    MMM-CalDAV
    97 Posts 10 Posters 32.6k Views 9 Watching
    • G Offline
      GregoryWest @sdetweil
      @sdetweil WOW its working!!! Thanks for your patience. Looking good. Something just occured to me. Can I do this with multiple users/calendars? The plan is for 5 calendars to be on the screen, they are all coming from the same SoGo server.
        sdetweil @GregoryWest
        @gregorywest that I do not know
        • G Offline
          @sdetweil I noticed a different issue now. I was updating my calendar in SoGo, but none of the updates are showing up on MMM. This is even the case after a reboot of MMM.
          The problem of the multiple calendars might be a show stopper. Will keep muddling through this.
          Greg
            @gregorywest ok, for multiple cals, u use another instance of the module in config.js
            his doc shows that…
            update? should be the updateInterval parm… default 15 mins it says
              MMRIZE @GregoryWest
              Thanks your kind help. I was absent for days. So I couldn’t support this issue.
              @GregoryWest
              When you want to get several calendars(or accounts), just add this module again in your config.
              And to refresh calendar, wait updateInterval.
              And with rebooting, usually last result will be shown after reboot.(CalDAV parsing is quite slow ). Generally it will take updateInterval after reboot, the change will be displayed.
                MMRIZE @GregoryWest
                @gregorywest said in MMM-CalDAV:
                What you want is;
                • 5 CalDAV calendars from one account (It has more than 5 calendars) as one iCal Calendar : Just use calendarFilter
                • 5 CalDAV calendaras from one account as 5 iCal Calendars: Use this module 5 times with calendarFilter
                • 5 CalDAV calendars from several accounts as one summarized iCal Calendar : Sorry, impossible with this module.
                • 5 CalDav calendars from several accounts as 5 iCal Calendars : Use method 2.
                  MMRIZE
                  UPDATE 2.0.0
                  • Newly rebuilt from scratch
                  • OAUTH supported (For Google Calendar)
                  • Multi servers/calendars in one module.
                  • more secure and efficiently
                  Now, you can use Google Calendar in the default calendar module(and more).
                  https://github.com/MMRIZE/MMM-CalDAV
                    MMRIZE @Guest
                    @matt216
                    More details about your environment are needed to know what happens.
                    Let’s start with the concept.
                    Some CALDAV Providers don’t serve any public iCAL(.ics) URL to be consumed externally. You don’t need this module if your CALDAV service can host iCAL URLs. I have no idea about baikal, but I think you know whether that service would provide iCAL or not.
                    MMM-CALDAV can access the CALDAV server(which would not host any public iCAL URL) to get target calendar events. Then, this module converts the event data to a real iCAL file(.ics). And this module also hosts that file as a URL accessible from the default calendar module or some iCAL consuming modules with security. MMM-CALDAV will work like a private iCAL provider service.
                    So, to show your event on MM, you may need both MMM-CALDAV and calendar module together.
                    .env file is needed to connect/authenticate CALDAV server and some security features. Calendar events are very private so I want to block the security hole on working this module. You should put .env in MMM-CALDAV directory.
                    So, where are you stuck now? Tell me what happens.
                      matt216 @MMRIZE
                      @MMRIZE Thank you for your help, but I managed to figure out getting baikal to generate the ics file, so I don’t need this module anymore.
                      Thanks anyway
                        MMRIZE
                        Update 2.1.0
                        • Birthday calendar enabled. (CardDAV implementation)
                        • Some code refactoring.
                        • calendars: [], is changed to targets: []. you have to reconfigure your config.js
                        Now you can get Birthdays calendar from iCloud or Google Contacts. (Of course, other CardDAV supported contacts services.)
                        • 9
                        • 10
                        • 2 / 10
