    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 44.1k Views 20 Watching
    • T
      timodejong95
      I have been debugging it and it seems that the devices is ‘just’ being disconnected:
      HCI Event: Disconn Complete (0x05) plen 4
          status 0x00 handle 64 reason 0x13
          Reason: Remote User Terminated Connection
      I do not know why :/
      • T
        timodejong95
        @lavolp3 Oke I have pushed some changes, see: https://github.com/timodejong95/MMM-BluetoothDevices. Don’t forget npm install.
        I updated the configuration see docs. You need to add a track key to the device config with the value ‘battery’:
        example:
        devices: [
          { type: 'OralBToothbrush', name: 'oralb', mac: 'xxx', tracks: ['battery'], format: 'formatted' },
        It’s still a bit buggy let me know what your experience is!
        lavolp3L 1 Reply Last reply
        • lavolp3L
          lavolp3 Module Developer @timodejong95
          @timodejong95 No luck yet.
          No Battery status to be seen and this error in the logs
          0|mm       | [2020-04-20 01:21:08.432] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
          0|mm       |     --> starting at object with constructor 'DBusObject'
          0|mm       |     |     property 'proxy' -> object with constructor 'Object'
          0|mm       |     |     property 'org.freedesktop.DBus.Introspectable' -> object with constructor 'DBusInterface'
          0|mm       |     --- property '$parent' closes the circle
          0|mm       |     at JSON.stringify (<anonymous>)
          0|mm       |     at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/index.js:24:25
          0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
          0|mm       | [2020-04-20 01:21:08.435] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          T 1 Reply Last reply
          • T
            timodejong95 @lavolp3
            @lavolp3 Damm ashame, could you post the logs above the error? If correct there should be 2 more error logs, and just to be sure it still works when you remove the battery track, right?
            D lavolp3L 2 Replies Last reply
              djerik @timodejong95
              @timodejong95
              I have removed the module, installed again and added the extra piece of configuration. The updated UI is working fine, but there is no battery indicator. Is this the log you are looking for?
              [2020-04-22 19:40:43.278] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:40:43.389] [LOG] MMM-BluetoothDevices trying to connect to: OralB 1/2
              [2020-04-22 19:40:53.451] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:40:53.673] [LOG] MMM-BluetoothDevices trying to connect to: OralB 2/2
              [2020-04-22 19:40:59.444] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:41:10.482] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:41:13.767] [ERROR] MMM-BluetoothDevices unhandled exception:
              [2020-04-22 19:41:13.771] [ERROR] MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded
              [2020-04-22 19:41:13.774] [ERROR] MMM-BluetoothDevices {“troubleshooting”:“devices#resolve-services”,“extra”:{}}
              [2020-04-22 19:41:21.451] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:41:32.477] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:41:43.546] [LOG] MMM-BluetoothDevices received device update for OralB
              [2020-04-22 19:41:54.482] [LOG] MMM-BluetoothDevices received device update for OralB
              • lavolp3L
                @timodejong95 there are no logs above that.
                I get this error before I started the brush
                [2020-04-23 00:19:17.258] [ERROR]  00:19:17 <error> MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                [2020-04-23 00:19:17.263] [ERROR]  00:19:17 <error> MMM-BluetoothDevices Error: Error: Couldn't connect to BABSIS OralB after 2 tries. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                [2020-04-23 00:19:17.277] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                [2020-04-23 00:19:17.284] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                [2020-04-23 00:19:17.289] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:19:17.293] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:19:17.296] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:19:17.299] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:23:44.731] [LOG]    00:23:44 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:23:47.096] [LOG]    00:23:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:23:57.944] [LOG]    00:23:57 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:24:08.935] [LOG]    00:24:08 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:24:19.917] [LOG]    00:24:19 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:24:30.925] [LOG]    00:24:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:24:41.961] [LOG]    00:24:41 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:24:52.927] [LOG]    00:24:52 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:03.965] [LOG]    00:25:03 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:14.860] [LOG]    00:25:14 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:25.926] [LOG]    00:25:25 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:36.875] [LOG]    00:25:36 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:47.877] [LOG]    00:25:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                [2020-04-23 00:25:58.907] [LOG]    00:25:58 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                This error vanishes when I deactivate the JSON.stringify function.
                I have the feeling that everything is working, but the battery is not showing up at all.
