    MMM-CalDAV
    97 Posts 10 Posters 51.7k Views 9 Watching
      caw @MMRIZE
      @MMRIZE said in MMM-CalDAV:
      Hi thank you very much for the really fast supply.
      the strange thing is that i configured it like you said. but if im running it the magicmirror it is showing me that the “Site is not reachable” (The Synology default page)
      if im running MM just without the CALDAV Module it´s working.
      I´m running the MM in Docker on the Synology.
        MMRIZE @caw
        @caw could you show me the capture of error message to know what happened?
          caw @MMRIZE
          @MMRIZE if i´m adding the
          		module :"MMM-CalDAV",
          			servers: [
          					envPrefix: "SYNOLOGY_",
          					serverUrl: "https://myownsynologyadress.de/caldav/",
          following error occurs
          M S 3 Replies Last reply Reply Quote 0
            MMRIZE @caw
            @caw said in MMM-CalDAV:
            I cannot understand the context. What did you do? The image seems like that something on the browser.
            Does your MagicMirror is executed on the Synology NAS with Docker?
              MMRIZE @caw
              module :“MMM-CalDAV”,
              servers: [
              envPrefix: “SYNOLOGY_”,
              serverUrl: “https://myownsynologyadress.de/caldav/”,
              And you’ve missed a closing brace in your code.
              			servers: [
                                               }, // <-- HERE
                caw @MMRIZE
                @MMRIZE yes the image is a screen from the browser. MM is running till i add the Caldav-Module. So i assume I missconfigured something. The missing bracket did not solve the problem in the log:
                2024/09/04 15:33:13 stderr if (key?.startsWith(prefix)) {
                2024/09/04 15:33:13 stderr [04.09.2024 15:33.13.728] [ERROR] /opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:14
                2024/09/04 15:33:13 stderr [04.09.2024 15:33.13.727] [ERROR] Whoops! There was an uncaught exception…
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.726] [LOG] No helper found for module: MMM-Carousel.
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.726] [LOG] No helper found for module: clock.
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] Module helper loaded: updatenotification
                2024/09/04 15:33:13 stderr at /opt/magic_mirror/js/app.js:166:6
                2024/09/04 15:33:13 stderr at loadNextModule (/opt/magic_mirror/js/app.js:164:5)
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] Initializing new module helper …
                2024/09/04 15:33:13 stderr at loadModule (/opt/magic_mirror/js/app.js:126:19)
                2024/09/04 15:33:13 stderr at require (internal/modules/cjs/helpers.js:74:18)
                2024/09/04 15:33:13 stderr at Module.require (internal/modules/cjs/loader.js:887:19)
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] No helper found for module: alert.
                2024/09/04 15:33:13 stderr at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                2024/09/04 15:33:13 stderr at Module.load (internal/modules/cjs/loader.js:863:32)
                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.724] [LOG] Loading module helpers …
                2024/09/04 15:33:13 stderr at Object.Module._extensions…js (internal/modules/cjs/loader.js:1027:10)
                2024/09/04 15:33:13 stderr at Module._compile (internal/modules/cjs/loader.js:963:27)
                2024/09/04 15:33:13 stderr at wrapSafe (internal/modules/cjs/loader.js:915:16)
                2024/09/04 15:33:13 stderr SyntaxError: Unexpected token ‘.’
                  sdetweil @caw
                  @caw because you are running in server mode, the version of nodejs matters.
                  your version is way down level
                  the ?. syntax shown on line 14 is from the latest js version
                    caw @sdetweil
                    @sdetweil thank you very much for the information - but now i have another problem to get it updated can you help me with this?
                      sdetweil @caw
                      @caw what environment are you running?
                        caw @sdetweil
                        @sdetweil im running the docker container on a Synology NAS
                          sdetweil @caw
                          @caw what docker container?
                            sdetweil @caw
                            https: means you have a certificate for that address and have configured MMM-Caldav to run in secure mode
                            is that true?
                            typically one uses mmm-caldav to read from the foreign calendar, and emit ics data for the local machine
                            and make it available thru a url request (which causes the MMM-Caldav module to provide the data live)
                            http://mmIP:mmPort/caldav
                            or shorthand for this same system is (using the default mm port)
                            http://localhost:8080/caldav
                            depending on how MM is configured,
                            address: and ipWhitelist, by default it rejects ALL requests from OUTSIDE systems
                            so your loop back at - https://myownsynologyadress.de would be rejected…
                            I use cloudflare to map outside requests to my systems thr a tunnel, so I have https (cert provided by cloudflare) and have reconfigured my MagicMirror to allow any incoming request
                            address: "0.0.0.0",
                            ipWhitelist:[],
                              caw @sdetweil
                              @sdetweil im running the “container manager” on the nas and the container by bastilimbach installation guide by https://mariushosting.com/how-to-install-magicmirror-on-your-synology-nas/
                                caw @sdetweil
                                @sdetweil i used ipv64 to receive a certificate - but for now i dont want to get any caldav from outside or do i missunderstand something?
                                  sdetweil @caw
                                  bastilimbach
                                  that image is 4 years old, so not running the latest node or MM…
                                  the install doc https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
                                  references this docker image
                                  https://gitlab.com/khassel/magicmirror
                                    sdetweil @caw
                                    @caw because the ics generated by MMM-Caldav is only needed on this same machine I would use
                                    http://localhost:mmport/CALDAV
                                    in the calendar module.
                                    I am guessing your cert is connected to your internet IP address (ISP router)
                                    which is then port forwarded to the MM machine…
                                    this is an external (from MM’s perspective) request
                                    MM is configured (be default) to be a closed system on the wall, not allowing any external systems to request the MM page (external means outside the machine MM is running on)
                                      caw @sdetweil
                                      @sdetweil i searched for a guide to get the Khassel container running on a Synology NAS but didn’t found anything about it. I tried it by my own but did not work. Do you have a clue how to get it on the Docker on a Synology NAS?
                                        sdetweil @caw
                                        @caw my older 416j only has 512mb storage, not enough room to run docker things
                                        but docker is docker. i thought he specified a compose or command line
                                        see this
                                        https://forum.magicmirror.builders/topic/18952/docker-install-on-synology-nas
                                          caw @sdetweil
                                          @sdetweil @MMRIZE
                                          so i got the khassel image running and i think the calendars are found but i get an error:
                                          [2024-09-05 22:42:56.488] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Familien_20Kalender.ics’
                                          2024/09/05 22:42:56 stderr [2024-09-05 22:42:56.486] [ERROR] Whoops! There was an uncaught exception…
                                          do you have a clue how to fix this? im irritated by the “20” between Familien_20Kalender.ics thats no part of the calendar name…
                                            sdetweil @caw
                                            @caw 20 is typically part of a name with a space in it, %20
                                            also you have a . (dot) in front of SYNOLOGY_
                                            • 2 / 5
