    Strange behavior TV / Browser & MMM-Carousel Slides are being ignored
    12 Posts 4 Posters 2.2k Views 3 Watching
    • W Offline
      wageck Project Sponsor
      Hello all,
      unfortunately I do not get on and need some help or tips.
      The goal is to distribute several calendar and todo modules on several pages.
      Unfortunately the Calendar and Todo modules do not reliably load the ical files on the TV via HDMI, most of the time it says Loading instead of the content.
      But using the browser in parallel the entries are loaded
      Additionally MMM-Carousel doesn’t seem to load the Slides, instead all modules end up on one page.
      I hope I have the most important info attached, if something is missing I’ll be happy to supply you with it.
      MagicMirror runs on a Raspberry 4
      Installed with MagicMirrorOS in version MagicMirror: v2.16.0
      I will add a post with log / config.js / screenshots in a minute.
      • W Offline
        wageck Project Sponsor @wageck
        Used Modules
        Screenshot Custom CSS in Browser
        Screenshot Custom CSS on TV
        Screenshot default CSS in Browser
        Screenshot default CSS on TV
        • W Offline
          config.js
          /* Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * !! ACHTUNG Die config.js.template muss bearbeitet werden !!
           * Link zur CSS Aufteilung: https://forum.magicmirror.builders/topic/286/regions
          var config = {
          	address: "0.0.0.0", 	// Address to listen on, can be:
          	port: 8080,					// Default 8080
          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: [], 	// Set [] to allow all IP addresses ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.0/24"]
          	language: "de",
          	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          	timeFormat: 24,
          	units: "metric",
          	// serverOnly: true/false/"local" ,
          	// starts serveronly and then starts chrome browser
          // Beginn: Modul um die Aktuelle Page in der Übersicht anzuzeigen
           module: "MMM-page-indicator",
           //pages: {all: "bottom_center"},
          		position: "bottom_center",
          		carouselId: "510"
          // Ende: Modul um die Aktuelle Page in der Übersicht anzuzeigen
          // Beginn: Motivationstext
          	module: "helloworld",
          	//pages: {"all": "top_center"},
          	position: "top_center",
          		carouselId: "520",
          		text: "Motivation juhu"
          // Ende: Motivationstext
          // Begin: Modul zur Wetter INformation:
          	module: "currentweather",
          	header: "Heute",
          		carouselId: "530",
          		locationID: "2891480", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          		appid: "daf92bc5adeb64ee90406481ab2289b0",
          		units: "metric",
          		degreeLabel: true,
          		timeFormat: "24",
          		lang: "de"
          	module: "weatherforecast",
          	header: "Vorhersage",
          		carouselId: "540",
          		units: "metric",
          		degreeLabel: true,
          		timeFormat: "24",
          		lang: "de"
          // Ende: Modul zur Wetter INformation:
          // Begin: Modul um RSS Feeds einzubinden: alle Seiten
          	module: "newsfeed",
          	//pages: {all: "bottom_bar"},
          	position: "bottom_bar",
          	header: "News",
          		carouselId: "550",
          		showSourceTitle: true,
          		showPublishDate: true,
          		showAsList: true,
          		maxNewsItems: 4,
          		ignoreOldItems: true,
          		ignoreOlderThan: 604800000,
          			feeds: [
          					title: "Weierhof",
          					url: "https://www.weierhof.de/feed/"
          					title: "Webindividualschule",
          					url: "http://fetchrss.com/rss/6146348142e4574b423ea3c26146346d1410593c18432932.xml"
          // Ende: Modul um RSS Feeds einzubinden: Alle Seiten
          // Begin: Modul um Tasks per webcal auszulesen für die nächsten 1 Tage
          			module: "MMM-ToDo",
          			header: "Familie Heute",
          			//pages: {FamilieHeute: "top_left"},
          				carouselId: "10",
          				maximumEntries: 14,
          				maximumNumberOfDays: 1,
          				broadcastEvents: false,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				fetchInterval: 150000,
          				hidePrivate: false,
          				hideCompleted: true,
          				showLocation: false,
          				fade: false,
          				colored: false,
          				coloredSymbolOnly: false,
          				displaySymbol: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics",
          			module: "MMM-ToDo",
          			header: "Papa Heute",
          			//pages: {PapaHeute: "top_left"},
