    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 41.4k Views 20 Watching
    • T Offline
      timodejong95 @lavolp3
      @lavolp3 Oké check, well no need to try again tonight because your up-to-date then. I will let you know when I have looked at it. For now you can prevent the errors by removing the battery in the tracks array.
      • T Offline
        timodejong95
        I have just pushed some new changes which improve connecting, and a few tests cases for device connection. It requires a npm install.
        @lavolp3 and @djerik if you have some time could you try it out? Also I though you already had it on but if not it might be handy to enable debugLogs.
        Also I want to thank you for the time you put into this and help me by providing logs and errors so I can improve the module.
        • lavolp3L Offline
          lavolp3 Module Developer @timodejong95
          @timodejong95 IT WORKED! At least partially, that is.
          0|mm  | 00:13:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:17.988] [LOG]
          0|mm  | 00:13:17 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
          0|mm  | [2020-04-26 00:13:17.995] [LOG]
          0|mm  | 00:13:17 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:21.469] [LOG]
          0|mm  | 00:13:21 <log> MMM-BluetoothDevices connected to device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:21.534] [LOG]
          0|mm  | 00:13:21 <log> MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:13:21.552] [LOG]    00:13:21 <log> MMM-BluetoothDevices waiting for services to be resolved for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:13:29.503] [LOG]
          0|mm  | 00:13:29 <log> MMM-BluetoothDevices connected to: DIRKS OralB after 1 try (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:29.961] [LOG]
          0|mm  | 00:13:29 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:13:29.966] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:29.979] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:30.255] [LOG]
          0|mm  | 00:13:30 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:13:30.259] [LOG]    00:13:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:31.229] [LOG]
          0|mm  | 00:13:31 <log> MMM-BluetoothDevices battery updated to: 99% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:13:31.234] [LOG]    00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:31.466] [LOG]
          0|mm  | 00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:31.520] [LOG]
          0|mm  | 00:13:31 <log> MMM-BluetoothDevices connection lost with device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:33.303] [LOG]
          0|mm  | 00:13:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:33.315] [LOG]
          0|mm  | 00:13:33 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
          0|mm  | [2020-04-26 00:13:33.318] [LOG]    00:13:33 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:43.919] [LOG]
          0|mm  | 00:13:43 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:13:54.916] [LOG]
          0|mm  | 00:13:54 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:14:05.881] [LOG]
          0|mm  | 00:14:05 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:14:13.884] [LOG]
          0|mm  | 00:14:13 <info> MMM-BluetoothDevices failed to reconnect to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
          0|mm  | [2020-04-26 00:14:13.886] [LOG]    00:14:13 <log> MMM-BluetoothDevices Error: Error: Couldn't connect to DIRKS OralB after 1 try. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
          0|mm  | [2020-04-26 00:14:16.957] [LOG]
          0|mm  | 00:14:16 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:14:28.049] [LOG]
          0|mm  | 00:14:28 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:14:38.869] [LOG]
          0|mm  | 00:14:38 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:14:49.968] [LOG]
          0|mm  | 00:14:49 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:15:00.855] [LOG]
          0|mm  | 00:15:00 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:15:12.156] [LOG]
          0|mm  | 00:15:12 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:15:22.928] [LOG]
          0|mm  | 00:15:22 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          0|mm  | [2020-04-26 00:15:33.865] [LOG]
          0|mm  | 00:15:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
          Battery updates are there but only in the beginning.
          I would assume my battery drains more than this one percent in 2 minutes but may be wrong.
          Nothing displayed on the mirror.
          Might still be missing?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • T Offline
            @lavolp3 Nice, yeah thats still a thing. I thought it was the way it connects, but the devices automatically disconnects after 20-30 seconds. When disconnected its not able to get the battery status. So what I build that if the devices is disconnected at the first 5 seconds of brushing it’s going to reconnect (1 try). If that succeeds it gets the battery value. If not well, then sadly not.
            I haven’t figured out a solution to keep it connected throughout the whole session or just forever. My guess is, the brush might expect data to be send to keep the connection active/alive.
            In the logs I see that the reconnection has failed, do you got that every session? Else I might increase the reconnection attempts to 2.
            • O Offline
              OberfragGER
              Did anyone got this running.
              I have tested on MM2 - 2.14 and 2.15. No sucess.
              Just the Time runs…
              Do i have to do anything special like pairing the toothbrush (not possible, pairing nit sucessful).
              Im using RPI4 with BT build in.
              • lavolp3L Offline
                lavolp3 Module Developer @OberfragGER
                @oberfragger yeah I had this running.
                Might retry these days.
                You need to pair the toothbrush with your RasPi. If that didn’t work the module itself probably won’t work.
                Where did it fail?
                • O Offline
                  OberfragGER @lavolp3
                  @lavolp3 No pairing possible. Maybe my Toothbrush is too new? Oral-B Genius 9000.
                  Do i have to “click” something on the toothbrush to pair? Its already paired with the app.
                  • lavolp3L Offline
                    @oberfragger
                    Actually the better module currently to work with the toothbrush is MMM-BluetoothDevices
                    I think I have that working.
                    However, pairing is necessary.
                    At which point are you failing, what description have you used?
                    • 4 / 4
