    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 44.5k Views 4 Watching
      Richard238
      MM said I was 122 commits behind.
      Ran the update script:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      Eeeeek, black screen! Searched forum, found this:
      https://forum.magicmirror.builders/topic/15240/black-screen/2?_=1641460034694
      Did as suggested:
      pi@magicmirror:~/MagicMirror $ npm run config:check
      > magicmirror@2.18.0 config:check
      > node js/check_config.js
      /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359
      const require$1 = Module.createRequire((typeof document === 'undefined' ? new (require('u' + 'rl').URL)('file:' + __filename).href : (document.currentScript && document.currentScript.src || new URL('eslintrc.cjs', document.baseURI).href)));
      TypeError: Module.createRequire is not a function
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359:26)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
      pi@magicmirror:~/MagicMirror $ npm init -y
      Wrote to /home/pi/MagicMirror/package.json:
        "name": "magicmirror",
        "version": "2.18.0",
        "description": "The open source modular smart mirror platform.",
        "main": "js/electron.js",
        "scripts": {
          "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
          "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
          "server": "node ./serveronly",
          "install": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error",
          "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error",
          "postinstall": "npm run install-fonts && echo \"MagicMirror installation finished successfully! \n\"",
          "test": "NODE_ENV=test jest -i --forceExit",
          "test:coverage": "NODE_ENV=test nyc --reporter=lcov --reporter=text jest -i --forceExit",
          "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
          "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
          "test:unit": "NODE_ENV=test jest --selectProjects unit -i --forceExit",
          "test:prettier": "prettier . --check",
          "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json",
          "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
          "test:calendar": "node ./modules/default/calendar/debug.js",
          "config:check": "node js/check_config.js",
          "lint:prettier": "prettier . --write",
          "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json --fix",
          "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
          "lint:staged": "pretty-quick --staged",
          "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
        "repository": {
          "type": "git",
          "url": "git+https://github.com/MichMich/MagicMirror.git"
        "keywords": [
          "magic mirror",
          "smart mirror",
          "mirror UI",
          "modular"
        "author": "Michael Teeuw",
        "contributors": [
          "https://github.com/MichMich/MagicMirror/graphs/contributors"
        "license": "MIT",
        "bugs": {
          "url": "https://github.com/MichMich/MagicMirror/issues"
        "homepage": "https://magicmirror.builders",
        "devDependencies": {
          "eslint-config-prettier": "^8.3.0",
          "eslint-plugin-jest": "^25.3.0",
          "eslint-plugin-jsdoc": "^37.4.0",
          "eslint-plugin-prettier": "^4.0.0",
          "express-basic-auth": "^1.2.1",
          "husky": "^7.0.4",
          "jest": "^27.4.5",
          "jsdom": "^19.0.0",
          "lodash": "^4.17.21",
          "nyc": "^15.1.0",
          "playwright": "^1.17.1",
          "prettier": "^2.5.1",
          "pretty-quick": "^3.1.3",
          "sinon": "^12.0.1",
          "stylelint": "^14.2.0",
          "stylelint-config-prettier": "^9.0.3",
          "stylelint-config-standard": "^24.0.0",
          "stylelint-prettier": "^2.0.0",
          "suncalc": "^1.8.0"
        "optionalDependencies": {
          "electron": "^16.0.5"
        "dependencies": {
          "colors": "^1.4.0",
          "console-stamp": "^3.0.3",
          "digest-fetch": "^1.2.1",
          "eslint": "^8.5.0",
          "express": "^4.17.2",
          "express-ipfilter": "^1.2.0",
          "feedme": "^2.0.2",
          "helmet": "^4.6.0",
          "iconv-lite": "^0.6.3",
          "module-alias": "^2.2.2",
          "moment": "^2.29.1",
          "node-fetch": "^2.6.6",
          "node-ical": "^0.13.0",
          "socket.io": "^4.4.0"
        "engines": {
          "node": ">=12"
        "jest": {
          "verbose": true,
          "testTimeout": 10000,
          "projects": [
              "displayName": "unit",
              "moduleNameMapper": {
                "logger": "<rootDir>/js/logger.js"
              "testMatch": [
                "**/tests/unit/**/*.[jt]s?(x)"
              "testPathIgnorePatterns": [
                "<rootDir>/tests/unit/mocks"
              "displayName": "electron",
              "testMatch": [
                "**/tests/electron/**/*.[jt]s?(x)"
              "displayName": "e2e",