          				carouselId: "11",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics",
          			module: "MMM-ToDo",
          			header: "Aufgaben Mama Heute",
          			//pages: {MamaHeute: "top_left"},
          				carouselId: "12",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics",
          			module: "MMM-ToDo",
          			header: "Aufgaben Leon Heute",
          			//pages: {LeonHeute: "top_left"},
          				carouselId: "13",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics",
          			module: "MMM-ToDo",
          			header: "Aufgaben Silas Heute",
          			//pages: {SilasHeute: "top_left"},
          				carouselId: "14",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics",
          			module: "MMM-ToDo",
          			header: "Aufgaben Samuel",
          			//pages: {SamuelHeute: "top_left"},
          				carouselId: "15",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics",
          			module: "MMM-ToDo",
          			header: "Offene Aufgaben",
          			//pages: {Offen: "top_right"},
          				carouselId: "16",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen.ics",
          			module: "MMM-ToDo",
          			header: "Offene wichtige und dringende Aufgaben",
          			//pages: {Offen: "top_left"},
          				carouselId: "17",
          				maximumEntries: 14,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen-wichtig.ics",
          // Ende: Modul um Tasks per webcal auszulesen für die nächsten 1 Tage
          // Begin: Modul um Tasks per webcal auszulesen für die nächsten 7 Tage
          			module: "MMM-ToDo",
          			header: "Aufgaben diese Woche",
          			//pages: {FamilieHeute: "bottom_left"},
          			position: "bottom_left",
          				carouselId: "20",
          				maximumEntries: 11,
          				maximumNumberOfDays: 7,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			module: "MMM-ToDo",
          			//pages: {PapaHeute: "bottom_left"},
          				carouselId: "21",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			module: "MMM-ToDo",
          			//pages: {MamaHeute: "bottom_left"},
          				carouselId: "22",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			module: "MMM-ToDo",
          			//pages: {LeonHeute: "bottom_left"},
          				carouselId: "23",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			module: "MMM-ToDo",
          			//pages: {SilasHeute: "bottom_left"},
          				carouselId: "24",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			module: "MMM-ToDo",
          			//pages: {SamuelHeute: "bottom_left"},
          				carouselId: "25",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: false,
          				fade: false,
          				colored: false,
          				calendars: 	[
          // Ende: Modul um Tasks per webcal auszulesen für die nächsten 7 Tage
          // Begin: Modul um Termine auszulesen für die nächsten 1 Tage
          			header: "Termine Familie Heute",
          			//pages: {FamilieHeute: "top_right"},
          				carouselId: "30",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				excludedEvents: ["Abgesagt:"],
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie_cal.ics",
          			header: "Termine Mama Heute",
          			//pages: {MamaHeute: "top_right"},
          				carouselId: "31",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama_cal.ics",
          			header: "Termine Papa Heute",
          			//pages: {PapaHeute: "top_right"},
          				carouselId: "32",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa_cal.ics",
          			header: "Termine Leon Heute",
          			//pages: {LeonHeute: "top_right"},
          				carouselId: "33",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon_cal.ics",
          			header: "Termine Silas Heute",
          			//pages: {SilasHeute: "top_right"},
          				carouselId: "34",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas_cal.ics",
          			header: "Termine Samuel Heute",
          			//pages: {SamuelHeute: "top_right"},
          				carouselId: "35",
          				maximumEntries: 11,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel_cal.ics",
          // Ende: Modul um Termine auszulesen für die nächsten 1 Tage
          // Begin: Modul um Termine auszulesen für die nächsten 7 Tage
          			header: "Termine diese Woche",
          			//pages: {FamilieHeute: "bottom_right"},
          			position: "bottom_right",
          				carouselId: "40",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			//pages: {MamaHeute: "bottom_right"},
          				carouselId: "41",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			//pages: {PapaHeute: "bottom_right"},
          				carouselId: "42",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			//pages: {LeonHeute: "bottom_right"},
