    MMM-windyV2 module installed, but have a problem
    5 Posts 3 Posters 996 Views 3 Watching
      DavidSung
      hellow, I installed MMM-windyV2 and set config.js also.
      but when I npm run start, it’s working other modules, but not working MMM-windyV2
      just black screen and date, newsfeed etc.
      here is my cord.
      broadcastNewsUpdates: true
      module: ‘MMM-AirQuality’,
      position: ‘top_right’,
      lang: ‘kr’
      module: “MMM-WindyV2”,
      position: ‘fullscreen_above’, // this must be set to ‘fullscreen_above’
      apiKey: ‘N0KGdbz9qUYjaAbW6X0L311BHBBmGcQk’, // insert your free or paid API key here
      initLoadDelay: 50, // optional, default is 50 milliseconds
      latitude: 127.7, // example: 69.123
      longitude: 36.6, // example: 17.123
      zoomLevel: 6, // set your preferred zoom level
      showLayer: ‘rain’, // wind, rain, clouds, temp, pressure, currents, waves
      rotateLayers: false, // set to true to rotate layers
      layersToRotate: [‘wind’,‘rain’], // layers to rotate
      delayRotate: 5000, // delay between rotated layers, in milliseconds
      wMinZoom: 3, // set minimum zoom level for WindyV2
      wMaxZoom: 17, // set maximum zoom level for WindyV2
      windyMetric: ‘m/s’, // ‘kt’, ‘bft’, ‘m/s’, ‘km/h’ and ‘mph’
      updateTimer: 60 * 60 * 1000 * 6, // update per 6 hours
      retainZoom: true // retain zoomlevel between changing overlays
      // module: “MMM-windy”,
      // position: ‘fullscreen_above’, // this must be set to ‘fullscreen_above’
      // config: {
      // apiKey: ‘N0KGdbz9qUYjaAbW6X0L311BHBBmGcQk’,
      // initLoadDelay: 50, // optional, default is 50 milliseconds
      // location: { // optional location in latitude and longitude
      // lat: 36.5,
      // lng: 127.7,
      // zoom: 3, // optional zoom level, default is 5. Bigger numbers zoom closer
      // particlesAnim: ‘on’, // optional, turns particles animation on or off, default ‘on’
      // graticule: false, // optional
      // englishLabels: false, // optional
      // hourFormat: ‘12h’, // optional
      // overlay: ‘wave’ //optional
      if (typeof module !== “undefined”) {module.exports = config;}
      cowboysdudeC mumblebajM 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @DavidSung
        @davidsung Just a thought here and is very common. If you copied and pasted the config example from Github then it will not work. Go through and edit all your ’ and " and change them. For some reason they do not copy well and create errors.
        Give that a try first!
        • mumblebajM Offline
          mumblebaj Module Developer @DavidSung
          @davidsung Does seem to be related to the quotes. Also, please always remove your API Keys prior to posting. ;-)
            DavidSung @cowboysdude
            @cowboysdude thx , I will try that way :)
              DavidSung @mumblebaj
              @mumblebaj thx for ur reply, :) I didn’t thought about API key. will remove that