              "setupFilesAfterEnv": [
                "<rootDir>/tests/e2e/mock-console.js"
              "testMatch": [
                "**/tests/e2e/**/*.[jt]s?(x)"
              "modulePaths": [
                "<rootDir>/js/"
                "<rootDir>/tests/e2e/modules/mocks",
                "<rootDir>/tests/e2e/modules/basic-auth.js",
                "<rootDir>/tests/e2e/global-setup.js",
        "directories": {
          "test": "tests"
      pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
      [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 50 lines:
      PM2        | 2021-12-22T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-23T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-23T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-24T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-24T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-25T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-25T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-26T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-26T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-27T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-27T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-28T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-28T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-29T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-29T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-30T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-30T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2021-12-31T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2021-12-31T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-01T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2022-01-01T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-02T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2022-01-02T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-03T13:52:37: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2022-01-03T13:52:37: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-04T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2022-01-04T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-05T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE
      PM2        | 2022-01-05T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2
      PM2        | 2022-01-06T08:25:26: PM2 log: Stopping app:MagicMirror id:0
      PM2        | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms
      PM2        | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms
      PM2        | 2022-01-06T08:25:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
      PM2        | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=process killed
      PM2        | 2022-01-06T08:31:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2022-01-06T08:31:27: PM2 log: App [MagicMirror:0] online
      PM2        | 2022-01-06T08:33:57: PM2 log: Stopping app:MagicMirror id:0
      PM2        | 2022-01-06T08:33:58: PM2 log: pid=12095 msg=failed to kill - retrying in 100ms
      PM2        | 2022-01-06T08:33:58: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
      PM2        | 2022-01-06T08:33:58: PM2 log: pid=12095 msg=process killed
      PM2        | 2022-01-06T08:34:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2022-01-06T08:34:05: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
      0|MagicMir | [06.01.2022 08:31.32.828] [LOG]   Module helper loaded: currentweather
      0|MagicMir | [06.01.2022 08:31.32.833] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:31.32.835] [LOG]   Module helper loaded: weatherforecast
      0|MagicMir | [06.01.2022 08:31.32.843] [LOG]   Loading module helpers ...
      0|MagicMir | [06.01.2022 08:31.32.845] [LOG]   No helper found for module: alert.
      0|MagicMir | [06.01.2022 08:31.32.847] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:31.32.849] [LOG]   Module helper loaded: updatenotification
      0|MagicMir | [06.01.2022 08:31.32.850] [LOG]   No helper found for module: clock.
      0|MagicMir | [06.01.2022 08:31.32.852] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:31.32.853] [LOG]   Module helper loaded: calendar
      0|MagicMir | [06.01.2022 08:31.32.855] [LOG]   No helper found for module: compliments.
      0|MagicMir | [06.01.2022 08:31.32.857] [LOG]   No helper found for module: MMM-doomsDay.
      0|MagicMir | [06.01.2022 08:31.32.859] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:31.32.860] [LOG]   Module helper loaded: currentweather
      0|MagicMir | [06.01.2022 08:31.32.862] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:31.32.863] [LOG]   Module helper loaded: weatherforecast
      0|MagicMir | [06.01.2022 08:31.33.522] [LOG]   Launching application.
      0|MagicMir |
      0|MagicMir | > magicmirror@2.18.0 start
      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMir |
      0|MagicMir | [06.01.2022 08:34.09.207] [LOG]   Starting MagicMirror: v2.18.0
      0|MagicMir | [06.01.2022 08:34.09.220] [LOG]   Loading config ...