          				carouselId: "43",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			//pages: {SilasHeute: "bottom_right"},
          				carouselId: "44",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          			//pages: {SamuelHeute: "bottom_right"},
          				carouselId: "45",
          				maximumEntries: 12,
          				maxTitleLength: 50,
          				wrapEvents: false,
          				maxTitleLines: 1,
          				hidePrivate: true,
          				hideOngoing: true,
          				fade: false,
          				colored: false,
          				calendars: 	[
          // Ende: Modul um Termine auszulesen für die nächsten 7 Tage
          // Beginn: Modul für die Fernsteuerung per Webrowser
           module: 'MMM-Remote-Control',
           // uncomment the following line to show the URL of the remote control on the mirror
           // position: "top_bar",
           // you can hide this module afterwards from the remote control itself
          		carouselId: "680",
           customCommand: {}, // Optional, See "Using Custom Commands" below
           showModuleApiMenu: true, // Optional, Enable the Module Controls menu
           secureEndpoints: false, // Optional, See API/README.md
           // uncomment any of the lines below if you're gonna use it
           customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
          	// apiKey: "", // Optional, See API/README.md for details
           // classes: {} // Optional, See "Custom Classes" below
          // Ende: Modul für die Fernsteuerung per Webrowser
          // Beginn: Modul das Bewegung über die Kamera erkennt
           module: 'MMM-SleepWake',
          	// pages: {all: "bottom_bar"},
          	config:{
           carouselId: "690",
          	 delay: '14', // amount of time with no motion before sleeping, in minutes
           mode: 'PI',
           pi_on: 'wget http://192.168.1.241:8083/fhem?cmd=set%20FamilienplanerTV%20on -O /dev/null',
           pi_off: 'wget http://192.168.1.241:8083/fhem?cmd=set%20FamilienplanerTV%20off -O /dev/null'
          // Ende: Modul das Bewegung über die Kamera erkennt
          // Beginn: Modul zur Nutzung mehrere Pages
           module: 'MMM-Carousel',
           //position: 'bottom_bar', // Required only for navigation controls
           transitionInterval: 30000,
           slideTransitionSpeed: 1500,
           showPageIndicators: false,
           showPageControls: false,
           ignoreModules: ['MMM-SleepWake'],
           //mode: 'global'
           mode: 'slides',
           slides: {
           main: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId: "10"},
          				{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId: "20"},
          				{name:'calendar', classes:'', position:"top_right", carouselId: "30"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId: "40"},
          				{name:'helloworld', classes:'', position:"top_center",carouselId:"520"},
          				{name:'MMM-page-indicator', classes:'', position:"bottom_center",carouselId: "510"},
          				{name:'newsfeed', classes:'', position:"bottom_bar",carouselId:"550"},
          				{name:'currentweather', classes:'', position:"bottom_center",carouselId: "530"},
          				{name:'weatherforecast', position:"bottom_center",carouselId: "540"}],
          Seite2: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId: "11"},
          				{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId: "21"},
          				{name:'calendar', classes:'', position:"top_right", carouselId: "31"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId: "41"},
          				{name:'helloworld', classes:'', position:"top_center",carouselId: "520"},
          				{name:'newsfeed', classes:'', position:"bottom_bar",carouselId: "550"},
          				{name:'weatherforecast', classes:'', position:"bottom_center",carouselId: "540"}],
          Seite3: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId: "12"},
          				{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId: "22"},
          				{name:'calendar', classes:'', position:"top_right", carouselId: "32"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId: "42"},
          Seite4: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId: "13"},
          				{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId: "23"},
          				{name:'calendar', classes:'', position:"top_right", carouselId: "33"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId: "43"},
          Seite5: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId: "14"},
          	 			{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId: "24"},
          				{name:'calendar', classes:'', position:"top_right", carouselId: "34"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId: "44"},
