                    https://forum.magicmirror.builders/topic/18952/docker-install-on-synology-nas
                      caw @sdetweil
                      @sdetweil @MMRIZE
                      so i got the khassel image running and i think the calendars are found but i get an error:
                      [2024-09-05 22:42:56.488] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Familien_20Kalender.ics’
                      2024/09/05 22:42:56 stderr [2024-09-05 22:42:56.486] [ERROR] Whoops! There was an uncaught exception…
                      do you have a clue how to fix this? im irritated by the “20” between Familien_20Kalender.ics thats no part of the calendar name…
                        sdetweil @caw
                        @caw 20 is typically part of a name with a space in it, %20
                        also you have a . (dot) in front of SYNOLOGY_
                          caw @sdetweil
                          and do you have any clue where the misstake is? and how can i fix it?
                            sdetweil @caw
                            @caw i am going to guess
                            remove the dot in front of SYNOLOGY
                            and in the MagicMirror config mke sure there is a space where you see the 20, or make it %20
                            one change at a time
                              caw @sdetweil
                              @sdetweil i dont have a dot in front of the Prefix
                              module :“MMM-CalDAV”,
                              servers: [
                              envPrefix: “SYNOLOGY_”,
                              2024/09/06 01:23:15 stderr path: ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                              2024/09/06 01:23:15 stderr syscall: ‘open’,
                              2024/09/06 01:23:15 stderr code: ‘EACCES’,
                              2024/09/06 01:23:15 stderr errno: -13,
                              2024/09/06 01:23:15 stderr at async saveIcs (/opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:76:7) {
                              2024/09/06 01:23:15 stderr at async Object.writeFile (node:internal/fs/promises:1212:14)
                              2024/09/06 01:23:15 stderr at async open (node:internal/fs/promises:639:25)
                              2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.709] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                              2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.707] [ERROR] Whoops! There was an uncaught exception…
                              2024/09/06 01:23:14 stderr at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                              2024/09/06 01:23:14 stderr at NodeHelper.checkFetchStatus (/opt/magic_mirror/js/node_helper.js:110:9)
                              2024/09/06 01:23:14 stderr [2024-09-06 01:23:14.687] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics Error: Not Found
                              2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.671] [LOG] [CALDAV] /opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics is not found.
                              2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.606] [LOG] Create new calendarfetcher for url: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics - Interval: 3600000
                              2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.539] [LOG] [CALDAV] Fetching SYNOLOGY_ : caldav …
                              S M karsten13K 3 Replies Last reply
                                sdetweil @caw
                                servers: [
                                i dont know what caldav wants in its setup,
                                sorry. you’ll have to wait for @MMRIZE to help
                                  MMRIZE @caw
                                  @caw
                                  I’m not familiar with the Docker setting. Anyway, it seems to be a permission issue. The docker container creation and execution might be performed by different accounts. Or you may need proper permission for those files or directories. However, I have no idea of Docker environment, so that’s all I can say.
                                  • karsten13K
                                    karsten13 @caw
                                    @caw
                                    how did you start the container? Please provide full docker run ... command or compose file.
                                      danny607
                                      Hello, I am new and wondering what do you name the file env.example to? Second What lines need to be added to the /config/config.js file?
                                        sdetweil @danny607
                                        @danny607 the env file name is typically
                                        .env
                                        note the leading dot
                                        the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
                                          @caw
                                          so looking at the code, this module will write out the constructed ICAL format data to
                                            const filePath = path.resolve(__dirname, 'service', '.' + fileName)
                                          notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
                                          SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
                                          in THIS module folder… but write to it…
                                          @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
                                          karsten13K 1 Reply Last reply
                                          • karsten13K
                                            karsten13 @sdetweil
                                            @sdetweil said in MMM-CalDAV:
                                            see docs
                                            rw: Read and write access. This is the default if none is specified.
                                            • 3 / 5
