    MMM-CalDAV
    97 Posts 10 Posters 57.7k Views 9 Watching
      caw @sdetweil
      @sdetweil im running the “container manager” on the nas and the container by bastilimbach installation guide by https://mariushosting.com/how-to-install-magicmirror-on-your-synology-nas/
        caw @sdetweil
        @sdetweil i used ipv64 to receive a certificate - but for now i dont want to get any caldav from outside or do i missunderstand something?
          sdetweil @caw
          @caw said in MMM-CalDAV:
          bastilimbach
          that image is 4 years old, so not running the latest node or MM…
          the install doc https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
          references this docker image
          https://gitlab.com/khassel/magicmirror
          C 1 Reply Last reply
            sdetweil @caw
            @caw because the ics generated by MMM-Caldav is only needed on this same machine I would use
            http://localhost:mmport/CALDAV
            in the calendar module.
            I am guessing your cert is connected to your internet IP address (ISP router)
            which is then port forwarded to the MM machine…
            this is an external (from MM’s perspective) request
            MM is configured (be default) to be a closed system on the wall, not allowing any external systems to request the MM page (external means outside the machine MM is running on)
              caw @sdetweil
              @sdetweil i searched for a guide to get the Khassel container running on a Synology NAS but didn’t found anything about it. I tried it by my own but did not work. Do you have a clue how to get it on the Docker on a Synology NAS?
                sdetweil @caw
                @caw my older 416j only has 512mb storage, not enough room to run docker things
                but docker is docker. i thought he specified a compose or command line
                see this
                https://forum.magicmirror.builders/topic/18952/docker-install-on-synology-nas
                  caw @sdetweil
                  @sdetweil @MMRIZE
                  so i got the khassel image running and i think the calendars are found but i get an error:
                  [2024-09-05 22:42:56.488] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Familien_20Kalender.ics’
                  2024/09/05 22:42:56 stderr [2024-09-05 22:42:56.486] [ERROR] Whoops! There was an uncaught exception…
                  do you have a clue how to fix this? im irritated by the “20” between Familien_20Kalender.ics thats no part of the calendar name…
                    sdetweil @caw
                    @caw 20 is typically part of a name with a space in it, %20
                    also you have a . (dot) in front of SYNOLOGY_
                      caw @sdetweil
                      and do you have any clue where the misstake is? and how can i fix it?
                        sdetweil @caw
                        @caw i am going to guess
                        remove the dot in front of SYNOLOGY
                        and in the MagicMirror config mke sure there is a space where you see the 20, or make it %20
                        one change at a time
                          caw @sdetweil
                          @sdetweil i dont have a dot in front of the Prefix
                          module :“MMM-CalDAV”,
                          servers: [
                          envPrefix: “SYNOLOGY_”,
                          2024/09/06 01:23:15 stderr path: ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                          2024/09/06 01:23:15 stderr syscall: ‘open’,
                          2024/09/06 01:23:15 stderr code: ‘EACCES’,
                          2024/09/06 01:23:15 stderr errno: -13,
                          2024/09/06 01:23:15 stderr at async saveIcs (/opt/magic_mirror/modules/MMM-CalDAV/node_helper.js:76:7) {
                          2024/09/06 01:23:15 stderr at async Object.writeFile (node:internal/fs/promises:1212:14)
                          2024/09/06 01:23:15 stderr at async open (node:internal/fs/promises:639:25)
                          2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.709] [ERROR] Error: EACCES: permission denied, open ‘/opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics’
                          2024/09/06 01:23:15 stderr [2024-09-06 01:23:15.707] [ERROR] Whoops! There was an uncaught exception…
                          2024/09/06 01:23:14 stderr at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          2024/09/06 01:23:14 stderr at NodeHelper.checkFetchStatus (/opt/magic_mirror/js/node_helper.js:110:9)
                          2024/09/06 01:23:14 stderr [2024-09-06 01:23:14.687] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics Error: Not Found
                          2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.671] [LOG] [CALDAV] /opt/magic_mirror/modules/MMM-CalDAV/service/.SYNOLOGY_Simon.ics is not found.
                          2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.606] [LOG] Create new calendarfetcher for url: http://localhost:8080/CALDAV/SYNOLOGY_Simon.ics - Interval: 3600000
                          2024/09/06 01:23:14 stdout [2024-09-06 01:23:14.539] [LOG] [CALDAV] Fetching SYNOLOGY_ : caldav …
                          S M karsten13K 3 Replies Last reply
                            sdetweil @caw
                            servers: [
                            i dont know what caldav wants in its setup,
                            sorry. you’ll have to wait for @MMRIZE to help
                              MMRIZE @caw
                              @caw
                              I’m not familiar with the Docker setting. Anyway, it seems to be a permission issue. The docker container creation and execution might be performed by different accounts. Or you may need proper permission for those files or directories. However, I have no idea of Docker environment, so that’s all I can say.
                              • karsten13K
                                karsten13 @caw
                                @caw
                                how did you start the container? Please provide full docker run ... command or compose file.
                                  danny607
                                  Hello, I am new and wondering what do you name the file env.example to? Second What lines need to be added to the /config/config.js file?
                                    sdetweil @danny607
                                    @danny607 the env file name is typically
                                    .env
                                    note the leading dot
                                    the linux file systems do not have a flag for hidden, so by convention anything with a leading . (dot) will not be shown in file lists unless explicitly requested
                                      @caw
                                      so looking at the code, this module will write out the constructed ICAL format data to
                                        const filePath = path.resolve(__dirname, 'service', '.' + fileName)
                                      notice the dot… in linux =by convention, file/folder names that start with dot are not shown unless explicitly requested… (making them hidden ‘most’ of the time
                                      SO, the code above is trying to USE a directory ‘service’ (part of this module repo)
                                      in THIS module folder… but write to it…
                                      @karsten13 is the docker volume for where modules are located mapped read/write?? (the compose file doesn’t say)
                                      karsten13K 1 Reply Last reply
                                      • karsten13K
                                        karsten13 @sdetweil
                                        @sdetweil said in MMM-CalDAV:
                                        see docs
                                        rw: Read and write access. This is the default if none is specified.
                                          sdetweil @karsten13
                                          @karsten13 thats what I thought
                                          @caw can you ssh logon to your synology and execute a docker command
                                          docker inspect  magicmirror
                                          scroll up to look at the mounts section
                                          (this is from a different container, as I don’t have one running MM)
                                          Mounts": [
                                                          "Type": "volume",
                                                          "Name":
                                          "94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919",
                                                          "Source": "/var/lib/docker/volumes/94f89b1076c681a8dd32a7863d7a867e2077849f0fc53091062aae3797433919/_data",
                                                          "Destination": "/config",    <---- check for /opt/magic_mirror/modules
                                                          "Driver": "local",
                                                          "Mode": "",
                                                          "RW": true,    <------------    check this , should be true
                                                          "Propagation": ""
                                          also, how (from where, as what userid?) did you git clone the module, and npm install?
                                          another docker command
                                          docker exec magicmirror ls /opt/magic_mirror/modules -laF
                                            caw @karsten13
                                            @karsten13
                                            i used:
                                            docker run -d --user root --name magicmirror
                                            -p 8036:8080
                                            -v /volume1/docker/magicmirror/config:/opt/magic_mirror/config
                                            -v /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
                                            -v /volume1/docker/magicmirror/customcss:/opt/magic_mirror/customcss
                                            -e TZ=Europe/Berlin
                                            –restart always
                                            registry.gitlab.com/khassel/magicmirror
                                            • 3 / 5