          Seite6: [ {name:'MMM-ToDo', classes:'', position:"top_left", carouselId:"15"},
          				{name:'MMM-ToDo', classes:'', position:"bottom_left", carouselId:"25"},
          				{name:'calendar', classes:'', position:"top_right", carouselId:"35"},
          				{name:'calendar', classes:'', position:"bottom_right", carouselId:"45"},
          				{name:'MMM-page-indicator', classes:'', position:"bottom_center",carouselId:"510"},
          				{name:'currentweather', classes:'', position:"bottom_center",carouselId:"530"},
          				{name:'weatherforecast', classes:'', position:"bottom_center",carouselId:"540"}],
          Seite7: [ {name:'MMM-ToDo',classes:'',position:"top_left",carouselId:"16"},
          				{name:'MMM-ToDo',classes:'',position:"bottom_left",carouselId:"17"},
          				{name:'calendar',classes:'',position:"top_right",carouselId:"30"},
          				{name:'calendar',classes:'',position:"bottom_right",carouselId:"40"},
          				{name:'helloworld',classes:'',position:"top_center",carouselId:"520"},
          				{name:'MMM-page-indicator',classes:'',position:"bottom_center",carouselId:"510"},
          				{name:'newsfeed',classes:'',position:"bottom_bar",carouselId:"550"},
          				{name:'currentweather',classes:'',position:"bottom_center",carouselId:"530"},
          				{name:'weatherforecast',classes:'',position:"bottom_center",carouselId:"540"}]
          // Ende: Modul zur Nutzung mehrere Pages
          // Ende: aller Module
          • W Offline
            main.css
            :root {
              --color-text: #999;
              --color-text-dimmed: #666;
              --color-text-bright: #fff;
              --color-background: #000;
              --font-primary: "Roboto Condensed";
              --font-secondary: "Roboto";
              --font-size: 20px;
              --font-size-small: 0.75rem;
              --gap-body-top: 60px;
              --gap-body-right: 60px;
              --gap-body-bottom: 60px;
              --gap-body-left: 60px;
              --gap-modules: 30px;
            html {
              cursor: none;
              overflow: hidden;
              background: var(--color-background);
              user-select: none;
              font-size: var(--font-size);
            ::-webkit-scrollbar {
              display: none;
            body {
              margin: var(--gap-body-top) var(--gap-body-right) var(--gap-body-bottom) var(--gap-body-left);
              position: absolute;
              height: calc(100% - var(--gap-body-top) - var(--gap-body-bottom));
              width: calc(100% - var(--gap-body-right) - var(--gap-body-left));
              color: var(--color-text);
              font-family: var(--font-primary), sans-serif;
              font-weight: 400;
              line-height: 1.5;
              -webkit-font-smoothing: antialiased;
             * Default styles.
            .dimmed {
              color: var(--color-text-dimmed);
            .normal {
            .bright {
              color: var(--color-text-bright);
            .xsmall {
              font-size: var(--font-size-small);
              line-height: 1.275;
            .small {
              font-size: 1rem;
              line-height: 1.25;
            .medium {
              font-size: 1.5rem;
              line-height: 1.225;
            .large {
              font-size: 3.25rem;
              line-height: 1;
            .xlarge {
              font-size: 3.75rem;
              line-height: 1;
              letter-spacing: -3px;
            .thin {
              font-family: var(--font-secondary), sans-serif;
              font-weight: 100;
            .light {
              font-weight: 300;
            .regular {
              font-weight: 400;
            .bold {
              font-weight: 700;
            .align-right {
              text-align: right;
            .align-left {
              text-align: left;
            header {
              text-transform: uppercase;
              font-family: var(--font-primary), Arial, Helvetica, sans-serif;
              font-weight: 400;
              border-bottom: 1px solid var(--color-text-dimmed);
              line-height: 15px;
              padding-bottom: 5px;
              margin-bottom: 10px;
            sup {
              font-size: 50%;
              line-height: 50%;
             * Module styles.
            .module {
              margin-bottom: var(--gap-modules);
            .region.bottom .module {
              margin-top: var(--gap-modules);
              margin-bottom: 0;
            .no-wrap {
              white-space: nowrap;
              overflow: hidden;
              text-overflow: ellipsis;
            .pre-line {
              white-space: pre-line;
             * Region Definitions.
