    Help. MM doesn't work Anymore
    10 Posts 3 Posters 1.7k Views 3 Watching
    • E Offline
      Extra
      Hello,
      I had installed a module called on-this-day and now my MM doesn’t work. I uninstalled it and it still doesn’t work. I get this error:
      > magicmirror@2.18.0 start
      [22.01.2022 20:01.34.583] [LOG]   Starting MagicMirror: v2.18.0
      [22.01.2022 20:01.34.621] [LOG]   Loading config ...
      [22.01.2022 20:01.34.650] [LOG]   Loading module helpers ...
      [22.01.2022 20:01.34.661] [LOG]   No helper found for module: alert.
      [22.01.2022 20:01.34.746] [LOG]   Initializing new module helper ...
      [22.01.2022 20:01.34.751] [LOG]   Module helper loaded: updatenotification
      [22.01.2022 20:01.34.757] [LOG]   No helper found for module: clock.
      [22.01.2022 20:01.36.053] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
      Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
      [22.01.2022 20:01.36.058] [LOG]   Loading module helpers ...
      [22.01.2022 20:01.36.062] [LOG]   No helper found for module: alert.
      [22.01.2022 20:01.36.066] [LOG]   Initializing new module helper ...
      [22.01.2022 20:01.36.068] [LOG]   Module helper loaded: updatenotification
      [22.01.2022 20:01.36.072] [LOG]   No helper found for module: clock.
      [22.01.2022 20:01.36.215] [ERROR] App threw an error during load
      [22.01.2022 20:01.36.218] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
          at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25)
          at loadModule (/home/pi/MagicMirror/js/app.js:127:19)
          at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
          at /home/pi/MagicMirror/js/app.js:167:6
          at loadModule (/home/pi/MagicMirror/js/app.js:146:4)
          at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
          at loadModule (/home/pi/MagicMirror/js/app.js:144:6)
          at loadModules (/home/pi/MagicMirror/js/app.js:176:3)
          at /home/pi/MagicMirror/js/app.js:225:4
          at loadConfig (/home/pi/MagicMirror/js/app.js:81:4)
          at App.start (/home/pi/MagicMirror/js/app.js:212:3)
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7)
          at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
          at Object.<anonymous> (node:electron/js2c/browser_init:193:3197)
          at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401)
          at __webpack_require__ (node:electron/js2c/browser_init:1:128)
          at node:electron/js2c/browser_init:1:1200
          at node:electron/js2c/browser_init:1:1267
      [22.01.2022 20:01.36.224] [ERROR] Whoops! There was an uncaught exception...
      [22.01.2022 20:01.36.282] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
          at Function.c._load (node:electron/js2c/asar_bundle:5:13331) {
        code: 'ERR_REQUIRE_ESM'
      [22.01.2022 20:01.36.293] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [22.01.2022 20:01.36.295] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [22.01.2022 20:01.38.394] [LOG]   Launching application.
      [12298:0122/200144.333810:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      [12329:0122/200145.375493:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      [22.01.2022 20:01.58.391] [LOG]   Shutting down server...
      [22.01.2022 20:01.58.398] [LOG]   Stopping module helper: updatenotification
      [22.01.2022 20:01.58.401] [LOG]   Stopping module helper: updatenotification
      [22.01.2022 20:01.58.406] [ERROR] Whoops! There was an uncaught exception...
      [22.01.2022 20:01.58.410] [ERROR] TypeError: Cannot read properties of undefined (reading 'close')
          at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
          at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
          at App.emit (node:events:394:28)
          at appMethod (node:electron/js2c/browser_init:69:1830)
          at Object.execute (node:electron/js2c/browser_init:69:5623)
          at MenuItem.click (node:electron/js2c/browser_init:73:1862)
          at Object.a._executeCommand (node:electron/js2c/browser_init:81:2453)
      [22.01.2022 20:01.58.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [22.01.2022 20:01.58.417] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Can someone help me fix this?
        sdetweil @Extra
        @extra do
        cd ~/MagicMirror
        rm -rf node_modules
        rm package-lock.json
        npm install --only=prod
        then try starting
        • E Offline
          Extra @sdetweil
          @sdetweil No, sadly this didn’t work. I still get the same error and a blank black screen.