                Also, when closing the mirror (ctrl+c when I started it with npm start dev ) I get these errors:
                [2020-04-23 00:38:03.482] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                    at Dongle.disconnectDevices (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:223:28)
                    at Dongle.destroy (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:58:17)
                    at Class.stop (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:46:23)
                    at App.stop (/home/pi/MagicMirror/js/app.js:252:16)
                    at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:108:7)
                    at App.emit (events.js:200:13) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:38:03.486] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                [2020-04-23 00:38:03.489] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:38:03.495] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:38:03.503] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                [2020-04-23 00:38:03.509] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                • lavolp3L
                  @timodejong95
                  https://makandracards.com/makandra/28847-dealing-with-typeerror-converting-circular-structure-to-json-on-javascript
                  • lavolp3L
                    and more debugging messages, sorry for the spamming:
                    [2020-04-23 00:51:53.902] [LOG]    00:51:53 <log> MMM-BluetoothDevices starting hub (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:23 Class.startHub)
                    [2020-04-23 00:51:58.845] [LOG]    00:51:58 <log> MMM-BluetoothDevices unhandled adapter msg: {"serial":1536,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["UUIDs",[[{"type":"a","child":[{"type":"s","child":[]}]}],[["00001112-0000-1000-8000-00805f9b34fb","00001801-0000-1000-8000-00805f9b34fb","0000110e-0000-1000-8000-00805f9b34fb","00001800-0000-1000-8000-00805f9b34fb","00001200-0000-1000-8000-00805f9b34fb","0000110c-0000-1000-8000-00805f9b34fb","0000110a-0000-1000-8000-00805f9b34fb","0000111f-0000-1000-8000-00805f9b34fb","00001805-0000-1000-8000-00805f9b34fb"]]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                    [2020-04-23 00:52:01.474] [LOG]    00:52:01 <log> MMM-BluetoothDevices unhandled adapter msg: {"serial":1542,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["Discovering",[[{"type":"b","child":[]}],[true]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                    [2020-04-23 00:52:01.993] [LOG]    00:52:01 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/2 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:13.667] [LOG]    00:52:13 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:13.834] [LOG]    00:52:13 <log> MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                    [2020-04-23 00:52:17.445] [LOG]    00:52:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:23.028] [LOG]    00:52:23 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:33.871] [ERROR]  00:52:33 <error> MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                    [2020-04-23 00:52:33.875] [ERROR]  00:52:33 <error> MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                    [2020-04-23 00:52:33.905] [LOG]    00:52:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:44.875] [LOG]    00:52:44 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:52:55.859] [LOG]    00:52:55 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:53:06.911] [LOG]    00:53:06 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:53:17.884] [LOG]    00:53:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    [2020-04-23 00:53:28.849] [LOG]    00:53:28 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                    • T
                      @lavolp3 No worries, check I will have a look at this when I find some time, probably this weekend. Seems that the devices couldn’t connect at the first try but failed in de second which is triggered instantly.
                      @djerik Thanks for sharing
                      I will try and fix the issues you send to be, thanks for sharing and excuses for the bugs! I might write some tests because the manual tests are stacking up and code coverage is always good.
                      • lavolp3L
                        @timodejong95 said in MMM-OralB / Bluetooth equipped toothbrush integration:
                        I don’t have a problem with that. Devices are connecting well as soon as I activate them. Everything works really well except no battery status shown.
                        Apparently the waitForService process ends unresolved, hence is not able to get the information from the battery service
                        [2020-04-23 00:52:33.875] [ERROR]  00:52:33  MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                        • T
                          @lavolp3 Check I get you. Just to be sure, you did do npm install I changed a package? If not then I will comeback to it when I have tested it myself.
                          • lavolp3L
                            Yes I did.
                            Did it now again (but no new installations) and trying again tonight
                            • T
                              @lavolp3 Oké check, well no need to try again tonight because your up-to-date then. I will let you know when I have looked at it. For now you can prevent the errors by removing the battery in the tracks array.
                              • T
                                timodejong95
                                I have just pushed some new changes which improve connecting, and a few tests cases for device connection. It requires a npm install.
                                @lavolp3 and @djerik if you have some time could you try it out? Also I though you already had it on but if not it might be handy to enable debugLogs.
                                Also I want to thank you for the time you put into this and help me by providing logs and errors so I can improve the module.
                                • lavolp3L
                                  @timodejong95 IT WORKED! At least partially, that is.
