    How to set ipWhitelist for all device can acess to MagicMirror v2?
    18 Posts 6 Posters 13.1k Views 6 Watching
    • yawnsY Offline
      yawns Moderator @Mykle1
      @Mykle1 said in How to set ipWhitelist for all device can acess to MagicMirror v2?:
      @morozgrafix
      can I merely view it or is there some control of MM that I can use remotely?
      http://beta.magicmirror.builders/module/24/remote-control ;)
        AAPS
        If having “/24” in my ipWhitelist works, should it be fine without changing to “/120” ? This has been confusing me lately, so any help would be appreciated.
        morozgrafixM 1 Reply Last reply Reply Quote 0
        • morozgrafixM Offline
          morozgrafix Moderator @AAPS
          @Mykle1 Glad it all worked out!
          @AAPS Theoretically you are fine but you are whitelisting a lot of IPs. Assuming you are talking about IPv6. Here is a brief explanation example:
          192.168.1.1/24 subnet mask on IPv4 network would cover IP 256 IP addresses ranging from 192.168.1.0 to 192.168.1.255.
          Start IP: 192.168.1.0
          End IP: 192.168.1.255
          Addresses: 256
          Class: Class C
          Netmask: 255.255.255.0.
          Binary: 11111111	11111111	11111111	00000000
          ::ffff:192.168.1.1/120 subnet mask on IPv6 network would also cover 256 IP addresses
          Start Range: 0:0:0:0:0:ffff:c0a8:100 (IPv4 equivalent of 192.168.1.0)
          End Range: 0:0:0:0:0:ffff:c0a8:1ff (IPv4 equivalent of 192.168.1.255)
          Addresses: 256
          Now if you have ::ffff:192.168.1.1/24 subnet mask on IPv6 network, you would allow 20282409603651670423947251286016 IPs to access your mirror. Which seems to be alot, but remember that devices most likely have to be on your home network in the first place.
          Start Range: 0:0:0:0:0:0:0:0
          End Range: 0:ff:ffff:ffff:ffff:ffff:ffff:ffff
          Addresses: 20282409603651670423947251286016
          Here is a helpful cheat sheet for IPv4 and IPv6 subnet masks: https://kthx.at/subnetmask/
          Hope this helps.
            AAPS
            I seem to be fine, but do you recommend that I change anyway?
              @AAPS It’s totally your call. I don’t think it affects anything as long as your network is closed and secure.
                AAPS @morozgrafix
                @morozgrafix Thanks! I am pretty late, but congrats to you and all the other new moderators.
                morozgrafixM 1 Reply Last reply Reply Quote 1
                  @AAPS thank you.
                    Mykle1 Project Sponsor Module Developer @yawns
                    @yawns Exactly what I was looking for. Thanks