      0|MagicMir | [06.01.2022 08:34.09.232] [LOG]   Loading module helpers ...
      0|MagicMir | [06.01.2022 08:34.09.238] [LOG]   No helper found for module: alert.
      0|MagicMir | [06.01.2022 08:34.09.272] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.275] [LOG]   Module helper loaded: updatenotification
      0|MagicMir | [06.01.2022 08:34.09.279] [LOG]   No helper found for module: clock.
      0|MagicMir | [06.01.2022 08:34.09.600] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.603] [LOG]   Module helper loaded: calendar
      0|MagicMir | [06.01.2022 08:34.09.606] [LOG]   No helper found for module: compliments.
      0|MagicMir | [06.01.2022 08:34.09.609] [LOG]   No helper found for module: MMM-doomsDay.
      0|MagicMir | [06.01.2022 08:34.09.614] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.616] [LOG]   Module helper loaded: currentweather
      0|MagicMir | [06.01.2022 08:34.09.620] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.622] [LOG]   Module helper loaded: weatherforecast
      0|MagicMir | [06.01.2022 08:34.09.630] [LOG]   Loading module helpers ...
      0|MagicMir | [06.01.2022 08:34.09.632] [LOG]   No helper found for module: alert.
      0|MagicMir | [06.01.2022 08:34.09.634] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.635] [LOG]   Module helper loaded: updatenotification
      0|MagicMir | [06.01.2022 08:34.09.637] [LOG]   No helper found for module: clock.
      0|MagicMir | [06.01.2022 08:34.09.638] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.640] [LOG]   Module helper loaded: calendar
      0|MagicMir | [06.01.2022 08:34.09.641] [LOG]   No helper found for module: compliments.
      0|MagicMir | [06.01.2022 08:34.09.643] [LOG]   No helper found for module: MMM-doomsDay.
      0|MagicMir | [06.01.2022 08:34.09.645] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.646] [LOG]   Module helper loaded: currentweather
      0|MagicMir | [06.01.2022 08:34.09.648] [LOG]   Initializing new module helper ...
      0|MagicMir | [06.01.2022 08:34.09.649] [LOG]   Module helper loaded: weatherforecast
      0|MagicMir | [06.01.2022 08:34.10.239] [LOG]   Launching application.
      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir | -
      0|MagicMir | [06.01.2022 08:34.09.653] [ERROR] App threw an error during load
      0|MagicMir | [06.01.2022 08:34.09.658] [ERROR] Error: Cannot find module 'mysql'
      0|MagicMir | Require stack:
      0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js
      0|MagicMir | - /home/pi/MagicMirror/js/app.js
      0|MagicMir | - /home/pi/MagicMirror/js/electron.js
      0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|MagicMir | -
      0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
      0|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
      0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
      0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js:10:13)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|MagicMir | [06.01.2022 08:34.09.660] [ERROR] Whoops! There was an uncaught exception...