            .region {
              position: absolute;
            .region.fullscreen {
              position: absolute;
              top: calc(-1 * var(--gap-body-top));
              left: calc(-1 * var(--gap-body-left));
              right: calc(-1 * var(--gap-body-right));
              bottom: calc(-1 * var(--gap-body-bottom));
              pointer-events: none;
            .region.fullscreen * {
              pointer-events: auto;
            .region.right {
              right: 0;
              text-align: right;
            .region.top {
              top: 0;
            .region.top.center,
            .region.bottom.center {
              left: 50%;
              transform: translateX(-50%);
            .region.top.right,
            .region.top.left,
            .region.top.center {
              top: 100%;
            .region.bottom {
              bottom: 0;
            .region.bottom.right,
            .region.bottom.center,
            .region.bottom.left {
              bottom: 100%;
            .region.bar {
              width: 100%;
              text-align: center;
            .region.third,
            .region.middle.center {
              width: 100%;
              text-align: center;
              transform: translateY(-50%);
            .region.upper.third {
              top: 33%;
              top: 50%;
            .region.lower.third {
              top: 66%;
            .region.left {
              text-align: left;
            .region table {
              width: 100%;
              border-spacing: 0;
              border-collapse: separate;
            custom.css
            :root {
              --gap-body-top: -3px;
              --gap-body-right: 0px;
              --gap-body-bottom: -30px;
              --gap-body-left: 0px;
              --gap-modules: 5px;
              --color-background: blue;
              --color-text: #fff;
              --color-text-dimmed: #fff;
            .xsmall {
              font-size: 45px;
              line-height: 45px;
            .small {
              font-size: 55px;
              line-height: 60px;
            .medium {
              font-size: 75px;
              line-height: 80px;
            .large {
              font-size: 140px;
              line-height: 145px;
            .xlarge {
              font-size: 165px;
              line-height: 170px;
            header {
              font-size: 55px;
              font-weight: 400;
              line-height: 60px;
              padding-bottom: 0px;
              margin-bottom: 0px;
            .html {
             /*background:red;*/
             /*overflow:visible;*/
            .body {
             /*background:blue;*/
             margin: 0;
            .region {
            /*outline: #fff solid;*/
            .region.bottom.bar .container .module.newsfeed {
                height: 520px; /*480 height of the module with maximum lines possible */
            .newsfeed .bright.medium.light {
              font-size: 52px;
              line-height: 70px;
            .newsfeed-list {
              list-style: none;
              text-align: center;
            .newsfeed-list li {
              text-align: justify;
              margin-bottom: 0.5em;
              text-align: center;
            .region.top.right,
            .region.top.left,
              width: 1280px;
              height: 960px;
              width: 1280px;
              height: 750px;
            .region.bottom.center .container .module.MMM-page-indicator {
              margin-bottom: 5;
              font-size: 80px;
              line-height: 85px;
            .currentweather .large {
              font-size: 60px;
              line-height: 65px;
            docker-compose.yml
            version: '3'
            services:
              magicmirror:
                container_name: mm
                image: karsten13/magicmirror:latest
                volumes:
                  - ../mounts/config:/opt/magic_mirror/config
                  - ../mounts/modules:/opt/magic_mirror/modules
                  - ../mounts/css:/opt/magic_mirror/css
                  - /etc/timezone:/etc/timezone:ro
                  - /etc/localtime:/etc/localtime:ro
                  - /tmp/.X11-unix:/tmp/.X11-unix
                  - /opt/vc:/opt/vc/:ro
                  - /run/udev:/run/udev:ro
                devices:
                  - /dev/vchiq
                  - /dev/input/btremote
                environment:
                  LD_LIBRARY_PATH: /opt/vc/lib
                  DISPLAY: unix:0.0
                  TZ: "Europe/Berlin"
                  timezone: "Europe/Berlin"
                  MM_OVERRIDE_DEFAULT_MODULES: "false"
                  MM_OVERRIDE_CSS: "false"
                  ELECTRON_ENABLE_LOGGING=true
                network_mode: host
                shm_size: "512mb"
                restart: unless-stopped
                command:
                  - npm
                  - run
                  - start debug
            • W Offline
              docker startup Log
              root@Familienboard:~# docker stop mm ;docker start mm ; docker logs -n 20 -f mm
              mm
              mm
              [10.10.2021 15:35.00.596] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:35.00.597] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
              [10.10.2021 15:35.00.628] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:35.02.554] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
              [10.10.2021 15:37.00.438] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics
              [10.10.2021 15:37.00.471] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics
              [10.10.2021 15:37.00.498] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics
              [10.10.2021 15:37.00.531] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics
              [10.10.2021 15:37.00.577] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics
              [10.10.2021 15:37.00.596] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics
              [10.10.2021 15:37.00.606] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen.ics
              [10.10.2021 15:37.00.614] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen-wichtig.ics
              [10.10.2021 15:37.00.625] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics
              [10.10.2021 15:37.00.635] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics
              [10.10.2021 15:37.00.649] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics
              [10.10.2021 15:37.00.660] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics
              [10.10.2021 15:37.00.673] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics
              [10.10.2021 15:37.00.689] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics
              renamed '/opt/magic_mirror/config/config.js' -> '/opt/magic_mirror/config/config.js-old'
              chown modules and config folder ...
              timezone is Europe/Berlin
              sh: 1: cannot create /etc/timezone: Read-only file system
              start magicmirror
              > magicmirror@2.16.0 start /opt/magic_mirror
              [10.10.2021 15:37.18.186] [LOG]   Starting MagicMirror: v2.16.0
              [10.10.2021 15:37.18.193] [LOG]   Loading config ...
