    MMM-CalDAV
    97 Posts 10 Posters 56.4k Views 9 Watching
      sdetweil @Tiller
      @Tiller can you show any of the output from
      npm start
      if using pm2 to autolaunch, then
      pm2 logs --lines=xxxx
      xxxx is the number of the most recent lines in the logs, default 15
      note that the log data will have full urls for calendar , so this could expose info
        MMRIZE @Tiller
        @Tiller said in MMM-CalDAV:
        CALDAV_SERVICE_USERNAME=
        For SYNOLOGY
        SYNOLOGY_username=username1
        SYNOLOGY_password=password1
        I think you may have confusing the username and password for the server and the module.
        This is for your Synology Caldav Server, usually it is your account id/password to login Synology Server (Or Synology calendar account)
        CALDAV_SERVICE_USERNAME=username2
        CALDAV_SERVICE_PASSWORD=password2
        This is a different thing. It is used for your MM calendar module. This module provide a secure calendar ics host by itself with this auth information. You should need to set your calendar config like this;
        // default calendar module.
                symbol: "calendar-check",
                url: "http://localhost:8080/CALDAV/SYNOLOGY_Family.ics",
                auth: { // REQUIRED
                  user: 'username2', // <= used here (CALDAV_SERVICE_USERNAME)
                  pass: 'password2', // <= used here (CALDAV_SERVICE_PASSWORD)
                  method: 'basic'
        • T
          Tiller @MMRIZE
          Thank you for your quick reply.
          @sdetweil I’m not using pm2 at the moment, but I could try to do it and check the logs.
          @MMRIZE sorry, my bad. I changed the password for the post, it’s correct in my .env but not working.
          I’m not exactly sure about the Synology url
          synology.com says I should use
          http://192.168.x.x:5000/caldav
          and than log in with my username and password
          But an older link is (seems there was an update)
          http://192.168.x.x:5000/caldav/username/ejialfjl/
          If I’m using the last one in the browser, it is downloading an .ics file.
          But it’s not working with both urls.
          Maybe I should try to reinstall everything?
          S M 3 Replies Last reply Reply Quote 0
            sdetweil @Tiller
            @Tiller if you are not using pm2 then the errors would be shown where you do npm start
              sdetweil @Tiller
              @Tiller no reinstall
              can you show us the new url(#2) in config.js,
              assume you are still using the env variables
                MMRIZE @Tiller
                @Tiller
                CalDAV is different to general ics hosting.
                Usually, the URL of Synology CalDAV accessing would be;
                https://IP_OR_URL:5001/caldav/
                http://IP_OR_URL:5000/caldav/
                Anyway, there would be some log to diagnosis. Can you show the frontend and backend logs?
                C T 2 Replies Last reply Reply Quote 0
                  caw @MMRIZE
                  @MMRIZE
                  i´ve got the same problem. I´m completly new to magicmirror but the integration of my Synology CalDAV should be the main part of it.
                  i´ve tried several combinations and addresses but no one worked for me.
                  maybe its possible to get a “step - by - step” Tutorial.
                  hopefully you can help :)
                    MMRIZE @caw
                    @caw
                    https://github.com/MMRIZE/MMM-CalDAV/wiki
                    1. Install
                    cd <Your MagicMirror directory>/modules
                    git clone https://github.com/MMRIZE/MMM-CalDAV
                    cd MMM-CalDAV
                    npm install
                    1. There would be .env (It would be hidden, so you should check it with ls -al or equivalent for your environment/OS)
                    If not there, copy it from env.example
                    cp env.example .env
                    1. Open your Synology Calendar. You can open it from your Synology Package Center Or installed app lists. Usually it will have http(s)://<IP_OR_URL>:<PORT(5000 or 5001)>/?launchApp=SYNO.Cal.Application as URL so you can open it on the browser.
                    You will see something like this.
                    1. Get the CadDAV account. Copy or memo the URL. Usually URL will have http(s)://<IP_OR_URL>:<PORT_5000_OR_5001>/caldav/ format.
                    1. Back to the terminal. Open the .env file with your favourite editor. Then, fulfil these lines.
                    2. Then configure the MMM-CalDAV module and the calendar module like this.
                    Carefully See the configuration of the calendar module.
                    1. Then run the MagicMirror.
                      At the very first execution, some time would be needed for CalDAV calendars to be reflected on the screen. So, just stop the MagicMirror.
                    If CalDAV calendars would be success to be derived, the log will say something like this.
                    [2024-09-03 22:52:01.461] [LOG]   [CALDAV] File: SYNOLOGY_test.ics is refreshed.
                    And there be files to be hosted in the service directory like these;
                    I have two calendars, My Calendar and test, so there would be 2 hidden ics files generated, service/.SYNOLOGY_My_20Calendar.ics and service/.SYNOLOGY_test.ics.
                    But the real URL consumed by the calendar module would be http://localhost:8080/CALDAV/SYNOLOGY_test.ics, don’t be confused.
