    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 44.1k Views 20 Watching
    • lavolp3L
      lavolp3 Module Developer @timodejong95
      @timodejong95 said in MMM-OralB / Bluetooth equipped toothbrush integration:
      @lavolp3 No worries, check I will have a look at this when I find some time, probably this weekend. Seems that the devices couldn’t connect at the first try but failed in de second which is triggered instantly.
      I don’t have a problem with that. Devices are connecting well as soon as I activate them. Everything works really well except no battery status shown.
      Apparently the waitForService process ends unresolved, hence is not able to get the information from the battery service
      [2020-04-23 00:52:33.875] [ERROR]  00:52:33  MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      T 1 Reply Last reply
      • T
        timodejong95 @lavolp3
        @lavolp3 Check I get you. Just to be sure, you did do npm install I changed a package? If not then I will comeback to it when I have tested it myself.
        lavolp3L 1 Reply Last reply
        • lavolp3L
          Yes I did.
          Did it now again (but no new installations) and trying again tonight
          • T
            @lavolp3 Oké check, well no need to try again tonight because your up-to-date then. I will let you know when I have looked at it. For now you can prevent the errors by removing the battery in the tracks array.
            • T
              timodejong95
              I have just pushed some new changes which improve connecting, and a few tests cases for device connection. It requires a npm install.
              @lavolp3 and @djerik if you have some time could you try it out? Also I though you already had it on but if not it might be handy to enable debugLogs.
              Also I want to thank you for the time you put into this and help me by providing logs and errors so I can improve the module.
              • lavolp3L
                @timodejong95 IT WORKED! At least partially, that is.
                0|mm  | 00:13:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:17.988] [LOG]
                0|mm  | 00:13:17 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                0|mm  | [2020-04-26 00:13:17.995] [LOG]
                0|mm  | 00:13:17 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:21.469] [LOG]
                0|mm  | 00:13:21 <log> MMM-BluetoothDevices connected to device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:21.534] [LOG]
                0|mm  | 00:13:21 <log> MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:13:21.552] [LOG]    00:13:21 <log> MMM-BluetoothDevices waiting for services to be resolved for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:13:29.503] [LOG]
                0|mm  | 00:13:29 <log> MMM-BluetoothDevices connected to: DIRKS OralB after 1 try (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:29.961] [LOG]
                0|mm  | 00:13:29 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:13:29.966] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:29.979] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:30.255] [LOG]
                0|mm  | 00:13:30 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:13:30.259] [LOG]    00:13:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:31.229] [LOG]
                0|mm  | 00:13:31 <log> MMM-BluetoothDevices battery updated to: 99% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:13:31.234] [LOG]    00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:31.466] [LOG]
                0|mm  | 00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:31.520] [LOG]
                0|mm  | 00:13:31 <log> MMM-BluetoothDevices connection lost with device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:33.303] [LOG]
                0|mm  | 00:13:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:33.315] [LOG]
                0|mm  | 00:13:33 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                0|mm  | [2020-04-26 00:13:33.318] [LOG]    00:13:33 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:43.919] [LOG]
                0|mm  | 00:13:43 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:13:54.916] [LOG]
                0|mm  | 00:13:54 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:14:05.881] [LOG]
                0|mm  | 00:14:05 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:14:13.884] [LOG]
                0|mm  | 00:14:13 <info> MMM-BluetoothDevices failed to reconnect to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                0|mm  | [2020-04-26 00:14:13.886] [LOG]    00:14:13 <log> MMM-BluetoothDevices Error: Error: Couldn't connect to DIRKS OralB after 1 try. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                0|mm  | [2020-04-26 00:14:16.957] [LOG]
                0|mm  | 00:14:16 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:14:28.049] [LOG]
                0|mm  | 00:14:28 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:14:38.869] [LOG]
                0|mm  | 00:14:38 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:14:49.968] [LOG]
                0|mm  | 00:14:49 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:15:00.855] [LOG]
                0|mm  | 00:15:00 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:15:12.156] [LOG]
                0|mm  | 00:15:12 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:15:22.928] [LOG]
                0|mm  | 00:15:22 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                0|mm  | [2020-04-26 00:15:33.865] [LOG]
                0|mm  | 00:15:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                Battery updates are there but only in the beginning.
                I would assume my battery drains more than this one percent in 2 minutes but may be wrong.
                Nothing displayed on the mirror.
                Might still be missing?
                • T
                  @lavolp3 Nice, yeah thats still a thing. I thought it was the way it connects, but the devices automatically disconnects after 20-30 seconds. When disconnected its not able to get the battery status. So what I build that if the devices is disconnected at the first 5 seconds of brushing it’s going to reconnect (1 try). If that succeeds it gets the battery value. If not well, then sadly not.
                  I haven’t figured out a solution to keep it connected throughout the whole session or just forever. My guess is, the brush might expect data to be send to keep the connection active/alive.
                  In the logs I see that the reconnection has failed, do you got that every session? Else I might increase the reconnection attempts to 2.
                  • O
                    OberfragGER
                    Did anyone got this running.
                    I have tested on MM2 - 2.14 and 2.15. No sucess.
                    Just the Time runs…
                    Do i have to do anything special like pairing the toothbrush (not possible, pairing nit sucessful).
                    Im using RPI4 with BT build in.
                    • lavolp3L
                      lavolp3 Module Developer @OberfragGER
                      @oberfragger yeah I had this running.
                      Might retry these days.
                      You need to pair the toothbrush with your RasPi. If that didn’t work the module itself probably won’t work.
                      Where did it fail?
                      O 1 Reply Last reply
                      • O
                        OberfragGER @lavolp3
                        @lavolp3 No pairing possible. Maybe my Toothbrush is too new? Oral-B Genius 9000.
                        Do i have to “click” something on the toothbrush to pair? Its already paired with the app.
                        • lavolp3L
                          @oberfragger
                          Actually the better module currently to work with the toothbrush is MMM-BluetoothDevices
                          I think I have that working.
                          However, pairing is necessary.
                          At which point are you failing, what description have you used?
                          • 4 / 4