              [10.10.2021 15:37.18.204] [LOG]   Loading module helpers ...
              [10.10.2021 15:37.18.207] [LOG]   No helper found for module: MMM-page-indicator.
              [10.10.2021 15:37.18.209] [LOG]   No helper found for module: helloworld.
              [10.10.2021 15:37.18.217] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.219] [LOG]   Module helper loaded: currentweather
              [10.10.2021 15:37.18.223] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.224] [LOG]   Module helper loaded: weatherforecast
              [10.10.2021 15:37.18.272] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.273] [LOG]   Module helper loaded: newsfeed
              [10.10.2021 15:37.18.377] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.379] [LOG]   Module helper loaded: MMM-ToDo
              [10.10.2021 15:37.18.402] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.403] [LOG]   Module helper loaded: calendar
              [10.10.2021 15:37.18.677] [LOG]   Initializing new module helper ...
              [10.10.2021 15:37.18.678] [LOG]   Module helper loaded: MMM-Remote-Control
              [10.10.2021 15:37.18.682] [LOG]   handler helper in init
              [10.10.2021 15:37.18.683] [LOG]   Module helper loaded: MMM-SleepWake
              [10.10.2021 15:37.18.685] [LOG]   No helper found for module: MMM-Carousel.
              [10.10.2021 15:37.18.686] [LOG]   All module helpers loaded.
              [10.10.2021 15:37.18.788] [LOG]   Starting server on port 8080 ...
              [10.10.2021 15:37.18.795] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [10.10.2021 15:37.18.803] [LOG]   Server started ...
              [10.10.2021 15:37.18.805] [LOG]   Connecting socket for: currentweather
              [10.10.2021 15:37.18.806] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
              [10.10.2021 15:37.18.807] [LOG]   Connecting socket for: weatherforecast
              [10.10.2021 15:37.18.809] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
              [10.10.2021 15:37.18.810] [LOG]   Connecting socket for: newsfeed
              [10.10.2021 15:37.18.811] [LOG]   Starting node helper for: newsfeed
              [10.10.2021 15:37.18.812] [LOG]   Connecting socket for: MMM-ToDo
              [10.10.2021 15:37.18.814] [LOG]   Starting node helper for: MMM-ToDo
              [10.10.2021 15:37.18.815] [LOG]   Connecting socket for: calendar
              [10.10.2021 15:37.18.816] [LOG]   Starting node helper for: calendar
              [10.10.2021 15:37.18.817] [LOG]   Connecting socket for: MMM-Remote-Control
              [10.10.2021 15:37.18.819] [LOG]   Starting node helper for: MMM-Remote-Control
              [10.10.2021 15:37.18.827] [LOG]   Connecting socket for: MMM-SleepWake
              [10.10.2021 15:37.18.829] [LOG]   handler helper in start
              [10.10.2021 15:37.18.830] [LOG]   Sockets connected & modules started ...
              [10.10.2021 15:37.19.085] [LOG]   Launching application.
              [10.10.2021 15:37.24.078] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics - Interval: 150000
              [10.10.2021 15:37.24.111] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics - Interval: 150000
              [10.10.2021 15:37.24.119] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics - Interval: 150000
              [10.10.2021 15:37.24.126] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics - Interval: 150000
              [10.10.2021 15:37.24.139] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics - Interval: 150000
              [10.10.2021 15:37.24.169] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen.ics - Interval: 150000
              [10.10.2021 15:37.24.884] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen-wichtig.ics - Interval: 150000
              [10.10.2021 15:37.24.895] [LOG]   Create new TODOCALENDAR fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics - Interval: 150000
              [10.10.2021 15:37.24.909] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics
              [10.10.2021 15:37.24.932] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics
              [10.10.2021 15:37.25.007] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics
              [10.10.2021 15:37.25.026] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics
              [10.10.2021 15:37.25.128] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics
              [10.10.2021 15:37.25.249] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.262] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.272] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.351] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.361] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.400] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie_cal.ics - Interval: 150000
              [10.10.2021 15:37.25.814] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama_cal.ics - Interval: 150000
              [10.10.2021 15:37.26.126] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa_cal.ics - Interval: 150000
              [10.10.2021 15:37.26.320] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.358] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.376] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.443] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon_cal.ics - Interval: 150000
              [10.10.2021 15:37.26.461] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas_cal.ics - Interval: 150000
              [10.10.2021 15:37.26.476] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel_cal.ics - Interval: 150000
              [10.10.2021 15:37.26.530] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.571] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.634] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.669] [LOG]   Create new newsfetcher for url: https://www.weierhof.de/feed/ - Interval: 300000
              [10.10.2021 15:37.26.710] [LOG]   Create new newsfetcher for url: http://fetchrss.com/rss/6146348142e4574b423ea3c26146346d1410593c18432932.xml - Interval: 300000