      **0|MagicMir | [06.01.2022 08:34.09.672] [ERROR] Error: Cannot find module 'mysql'**
      0|MagicMir | -
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
      0|MagicMir |   code: 'MODULE_NOT_FOUND',
      0|MagicMir |   requireStack: [
      0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
      0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|MagicMir |     undefined
      0|MagicMir |   ]
      0|MagicMir | }
      0|MagicMir | [06.01.2022 08:34.09.674] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [06.01.2022 08:34.09.675] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [12904:0106/083411.118170:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [12927:0106/083411.471839:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      pi@magicmirror:~/MagicMirror $ npm install mysql
      npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.18.0',
      npm WARN EBADENGINE   required: { node: '>=12' },
      npm WARN EBADENGINE   current: { node: 'v10.24.1', npm: '7.24.2' } }
      npm WARN EBADENGINE Unsupported engine { package: '@es-joy/jsdoccomment@0.13.0',
      npm WARN EBADENGINE   required: { node: '^12 || ^14 || ^16 || ^17' },
      npm WARN EBADENGINE Unsupported engine { package: '@eslint/eslintrc@1.0.5',
      npm WARN EBADENGINE   required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/experimental-utils@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/scope-manager@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/types@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/typescript-estree@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/visitor-keys@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: 'commander@8.3.0',
      npm WARN EBADENGINE   required: { node: '>= 12' },
      npm WARN EBADENGINE Unsupported engine { package: 'comment-parser@1.3.0',
      npm WARN EBADENGINE   required: { node: '>= 12.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'data-urls@3.0.1',
      npm WARN EBADENGINE Unsupported engine { package: 'domexception@4.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint@8.5.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jest@25.3.0',
      npm WARN EBADENGINE   required: { node: '^12.13.0 || ^14.15.0 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@37.4.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-scope@7.1.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-visitor-keys@3.1.0',
      npm WARN EBADENGINE Unsupported engine { package: 'espree@9.2.0',
      npm WARN EBADENGINE Unsupported engine { package: 'html-encoding-sniffer@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'husky@7.0.4',
      npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@2.0.0',
      npm WARN EBADENGINE   required: { node: '>=12.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'jsdom@19.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'playwright@1.17.1',
      npm WARN EBADENGINE Unsupported engine { package: 'playwright-core@1.17.1',
      npm WARN EBADENGINE Unsupported engine { package: 'postcss-safe-parser@6.0.0',
      npm WARN EBADENGINE   required: { node: '>=12.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint@14.2.0',
      npm WARN EBADENGINE   required: { node: '^12.20.0 || ^14.13.1 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint-config-prettier@9.0.3',
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint-prettier@2.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'tr46@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'w3c-xmlserializer@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'webidl-conversions@7.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-encoding@2.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-mimetype@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-url@10.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'xml-name-validator@4.0.0',
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      added 494 packages, and audited 761 packages in 6m
      66 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      Now when I start MM, I get just a blank page.
      pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      [PM2] Process successfully started
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 45   │ online    │ 0%       │ 2.6mb    │
      Hope it’s a simple fix, thank you.
      R mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @Richard238
        @richard238 if you haven’t deleted yet, can u try something
        because you did
        in the mm folder, instead of the module folder, this overwrote the shipped package.json
        so,
        do
        cd ~/MagicMirror.save
        git checkout package.json
        rm -rf node_modules
        rm package.lock.json
        npm install --only=prod
        then stop good mm if running and then do , in the MagicMirror.save folder
        npm start
          Richard238 @Richard238
          Powered it down, switched it on. Shows MM splash screen, then goes to desktop.
          No sign of MM :(
          Nothing new logged in either .npm or .pm2 log files.
          • mumblebajM Offline
            mumblebaj Module Developer @Richard238
            @richard238 Have a look at the below post. It might solve some of your issues.
              @richard238 said in v2.18.0 update gave black screen, then nothing.:
              0|MagicMir | [06.01.2022 08:34.09.658] [ERROR] Error: Cannot find module ‘mysql’
              Your error!
                Richard238 @mumblebaj
                @mumblebaj
                Yes, that’s what I spotted, then I did
                  @richard238 No, You need to do the following:
                  cd ~.MagicMirror/modules/MMM-MysqlQuery
                  npm init -y
                  npm install mysql --save
                  There may be other missing modules.