                    1. Rerun the MM again. Now on the screen, your hosting calendar will be served.
                      caw @MMRIZE
                      @MMRIZE said in MMM-CalDAV:
                      Hi thank you very much for the really fast supply.
                      the strange thing is that i configured it like you said. but if im running it the magicmirror it is showing me that the “Site is not reachable” (The Synology default page)
                      if im running MM just without the CALDAV Module it´s working.
                      I´m running the MM in Docker on the Synology.
                        MMRIZE @caw
                        @caw could you show me the capture of error message to know what happened?
                          caw @MMRIZE
                          @MMRIZE if i´m adding the
                          		module :"MMM-CalDAV",
                          			servers: [
                          					envPrefix: "SYNOLOGY_",
                          					serverUrl: "https://myownsynologyadress.de/caldav/",
                          following error occurs
                          M S 3 Replies Last reply Reply Quote 0
                            MMRIZE @caw
                            @caw said in MMM-CalDAV:
                            I cannot understand the context. What did you do? The image seems like that something on the browser.
                            Does your MagicMirror is executed on the Synology NAS with Docker?
                              MMRIZE @caw
                              module :“MMM-CalDAV”,
                              servers: [
                              envPrefix: “SYNOLOGY_”,
                              serverUrl: “https://myownsynologyadress.de/caldav/”,
                              And you’ve missed a closing brace in your code.
                              			servers: [
                                                               }, // <-- HERE
                                caw @MMRIZE
                                @MMRIZE yes the image is a screen from the browser. MM is running till i add the Caldav-Module. So i assume I missconfigured something. The missing bracket did not solve the problem in the log:
                                2024/09/04 15:33:13 stderr if (key?.startsWith(prefix)) {
                                2024/09/04 15:33:13 stderr [04.09.2024 15:33.13.728] [ERROR] /opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:14
                                2024/09/04 15:33:13 stderr [04.09.2024 15:33.13.727] [ERROR] Whoops! There was an uncaught exception…
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.726] [LOG] No helper found for module: MMM-Carousel.
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.726] [LOG] No helper found for module: clock.
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] Module helper loaded: updatenotification
                                2024/09/04 15:33:13 stderr at /opt/magic_mirror/js/app.js:166:6
                                2024/09/04 15:33:13 stderr at loadNextModule (/opt/magic_mirror/js/app.js:164:5)
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] Initializing new module helper …
                                2024/09/04 15:33:13 stderr at loadModule (/opt/magic_mirror/js/app.js:126:19)
                                2024/09/04 15:33:13 stderr at require (internal/modules/cjs/helpers.js:74:18)
                                2024/09/04 15:33:13 stderr at Module.require (internal/modules/cjs/loader.js:887:19)
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.725] [LOG] No helper found for module: alert.
                                2024/09/04 15:33:13 stderr at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                2024/09/04 15:33:13 stderr at Module.load (internal/modules/cjs/loader.js:863:32)
                                2024/09/04 15:33:13 stdout [04.09.2024 15:33.13.724] [LOG] Loading module helpers …
                                2024/09/04 15:33:13 stderr at Object.Module._extensions…js (internal/modules/cjs/loader.js:1027:10)
                                2024/09/04 15:33:13 stderr at Module._compile (internal/modules/cjs/loader.js:963:27)
                                2024/09/04 15:33:13 stderr at wrapSafe (internal/modules/cjs/loader.js:915:16)
                                2024/09/04 15:33:13 stderr SyntaxError: Unexpected token ‘.’
                                  sdetweil @caw
                                  @caw because you are running in server mode, the version of nodejs matters.
                                  your version is way down level
                                  the ?. syntax shown on line 14 is from the latest js version
                                    caw @sdetweil
                                    @sdetweil thank you very much for the information - but now i have another problem to get it updated can you help me with this?
                                      sdetweil @caw
                                      @caw what environment are you running?
                                        caw @sdetweil
                                        @sdetweil im running the docker container on a Synology NAS
                                          sdetweil @caw
                                          @caw what docker container?
                                            sdetweil @caw
                                            https: means you have a certificate for that address and have configured MMM-Caldav to run in secure mode
                                            is that true?
                                            typically one uses mmm-caldav to read from the foreign calendar, and emit ics data for the local machine
                                            and make it available thru a url request (which causes the MMM-Caldav module to provide the data live)
                                            http://mmIP:mmPort/caldav
                                            or shorthand for this same system is (using the default mm port)
                                            http://localhost:8080/caldav
                                            depending on how MM is configured,
                                            address: and ipWhitelist, by default it rejects ALL requests from OUTSIDE systems
                                            so your loop back at - https://myownsynologyadress.de would be rejected…
                                            I use cloudflare to map outside requests to my systems thr a tunnel, so I have https (cert provided by cloudflare) and have reconfigured my MagicMirror to allow any incoming request
                                            address: "0.0.0.0",
                                            ipWhitelist:[],
                                            • 2 / 5