              [10.10.2021 15:37.26.763] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.843] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.944] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.26.974] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.27.033] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.036] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.037] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.043] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.045] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.048] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.052] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.057] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.059] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
              [10.10.2021 15:37.27.062] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
              [10.10.2021 15:37.27.136] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics
              [10.10.2021 15:37.27.154] [LOG]   Create new calendarfetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie_cal.ics - Interval: 150000
              [10.10.2021 15:37.27.158] [LOG]   sleep-wake helper in socket notification=config
              [10.10.2021 15:37.27.192] [LOG]    external source defined dir=/opt/magic_mirror/modules/MMM-SleepWake/motion
              [10.10.2021 15:37.27.301] [INFO]  Newsfeed-Fetcher: Broadcasting 5 items.
              [10.10.2021 15:37.27.529] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [10.10.2021 15:37.27.626] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics
              [10.10.2021 15:37.27.669] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics
              [10.10.2021 15:37.27.710] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics
              [10.10.2021 15:37.27.763] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics
              [10.10.2021 15:37.27.784] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics
              [10.10.2021 15:37.27.817] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics
              [10.10.2021 15:37.27.840] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen.ics
              [10.10.2021 15:37.27.855] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen-wichtig.ics
              [10.10.2021 15:37.27.869] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics
              [10.10.2021 15:37.27.890] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics
              [10.10.2021 15:37.27.978] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics
              [10.10.2021 15:37.28.011] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics
              [10.10.2021 15:37.28.043] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics
              [10.10.2021 15:37.28.070] [LOG]   Use existing fetcher for url: http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics
              [10.10.2021 15:37.29.798] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
              custom_menu.json
                 "id": "custom",
                 "type": "menu",
                 "icon": "id-card-o",
                 "text": "Steuerung",
                 "items": [{
                       "id": "custom-item-1",
                       "type": "item",
                       "icon": "dot-circle-o",
                       "text": "Termine",
                       "action": "NOTIFICATION",
                       "content": {
                          "notification": "PAGE_SELECT",
                          "payload": "Termine"
                       "id": "custom-item-2",
                       "type": "item",
                       "text": "Aufgaben",
                      "content": {
                          "payload": "Aufgaben"
                       "id": "custom-item-3",
                       "type": "item",
                       "text": "Offene Aufgaben",
                       "content": {
                          "payload": "Offene Aufgaben"
                       "id": "custom-item-4",
                       "type": "item",
                       "text": "Offene wichtige Aufgaben",
                       "content": {
                          "payload": "Offene wichtige und dringende Aufgaben"
                       "id": "level2",
                       "type": "menu",
                       "menu": "custom",
                       "icon": "bars",
                       "text": "Sub-Menu",
                       "items": [{
                             "type": "item",
                             "text": "Sub-Menu Item 1",
                             "content": {
                                "notification": "NOTIFCATION_TEXT_4",
                                "payload": "This notification requires a string payload"
                             "type": "item",
                             "text": "Sub-Menu Item 2",
                             "content": {
                                "notification": "NOTIFCATION_TEXT_5",
                                "payload": {
                                   "title": "Payload Object",
                                   "message": "This notification requires a payload object"
              • W Offline
                i used MMM-Carousel from https://github.com/shbatm/MMM-Carousel
                i hope i Upload what is needed :-)
                • karsten13K Offline
                  karsten13 @wageck
                  @wageck
                  there are timezone related errors in the logs. You are using an old docker-compose.yml, the whole timezone/TZ stuff is not neaded anymore, please take a look at the current version …
                  • MichMichM Offline
                    MichMich
                    It seems like most of the issues are caused by a misconfiguration of the MMM-Carousel module. This is a 3rd party module therefore I can’t give any support on that module.
                    But for example, I see you using carouselId In de module configs, but I fail to find anything about this in the MMM-Carousel documentation.