                                  0|mm  | 00:13:17 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:17.988] [LOG]
                                  0|mm  | 00:13:17 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                                  0|mm  | [2020-04-26 00:13:17.995] [LOG]
                                  0|mm  | 00:13:17 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:21.469] [LOG]
                                  0|mm  | 00:13:21 <log> MMM-BluetoothDevices connected to device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:21.534] [LOG]
                                  0|mm  | 00:13:21 <log> MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:13:21.552] [LOG]    00:13:21 <log> MMM-BluetoothDevices waiting for services to be resolved for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:13:29.503] [LOG]
                                  0|mm  | 00:13:29 <log> MMM-BluetoothDevices connected to: DIRKS OralB after 1 try (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:29.961] [LOG]
                                  0|mm  | 00:13:29 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:13:29.966] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:29.979] [LOG]    00:13:29 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:30.255] [LOG]
                                  0|mm  | 00:13:30 <log> MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:13:30.259] [LOG]    00:13:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:31.229] [LOG]
                                  0|mm  | 00:13:31 <log> MMM-BluetoothDevices battery updated to: 99% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:13:31.234] [LOG]    00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:31.466] [LOG]
                                  0|mm  | 00:13:31 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:31.520] [LOG]
                                  0|mm  | 00:13:31 <log> MMM-BluetoothDevices connection lost with device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:33.303] [LOG]
                                  0|mm  | 00:13:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:33.315] [LOG]
                                  0|mm  | 00:13:33 <info> MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                                  0|mm  | [2020-04-26 00:13:33.318] [LOG]    00:13:33 <log> MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:43.919] [LOG]
                                  0|mm  | 00:13:43 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:13:54.916] [LOG]
                                  0|mm  | 00:13:54 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:14:05.881] [LOG]
                                  0|mm  | 00:14:05 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:14:13.884] [LOG]
                                  0|mm  | 00:14:13 <info> MMM-BluetoothDevices failed to reconnect to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
                                  0|mm  | [2020-04-26 00:14:13.886] [LOG]    00:14:13 <log> MMM-BluetoothDevices Error: Error: Couldn't connect to DIRKS OralB after 1 try. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
                                  0|mm  | [2020-04-26 00:14:16.957] [LOG]
                                  0|mm  | 00:14:16 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:14:28.049] [LOG]
                                  0|mm  | 00:14:28 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:14:38.869] [LOG]
                                  0|mm  | 00:14:38 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:14:49.968] [LOG]
                                  0|mm  | 00:14:49 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:15:00.855] [LOG]
                                  0|mm  | 00:15:00 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:15:12.156] [LOG]
                                  0|mm  | 00:15:12 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:15:22.928] [LOG]
                                  0|mm  | 00:15:22 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  0|mm  | [2020-04-26 00:15:33.865] [LOG]
                                  0|mm  | 00:15:33 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                  Battery updates are there but only in the beginning.
                                  I would assume my battery drains more than this one percent in 2 minutes but may be wrong.
                                  Nothing displayed on the mirror.
                                  Might still be missing?
                                  • T
                                    @lavolp3 Nice, yeah thats still a thing. I thought it was the way it connects, but the devices automatically disconnects after 20-30 seconds. When disconnected its not able to get the battery status. So what I build that if the devices is disconnected at the first 5 seconds of brushing it’s going to reconnect (1 try). If that succeeds it gets the battery value. If not well, then sadly not.
                                    I haven’t figured out a solution to keep it connected throughout the whole session or just forever. My guess is, the brush might expect data to be send to keep the connection active/alive.
                                    In the logs I see that the reconnection has failed, do you got that every session? Else I might increase the reconnection attempts to 2.
                                    • O
                                      OberfragGER
                                      Did anyone got this running.
                                      I have tested on MM2 - 2.14 and 2.15. No sucess.
                                      Just the Time runs…
                                      Do i have to do anything special like pairing the toothbrush (not possible, pairing nit sucessful).
                                      Im using RPI4 with BT build in.
                                      • lavolp3L
                                        lavolp3 Module Developer @OberfragGER
                                        @oberfragger yeah I had this running.
                                        Might retry these days.
                                        You need to pair the toothbrush with your RasPi. If that didn’t work the module itself probably won’t work.
                                        Where did it fail?
                                        O 1 Reply Last reply
                                        • O
                                          OberfragGER @lavolp3
                                          @lavolp3 No pairing possible. Maybe my Toothbrush is too new? Oral-B Genius 9000.
                                          Do i have to “click” something on the toothbrush to pair? Its already paired with the app.
                                          • lavolp3L
                                            @oberfragger
                                            Actually the better module currently to work with the toothbrush is MMM-BluetoothDevices
                                            I think I have that working.
                                            However, pairing is necessary.
                                            At which point are you failing, what description have you used?
                                            • 3 / 4