                    @mumblebaj
                    pi@magicmirror:~ $ cd ~/MagicMirror/modules/MMM-MysqlQuery
                    pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm init -y
                    Wrote to /home/pi/MagicMirror/modules/MMM-MysqlQuery/package.json:
                      "name": "mmm-mysqlquery",
                      "version": "1.0.0",
                      "description": "MagicMirror module to display result of MySQL query",
                      "license": "MIT",
                      "main": "MMM-MysqlQuery.js",
                      "scripts": {
                        "test": "./node_modules/grunt/bin/grunt"
                      "author": "Rich Alberth",
                      "repository": {
                        "type": "git",
                        "url": "git+https://github.com/ralberth/MMM-MysqlQuery.git"
                      "keywords": [
                        "MagicMirror",
                        "module",
                        "mysql"
                      "dependencies": {
                        "mysql": "latest",
                        "npm": "^6.4.1"
                        "grunt": "latest",
                        "grunt-eslint": "latest",
                        "grunt-jsonlint": "latest",
                        "grunt-markdownlint": "^1.0.13",
                        "grunt-stylelint": "latest",
                        "grunt-yamllint": "^0.3.0",
                        "stylelint": "^8.3.0",
                        "stylelint-config-standard": "latest",
                        "time-grunt": "latest",
                        "electron-rebuild": "^1.8.2"
                      "bugs": {
                        "url": "https://github.com/ralberth/MMM-MysqlQuery/issues"
                      "homepage": "https://github.com/ralberth/MMM-MysqlQuery#readme"
                    pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install mysql --save
                    npm ERR! code ERESOLVE
                    npm ERR! ERESOLVE unable to resolve dependency tree
                    npm ERR!
                    npm ERR! While resolving: mmm-mysqlquery@1.0.0
                    npm ERR! Found: stylelint@8.4.0
                    npm ERR! node_modules/stylelint
                    npm ERR!   dev stylelint@"^8.3.0" from the root project
                    npm ERR!
                    npm ERR! Could not resolve dependency:
                    npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
                    npm ERR! node_modules/grunt-stylelint
                    npm ERR!   dev grunt-stylelint@"latest" from the root project
                    npm ERR!
                    npm ERR! Fix the upstream dependency conflict, or retry
                    npm ERR! this command with --force, or --legacy-peer-deps
                    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                    npm ERR!
                    npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                    npm ERR!     /home/pi/.npm/_logs/2022-01-06T11_56_31_385Z-debug.log
                      @richard238 I think you installed the latest version in the MagicMirror folder whereas the MysqlQuery wants version 6.4.1. Go to the root of MagicMirror and run npm uninstall mysql. Once that is done then cd modules/MMM-MysqlQuery. Then just run npm install in the folder. It should then install the dependencies that it require.
                      R 1 Reply Last reply Reply Quote -1
                        @mumblebaj
                        pi@magicmirror:~/MagicMirror $ npm uninstall mysql
                        removed 4 packages, and audited 758 packages in 14s
                        pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!     /home/pi/.npm/_logs/2022-01-06T12_07_55_731Z-debug.log
                          @richard238 It seems your versions of npm and node might be older than the required versions. run the following
                          node -v
                          npm -v
                            @mumblebaj
                             $ node -v     v10.24.1
                             $ npm -v      7.24.2
                              @richard238 You want to update both first.
                                @mumblebaj
                                Great ok, thank you.
                                What’s the best way to do those two updates, please?
                                  @richard238 Just google update npm and update node. Once those are updated then you can do the rest. Uninstall mysql and run npm install in the MMM-MysqlQuery folder. Hopefully that will resolve the issues.
                                    @mumblebaj
                                    Ok, step one completed and looking much more up-to-date:
                                    pi@magicmirror:~ $ npm -v
                                    8.3.0
                                    pi@magicmirror:~ $ node -v
                                    v17.3.0
                                      @richard238
                                      And step two:
                                      up to date, audited 758 packages in 10s
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!     /home/pi/.npm/_logs/2022-01-06T12_51_27_088Z-debug-0.log
                                        @richard238 can you check if package-lock.json exist. if it does delete it rm package-lock.json then try again. Also, did you do the uninstall in the MagicMirror folder first?
                                          @mumblebaj
                                          Yes, I did.
                                          pi@magicmirror:~ $ sudo rm package-lock.json
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!     /home/pi/.npm/_logs/2022-01-06T13_37_32_112Z-debug-0.log
                                            @richard238 seems like styleint is giving issues, Can you just try and install mysql and see if that resolves your issue?
                                              @mumblebaj
                                              Install mysql - how and where?
                                              Apologies for the detail request, but having got this far, I don’t want to break anything else.
                                              Thank you.
                                              • 1 / 4