          Is there anything else I can do? Or do I have to uninstall and reinstall MM?
            sdetweil @Extra
            @extra no, need to seek the messages now
            where u do npm start
            if using pm2 then
            pm2 logs --lines=50
            • E Offline
              Extra @sdetweil
              @sdetweil I do npm start in
              ~/MagicMirror/modules/MMM-SmartTouch
              I don’t use pm2
              ~/MagicMirror/modules/MMM-SmartTouch $ pm2 logs--lines=50
              [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
              [PM2] PM2 Successfully daemonized
              [PM2][ERROR] Command not found
              usage: pm2 [options] <command>
              pm2 -h, --help             all available commands and options
              pm2 examples               display pm2 usage examples
              pm2 <command> -h           help on a specific command
              Access pm2 files in ~/.pm2
              ~/MagicMirror/modules/MMM-SmartTouch $ npm start
              [23.01.2022 14:55.16.782] [LOG]   Starting MagicMirror: v2.18.0
              [23.01.2022 14:55.16.820] [LOG]   Loading config ...
              [23.01.2022 14:55.16.861] [LOG]   Loading module helpers ...
              [23.01.2022 14:55.16.877] [LOG]   No helper found for module: alert.
              [23.01.2022 14:55.16.929] [LOG]   Initializing new module helper ...
              [23.01.2022 14:55.16.932] [LOG]   Module helper loaded: updatenotification
              [23.01.2022 14:55.16.934] [LOG]   No helper found for module: clock.
              [23.01.2022 14:55.17.400] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
              [23.01.2022 14:55.17.403] [LOG]   Loading module helpers ...
              [23.01.2022 14:55.17.406] [LOG]   No helper found for module: alert.
              [23.01.2022 14:55.17.408] [LOG]   Initializing new module helper ...
              [23.01.2022 14:55.17.409] [LOG]   Module helper loaded: updatenotification
              [23.01.2022 14:55.17.416] [LOG]   No helper found for module: clock.
              [23.01.2022 14:55.17.485] [ERROR] App threw an error during load
              [23.01.2022 14:55.17.487] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
              [23.01.2022 14:55.17.489] [ERROR] Whoops! There was an uncaught exception...
              [23.01.2022 14:55.17.502] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
              [23.01.2022 14:55.17.508] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [23.01.2022 14:55.17.509] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [23.01.2022 14:55.18.455] [LOG]   Launching application.
              [1416:0123/145520.523134:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
              [1446:0123/145521.167121:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
              [23.01.2022 14:55.24.239] [LOG]   Shutting down server...
              [23.01.2022 14:55.24.245] [LOG]   Stopping module helper: updatenotification
              [23.01.2022 14:55.24.246] [LOG]   Stopping module helper: updatenotification
              [23.01.2022 14:55.24.248] [ERROR] Whoops! There was an uncaught exception...
              [23.01.2022 14:55.24.252] [ERROR] TypeError: Cannot read properties of undefined (reading 'close')
              [23.01.2022 14:55.24.255] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [23.01.2022 14:55.24.258] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @Extra
                @extra so, what have you done
                did those commands
                black screen
                and since then?
                this looks like you did an npm install in the wrong folder
                • E Offline
                  Extra @sdetweil
                  @sdetweil I just copied my config file to a usb, uninstalled MM, and re-installed it and replaced the config file with the one from my usb. It’s back to normal now.
                  I appreciate the help though. Thanks again.
                    sdetweil @Extra
                    @extra how did u install?
                    • E Offline
                      Extra @sdetweil
                      @sdetweil I followed the steps on the docs (manual installation): https://docs.magicmirror.builders/getting-started/installation.html
                      Then downloaded the MMM-SmartTouch module and followed those setup instructions here: https://github.com/EbenKouao/MMM-SmartTouch
                      • mumblebajM Offline
                        mumblebaj Module Developer @Extra
                        @extra said in Help. MM doesn't work Anymore:
                        This is the wrong version of node-fetch that is installed on MM. You need to downgrade node-fetch to v2.6.1 or something earlier than v3 where the module was change to an ES module. I would uninstall node-fetch and check which module uses it and what specific version and install the correct version.