                    Your best guess is to open an issue in the repository of the respective module. Although I would recommend to do a deep dive in the module’s documentation first.
                    • W Offline
                      wageck Project Sponsor @MichMich
                      @shbatm can you say something to my Problem?
                      • W Offline
                        i use https://github.com/shbatm/MMM-Carousel and there is the carouselId
                        is there a better module for multiple pages ?
                        • W Offline
                          i test mm-pages and duplicate the MMM-Todo and the calendar but the calendar modul is not showing something, on the page where i set todo to right it is to see ?
                           * MIT Licensed.
                          var config = {
                          	language: "de",
                          	timeFormat: 24,
                          	units: "metric",
                          		carouselId: 510
                          		carouselId: 520 ,
                          	header: "Heute",
                          		carouselId: 530 ,
                          		units: "metric",
                          		degreeLabel: true,
                          		timeFormat: "24",
                          		lang: "de"
                          		carouselId: 540 ,
                          		units: "metric",
                          		degreeLabel: true,
                          		timeFormat: "24",
                          		lang: "de"
                          	module: "newsfeed",
                          	header: "News",
                          		carouselId: 550 ,
                          		showAsList: true,
                          		maxNewsItems: 4,
                          			feeds: [
                          					title: "Weierhof",
                          			module: "MMM-ToDo10",
                          				carouselId: 10 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo11",
                          				carouselId: 11 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo12",
                          				carouselId: 12 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo13",
                          				carouselId: 13 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo14",
                          				carouselId: 14 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo15",
                          				carouselId: 15 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo16",
                          				carouselId: 16 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo17",
                          				carouselId: 17 ,
                          				maximumEntries: 14,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo20",
                          				carouselId: 20 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo21",
                          				carouselId: 21 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo22",
                          				carouselId: 22 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo23",
                          				carouselId: 23 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo24",
                          				carouselId: 24 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "MMM-ToDo25",
                          				carouselId: 25 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: false,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar30",
                          				carouselId: 30 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar31",
                          				carouselId: 31 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar32",
                          				carouselId: 32 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar33",
                          				carouselId: 33 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar34",
                          				carouselId: 34 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar35",
                          				carouselId: 35 ,
                          				maximumEntries: 11,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar40",
                          				carouselId: 40 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar41",
                          				carouselId: 41 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar42",
                          				carouselId: 42 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar43",
                          				carouselId: 43 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar44",
                          				carouselId: 44 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          			module: "calendar45",
                          				carouselId: 45 ,
                          				maximumEntries: 12,
                          				maxTitleLength: 50,
                          				wrapEvents: false,
                          				maxTitleLines: 1,
                          				hidePrivate: true,
                          				hideOngoing: true,
                          				fade: false,
                          				colored: false,
                          				calendars: 	[
                          		carouselId: 680 ,
                          	config:{
                           carouselId: 690 ,
                           mode: 'PI',
                                  module: 'MMM-pages',
                                          modules:
                                              [[ "MMM-ToDo10", "MMM-ToDo20", "calendar30", "calendar40"],
                                               [ "MMM-ToDo11", "MMM-ToDo21", "calendar31", "calendar41"],
                          		     [ "MMM-ToDo12", "MMM-ToDo22", "calendar32", "calendar42"],
                          		     [ "MMM-ToDo13", "MMM-ToDo23", "calendar33", "calendar43"],
                          		     [ "MMM-ToDo14", "MMM-ToDo24", "calendar34", "calendar44"],
                          		     [ "MMM-ToDo15", "MMM-ToDo25", "calendar35", "calendar45"],
                          		     [ "MMM-ToDo16", "MMM-ToDo26", "calendar30", "calendar40"]],
                                          fixed: ["helloworld", "MMM-page-indicator", "newsfeed", "currentweather", "weatherforecast"],
                                          //hiddenPages: {
                                          //    "screenSaver": [ "clock", "MMM-SomeBackgroundImageModule" ],
                                          //    "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
                          		rotationTime: 10000,
                            sdetweil @wageck
                            @wageck I do not know…
                            but I would test by disabling every module (add disabled: true, after the module: … line ) but one
                            and test to make sure that the one module u want works… for each such module
                            then turn back on pages,
                            u could also do this in another copy of MM (copy the folder and edit there)
                            or use the default config in the copy and add your one definition, copy that folder from your full config
